well holy moly how have I never seen this?
And neither does SmartThings support know about it, or even wants to officially support it.
I contacted support to obtain this Custom Monitor SmartApp, they advised me that;
I would like to inform you that officialy we do not support the custom monitor smartapps in the new SmartThings app
So, I guess those of us early adopters to the new SmartThings app are out of luck.
By the way, the Left it Open SmartApp is a good solution for devices, but it doesn’t support triggering Camera recordings like the old SHM Custom Routines did. And since I can’t setup an Automation to record from an Arlo camera, I had to resort to using an old community provided SmartApp which I can only hope continues to work after all the SmartThings changes happen if they continue to not provide better support for Arlo camera integration.
Today is the last day to hit that Migrate button! I deleted all my other rules from the Classic app and with only having the custom rules enabled I migrated and don’t have any issues.
I do not see STHM in the list of smart apps.
I also lost all my classic custom monitors.
I would like to rebuild them.
Is there a way to add STHM from a template?
the new app has a region lock on some smartapps outside the US which the Classic app did not have. so, if you are outside the US, i imagine STHm is blocked to you.
always contact ST support and request that service be enabled and perhaps if enough users respond, they might open it up eventually.
without STHM, i guess you can try to use automations as best you can.
