Static IP for the SmartThings Hub
Hello!
I would like to ask if it’s possible to assign a static IP address for the SmartThings Hub. I plan to use it at work but our network isn’t configured for dynamic IP. I’ve checked the support site but I couldn’t find anything about it. The “Edit” button in the web dashboard didn’t allow me to edit the IP as well.
Thanks for your help!
I don’t know if you can do it from the client side. I set the static IP for my hub from within the router settings. You just need to know the MAC address to do that.
I am doing the same thing but it still uses DHCP with the advantage of a fixed IP address.
