ST Not Finding Some Hue Bulbs
Another ST issue I am having (I’m a new ST user) is that my hub will not find certain Hue bulbs. They are added to the Hue system through the Hue hub; however, ST cannot find them when I try to connect new things.
Some of my bulbs connected no problem. But there are a few (one of which is in the same room as the ST and Hue hubs, that ST will not find.
Anyone else running into this issue?
Thanks,
Janson
Go to your SmartApps. You should already see a Hue Connect there. Click it and then let it discover as in second image. When, the number of bulbs changes, click the + sign and check your new bulbs!
Click = Tap! :wink:
That worked! Thanks for fixing my problem!
