So, I need to use the CLI to find the port and ip that is being broadcast and add that to the App?
/status works for me and shows both garage doors my account has access to.
the logs indicate that there is communication between the server and the ST hub. but, not able to see any devices in the app yet.
11/2/2022, 12:24:04 PM | HTTP server listening on port 8090
11/2/2022, 12:24:04 PM | SSDP server up and listening for broadcasts: urn:SmartThingsCommunity:device:MyQController
11/2/2022, 12:24:07 PM | Got new username/password from hub. Initializing connection.
myQ API: Successfully connected to the myQ API.
myQ API: Discovered device family garagedoor: Garage Left (serial number: XXX, gateway: XXX).
myQ API: Discovered device family garagedoor: Garage Right (serial number: XXXX, gateway: XXX).
myQ API: Discovered device family gateway: Grey Garage [Chamberlain Smart Garage Hub] (serial number: XXX).
11/2/2022, 12:30:51 PM | Detected SSDP broadcast. Posting details back to server at http://192.168.62.14:33125/ping
UPDATE: CLI Logs Added
2022-11-02T20:54:45.215391485+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:54:52.792037403+00:00 TRACE MyQ Connector Received event with handler capability
2022-11-02T20:54:52.802727611+00:00 INFO MyQ Connector <Device: bXXX-XX-XX-XX-XXX(MyQ-Controller)> received command: {"args":{},"capability":"refresh","command":"refresh","component":"main","positional_args":{}}
2022-11-02T20:54:52.806100778+00:00 TRACE MyQ Connector Found CapabilityCommandDispatcher handler in myQConnectorDriver
2022-11-02T20:54:53.468057736+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:54:53.773442861+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:55:04.206178446+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:55:14.222546530+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:55:15.606072281+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T20:55:15.611269989+00:00 INFO MyQ Connector <Device: bXXX-XX-XX-XX-XXX(MyQ-Controller)> received lifecycle event: infoChanged
2022-11-02T20:55:15.615363072+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T20:55:15.618223947+00:00 DEBUG MyQ Connector Info changed handler invoked
2022-11-02T20:55:15.727804406+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:55:15.732920447+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:55:25.022127740+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:55:34.092371491+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:55:34.153854491+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T20:55:34.158829074+00:00 INFO MyQ Connector <Device: bXXX-XX-XX-XX-XXX(MyQ-Controller)> received lifecycle event: infoChanged
2022-11-02T20:55:34.166717241+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T20:55:34.169658199+00:00 DEBUG MyQ Connector Info changed handler invoked
2022-11-02T20:55:34.237375991+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:55:34.241349324+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:55:44.573613742+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:55:54.638084702+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:56:04.652884453+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:56:14.642874454+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:56:24.615477372+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:56:34.586152743+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
Pulled the new image. http://host:ip/status
shows my garage doors but http://host:ip/devices
shows âCannot GET /devicesâ
This is very strange. If youâre getting that far, I have no idea why the devices are not being created. If you force-kill the ST app and reopen it, can you just verify theyâre not in the unassigned room? I would be curious to see the results of your devices at the http://serverip:port/status
endpoint as well (just blank out the serial numbers and such - mostly curious what your device types are).
That is expected - the /devices endpoint only accepts POST. If the /status endpoint shows data, I do not know why your hub would not create those as devices. Very strange.
Iâll see about adding more logging. If you want to try downloading the SmartThings CLI and watching logs from that end, it could be helpful.
Forget what I said, just looked this afternoon and there they are! That was very delayed, but they are in Google Home now, BUT its not working.
Here is a log of what happens when selecting the garage device from Google Home:
11/2/2022, 9:18:09 PM | Setting Small Garage Door to on
myQ API: https://account-devices-gdo.myq-cloud.com/api/v5.2/Accounts/*{account id removed}*/door_openers/CG083015A813/on Error: 400 Bad Request
myQ API: Unable to send the command to myQ servers. Acquiring a new access token.
I did that and also removed the controller app, restarted the container and installed and configured the app again. Still donât see the doors. Logs indicate that the server and hub are able to communicate. Please see below and advise.
CLI Logs
2022-11-02T21:13:56.921914250+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T21:13:56.967961375+00:00 INFO MyQ Connector <Device: XXX-XX-XX-XX-XXXX (MyQ-Controller)> received lifecycle event: infoChanged
2022-11-02T21:13:56.991002625+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T21:13:57.008337958+00:00 DEBUG MyQ Connector Info changed handler invoked
2022-11-02T21:13:57.049433875+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T21:13:57.088609250+00:00 INFO MyQ Connector Listening for a response at 192.168.62.14:52175:XXX-XX-XX-XX-XXXX
2022-11-02T21:13:57.198125291+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:13:57.203511958+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:13:57.206705916+00:00 TRACE MyQ Connector Server:tick
2022-11-02T21:13:57.215904458+00:00 TRACE MyQ Connector Server:_tick
2022-11-02T21:13:57.222330166+00:00 TRACE MyQ Connector Server:route
2022-11-02T21:13:57.227455416+00:00 INFO MyQ Connector Content-Length: 72
Content-Type: application/json
Host: 192.168.62.14:52175
Accept: application/json, text/plain, */*
Connection: close
User-Agent: axios/0.27.2
2022-11-02T21:13:57.233257958+00:00 INFO MyQ Connector Incoming ping from 192.168.62.75:8090XXX-XX-XX-XX-XXXX
2022-11-02T21:13:57.252170541+00:00 INFO MyQ Connector Found controller.MyQController
2022-11-02T21:13:57.748713208+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T21:13:57.754936+00:00 INFO MyQ Connector <Device: XXX-XX-XX-XX-XXXX (MyQ-Controller)> received lifecycle event: infoChanged
2022-11-02T21:13:57.764059416+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T21:13:57.770037333+00:00 DEBUG MyQ Connector Info changed handler invoked
2022-11-02T21:13:59.664438792+00:00 INFO MyQ Connector <Device: XXX-XX-XX-XX-XXXX (MyQ-Controller)> emitting event: {"attribute_id":"statusText","capability_id":"towertalent27877.myqstatus","component_id":"main","state":{"value":"Connected"}}
2022-11-02T21:13:59.674193917+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:13:59.679603167+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:14:08.193594668+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:14:18.326673794+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:14:28.301355753+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:14:38.359462754+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:14:48.373620506+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:14:58.529132090+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:15:08.367863133+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:15:18.246819759+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:15:27.597176219+00:00 TRACE MyQ Connector Received event with handler capability
2022-11-02T21:15:27.605940885+00:00 INFO MyQ Connector <Device: XXX-XX-XX-XX-XXXX (MyQ-Controller)> received command: {"args":{},"capability":"refresh","command":"refresh","component":"main","positional_args":{}}
2022-11-02T21:15:27.609414469+00:00 TRACE MyQ Connector Found CapabilityCommandDispatcher handler in myQConnectorDriver
2022-11-02T21:15:28.108413385+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:15:28.170616469+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:15:38.446263845+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:15:48.346083554+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T21:15:58.303842972+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
Docker Logs
11/2/2022, 2:05:31 PM | HTTP server listening on port 8090
11/2/2022, 2:05:32 PM | SSDP server up and listening for broadcasts: urn:SmartThingsCommunity:device:MyQController
11/2/2022, 2:05:36 PM | Got new username/password from hub. Initializing connection.
myQ API: Discovered device family garagedoor: Garage Right (serial number: XXX, gateway: XXX).
11/2/2022, 2:13:58 PM | Detected SSDP broadcast. Posting details back to server at http://192.168.62.14:52175/ping
11/2/2022, 2:13:59 PM | Got new username/password from hub. Initializing connection.
Status Page Logs
[{"href":"/accounts/XXX-XX-XX-XX-XXXX/devices/garagedoor/XXX","serial_number":"XXX","device_family":"garagedoor","device_platform":"myq","device_type":"virtualgaragedooropener","device_model":"virtualgaragedooropener","name":"Garage Left","parent_device_id":"XXX","created_date":"0001-01-01T00:00:00","account_id":"XXX-XX-XX-XX-XXXX","state":{"dps_battery_critical":false,"dps_no_communication":false,"dps_low_battery_mode":false,"monitor_only_mode":false,"number_of_learned_dps_devices":1,"sensor_comm_error":false,"is_scheduling_allowed":true,"attached_camera_serial_number":"","door_state":"closed","last_update":"2022-11-02T00:51:38.3269947Z","is_unattended_open_allowed":true,"is_unattended_close_allowed":true,"service_cycle_count":0,"absolute_cycle_count":0,"online":true,"last_status":"2022-11-02T21:22:49.7783876Z"}},{"href":"/accounts/XXX-XX-XX-XX-XXXX/devices/garagedoor/XXX","serial_number":"XXX","device_family":"garagedoor","device_platform":"myq","device_type":"virtualgaragedooropener","device_model":"virtualgaragedooropener","name":"Garage Right","parent_device_id":"XXX","created_date":"0001-01-01T00:00:00","account_id":"XXX-XX-XX-XX-XXXX","state":{"dps_battery_critical":false,"dps_no_communication":false,"dps_low_battery_mode":false,"monitor_only_mode":false,"number_of_learned_dps_devices":1,"sensor_comm_error":false,"is_scheduling_allowed":true,"attached_camera_serial_number":"","door_state":"closed","last_update":"2022-11-02T15:15:11.2320763Z","is_unattended_open_allowed":true,"is_unattended_close_allowed":true,"service_cycle_count":0,"absolute_cycle_count":0,"online":true,"last_status":"2022-11-02T21:22:24.6232511Z"}},{"href":"/accounts/XXX-XX-XX-XX-XXXX/devices/gateway/XXX","serial_number":"XXX","device_family":"gateway","device_platform":"myq","device_type":"hub","device_model":"hub","name":"Grey Garage","created_date":"0001-01-01T00:00:00","account_id":"XXX-XX-XX-XX-XXXX","state":{"allow_bluetooth_lock":false,"firmware_version":"3.10","homekit_capable":false,"homekit_enabled":false,"learn_mode":false,"updated_date":"2022-11-02T18:04:42.3863276Z","physical_devices":["XXX","XXX"],"pending_bootload_abandoned":false,"wifi_rssi_decibel_milliwatts":-60,"wifi_signal_strength":"good","supports_dealer_diagnostics":false,"mandatory_update_required":false,"online":true,"last_status":"2022-11-02T18:04:38.382231Z"}}]
Thanks again for all the work on this.
Pulled the latest image. Status URL doesnât work.
Part of CLI log from my last run:
2022-11-02T20:20:07.346733498+00:00 TRACE MyQ Connector Setup driver myQConnectorDriver with lifecycle handlers:
DeviceLifecycleDispatcher: myQConnectorDriver
default_handlers:
infoChanged:
driverSwitched:
added:
init:
removed:
child_dispatchers:
2022-11-02T20:20:07.350879081+00:00 TRACE MyQ Connector Setup driver myQConnectorDriver with Capability handlers:
CapabilityCommandDispatcher: myQConnectorDriver
default_handlers:
switch:
on
off
refresh:
refresh
doorControl:
close
open
child_dispatchers:
2022-11-02T20:20:07.359229414+00:00 TRACE MyQ Connector Server.new_with
2022-11-02T20:20:07.362213164+00:00 TRACE MyQ Connector Server:post
2022-11-02T20:20:07.365287623+00:00 TRACE MyQ Connector Server:listen
2022-11-02T20:20:07.376298039+00:00 TRACE MyQ Connector Server listening on 192.168.1.240:60035
2022-11-02T20:20:07.412409789+00:00 DEBUG MyQ Connector driver device thread event handled
2022-11-02T20:20:07.415680873+00:00 TRACE MyQ Connector Received event with handler environment_info
2022-11-02T20:20:07.427818789+00:00 TRACE MyQ Connector Received event with handler environment_info
2022-11-02T20:20:07.430829706+00:00 DEBUG MyQ Connector Z-Wave hub node ID environment changed.
2022-11-02T20:20:07.434763248+00:00 TRACE MyQ Connector Received event with handler discovery
2022-11-02T20:20:07.441903039+00:00 DEBUG MyQ Connector Device discovery invoked
2022-11-02T20:20:07.447420248+00:00 INFO MyQ Connector Creating new controller device
2022-11-02T20:20:07.454887206+00:00 DEBUG MyQ Connector Exiting discovery
2022-11-02T20:20:07.457863998+00:00 DEBUG MyQ Connector discovery device thread event handled
2022-11-02T20:20:08.557561831+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T20:20:08.566179247+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received lifecycle event: added
2022-11-02T20:20:08.574726122+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T20:20:08.577815081+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received lifecycle event: doConfigure
2022-11-02T20:20:08.582962039+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T20:20:08.586025956+00:00 INFO MyQ Connector cdbb61fb-c9fa-4425-9b80-cf0fd0301e32: MyQController> ADDED
2022-11-02T20:20:08.588903372+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:20:08.606759831+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T20:20:08.609546956+00:00 DEBUG MyQ Connector MyQ-Controller: MyQController> INITIALIZING
2022-11-02T20:20:08.612671456+00:00 INFO MyQ Connector No credentials yet. Waiting.unknown
2022-11-02T20:20:08.615857164+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> emitting event: {"attribute_id":"statusText","capability_id":"towertalent27877.myqstatus","component_id":"main","state":{"value":"Awaiting credentials"}}
2022-11-02T20:20:08.650848414+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:20:08.655700039+00:00 TRACE MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received unhandled lifecycle event: doConfigure
2022-11-02T20:20:08.658582664+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:20:08.667137997+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:20:08.672303039+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:20:11.760552496+00:00 TRACE MyQ Connector Received event with handler capability
2022-11-02T20:20:11.826673705+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received command: {"args":{},"capability":"refresh","command":"refresh","component":"main","positional_args":{}}
2022-11-02T20:20:11.830113038+00:00 TRACE MyQ Connector Found CapabilityCommandDispatcher handler in myQConnectorDriver
2022-11-02T20:20:11.833058955+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:20:13.938024913+00:00 TRACE MyQ Connector Received event with handler discovery
2022-11-02T20:20:18.661259037+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:20:28.662719659+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:20:38.670534490+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:20:48.680444363+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:20:52.484816487+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T20:20:52.491038320+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received lifecycle event: infoChanged
2022-11-02T20:20:52.509109153+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T20:20:52.512098862+00:00 DEBUG MyQ Connector Info changed handler invoked
2022-11-02T20:20:52.520650612+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:20:52.525520528+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:02.233465575+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T20:21:02.240501722+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received lifecycle event: infoChanged
2022-11-02T20:21:02.310743125+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T20:21:02.314005910+00:00 DEBUG MyQ Connector Info changed handler invoked
2022-11-02T20:21:02.323548844+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:02.328086408+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:11.556136365+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T20:21:11.561470697+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received lifecycle event: infoChanged
2022-11-02T20:21:11.605823842+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T20:21:11.608795064+00:00 DEBUG MyQ Connector Info changed handler invoked
2022-11-02T20:21:11.617180411+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:21:11.630888679+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:21:13.644648722+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:13.649697347+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:17.412012473+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T20:21:17.417732348+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received lifecycle event: infoChanged
2022-11-02T20:21:17.428088264+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T20:21:17.431117806+00:00 DEBUG MyQ Connector Info changed handler invoked
2022-11-02T20:21:17.439713514+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:21:17.453537764+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:21:19.467222265+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:19.472092265+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:23.397695474+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T20:21:23.409361849+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received lifecycle event: infoChanged
2022-11-02T20:21:23.415218640+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T20:21:23.419002724+00:00 DEBUG MyQ Connector Info changed handler invoked
2022-11-02T20:21:23.427841724+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:21:23.442313224+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:21:25.455850724+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:25.460909682+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:28.445693349+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:21:28.506966807+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:21:30.520680391+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:30.938439308+00:00 TRACE MyQ Connector Received event with handler capability
2022-11-02T20:21:30.977046016+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received command: {"args":{},"capability":"refresh","command":"refresh","component":"main","positional_args":{}}
2022-11-02T20:21:31.007382308+00:00 TRACE MyQ Connector Found CapabilityCommandDispatcher handler in myQConnectorDriver
2022-11-02T20:21:31.010320141+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:21:31.032948266+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:21:33.051237391+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:33.455518266+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:21:33.507246975+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:21:35.521758933+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:38.450644975+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:21:38.509662767+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:21:40.528735809+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:43.459963143+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:21:43.509685643+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:21:45.523647643+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:48.464374393+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:21:48.510052977+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:21:50.535512268+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:53.469587310+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:21:53.483243019+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:21:55.504996561+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:21:58.471143478+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:21:58.484834061+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:22:00.515783020+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:03.480426645+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:22:03.494137020+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:22:05.518059020+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:08.494703479+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:22:08.511020937+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:22:10.614312646+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:10.617940062+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T20:22:10.622786937+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received lifecycle event: infoChanged
2022-11-02T20:22:10.630552687+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T20:22:10.633418271+00:00 DEBUG MyQ Connector Info changed handler invoked
2022-11-02T20:22:10.641605271+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:22:10.718058937+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:22:12.731452729+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:12.745836063+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:15.645801396+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:22:15.715470396+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:22:17.729531563+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:20.651376480+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:22:20.721026189+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:22:22.639741356+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:22.643338814+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T20:22:22.650367064+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received lifecycle event: infoChanged
2022-11-02T20:22:22.710603231+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T20:22:22.717130772+00:00 DEBUG MyQ Connector Info changed handler invoked
2022-11-02T20:22:22.760579356+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T20:22:22.804492981+00:00 INFO MyQ Connector Listening for a response at 192.168.1.240:60035:cdbb61fb-c9fa-4425-9b80-cf0fd0301e32
2022-11-02T20:22:24.096718314+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:24.100425772+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:24.103558064+00:00 TRACE MyQ Connector Received event with handler device_lifecycle
2022-11-02T20:22:24.108694356+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received lifecycle event: infoChanged
2022-11-02T20:22:24.114001147+00:00 TRACE MyQ Connector Found DeviceLifecycleDispatcher handler in myQConnectorDriver
2022-11-02T20:22:24.117018147+00:00 DEBUG MyQ Connector Info changed handler invoked
2022-11-02T20:22:24.652583772+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> emitting event: {"attribute_id":"statusText","capability_id":"towertalent27877.myqstatus","component_id":"main","state":{"value":"Connected"}}
2022-11-02T20:22:24.662427647+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:24.709084397+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:25.876110814+00:00 TRACE MyQ Connector Received event with handler capability
2022-11-02T20:22:25.900218314+00:00 INFO MyQ Connector <Device: cdbb61fb-c9fa-4425-9b80-cf0fd0301e32 (MyQ-Controller)> received command: {"args":{},"capability":"refresh","command":"refresh","component":"main","positional_args":{}}
2022-11-02T20:22:25.903527564+00:00 TRACE MyQ Connector Found CapabilityCommandDispatcher handler in myQConnectorDriver
2022-11-02T20:22:25.953860231+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:29.993180065+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:34.637208357+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:39.635930608+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T20:22:44.603044692+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
Donât worry about that. If you try again, it should work. The MyQ api just randomly fails like that from time to time.
I pushed an update to the Edge driver. Might take awhile before you get it, but once you do, it should be more descriptive:
Same deal - see what the CLI logs show during refresh when you get the latest driver version. I assume youâre using the IP address of your docker host when hitting the /status endpoint?
Scratch that. There is a bug in the door open command I think. Slipped through when I added switch capability. Will get that fixed.
This is now fixed in the latest edge driver version, so it should get pushed out over time. If you had door devices created previously, you will need to delete them and let them get recreated for the fix to apply.
@brbeaird I started over with a clean install, pulled the latest Docker Image and driver and Iâm still stuck at Awaiting Credentials.
Docker Logs show the server up and running
11/2/2022, 11:03:53 PM | HTTP server listening on port 8090
11/2/2022, 11:03:53 PM | SSDP server up and listening for broadcasts: urn:SmartThingsCommunity:device:MyQController
CLI Device log recognized username/password entries with
showed âInfo Changed handler invokedâ
Then, repeatedly âŚ
2022-11-02T23:11:57.978029070+00:00 DEBUG MyQ Connector MyQ-Controller device thread event handled
2022-11-02T23:12:05.960228821+00:00 INFO MyQ Connector Send broadcast looking for bridge server
2022-11-02T23:12:05.974405779+00:00 INFO MyQ Connector Listening for a response at 192.168.1.166:46077:c228492a-xxxx
Reading thru the posts above, Iâm at a loss at this point.
@ViperTK - Were you able to get the devices installed? Looking at your last post I think we may be having the same issue.
I noticed your garages are showing as âvirtualgaragedooropenerâ. Iâm having issues with the garage device being created for my garage that has a type of âwifigaragedooropenerâ, but my garage door with type âgaragedooropenerâ is created fine.
@brbeaird - In your edge driver are you specifically looking for âgaragedooropenerâ ? Iâm wondering if that is why some of our devices are not being created in SmartThings.
No, still the same. Communication between the hub and server is good. but devices are not being created. My device type showing up as virtual could be due to the fact that I have the add-on MyQ controller that controls both doors. I donât have the openers with in-built MyQ in them like some models.
Waiting on @brbeaird to advise on a possible remedy.
To anyone who has an RPI and using SSH or the Terminal window⌠consider getting Portainer. It will make things so much easier than trying to figure out why all the commands donât work. Portainer offers a free 5 user license when you sign up. I donât know if there are other options out there so check around if you donât want to deal with the commands. It kept failing on me tonight with the new commands so I sought out a program that would manage docker on rpi. Installed it and had the container up in moments.
now trying to figure out why I canât get the connector to install
Not sure if my driver has updated. Is the latest V2022-11-02T05:08:15.091547917?
Yes, Iâm using http://192.168.4.200:8090/status where 192.168.4.200 is my raspberry pi zero w docker host IP.
@bthrock, perhaps youâre having the same broadcast problem I was having when using the Bridge network. Iâm starting to think it has something to do with the specific host platform that docker is running on (some platforms forwarding broadcast packets to the container, some not).
If you attach the container to the host network and delete the forwarded ports, that might cause the bridge server to see the ST hub.
You may be on to something! I just updated the edge driver to look for device_family = garagedoor instead of device_type. Letâs see if that works.
@BartschLabs @jkp and anyone else running docker on a Raspberry pi - can you kill your container and then run this command to launch a new one?
docker run -d --name='smartthings-myq-edge' --network=host 'brbeaird/smartthings-myq-edge:latest'
You may need to prefix it with sudo
if the user youâre running it as does not have docker admin rights.
I am not able to get this working using bridge mode on my pi with docker. This seems to be because certain docker platforms are more restrictive in letting UDP broadcasts come through. The workaround is to just use host mode for now.
that loaded fine for me.
I was able to get UDP configured in Docker using brdige but could not verify it was working.
I was able to get my Connector installed earlier (had to reboot ST hub) and server reports the devices but still waiting on Garage Door to load in the app. Still not found with your latest docker commands but may be too soon.
