[ST Edge] Zigbee2MQTT-based drivers for 3,000+ Tuya, Aqara, IKEA, SONOFF and other Zigbee devices
Hi everyone,
I’ve been working on a collection of SmartThings Edge drivers that ports device support from Zigbee2MQTT.
This is an ongoing project and does not cover the full Zigbee2MQTT catalog. The channel currently includes 18 drivers with nearly 4,000 fingerprint entries, and more device families will be added over time.
Driver channel
Supported devices and source code
Support is split across multiple drivers, so please check the GitHub README for your device’s fingerprint and install the driver listed for it.
Current coverage includes selected models from Aqara, Xiaomi, IKEA, Philips, OSRAM, LEDVANCE, Innr, GLEDOPTO, SONOFF, Third Reality, HEIMAN, Schneider Electric, Legrand, Bosch, Frient, Sunricher, and other manufacturers.
It also includes many Tuya-based devices sold under different regional and white-label brands.
Device types currently represented include:
  • Lights, dimmers, switches, relays, and smart plugs
  • Motion, presence, environmental, and safety sensors
  • Covers, thermostats, TRVs, fans, and valves
  • Power and energy meters
  • Buttons, scene switches, remotes, and repeaters
Not every feature exposed by Zigbee2MQTT is available as a SmartThings capability yet. I’m focusing on the main controls and status values first. If there is a missing option or feature you need, please let me know.
Many fingerprints were added from Zigbee2MQTT definitions but have not yet been tested on real SmartThings hardware. If something does not work as expected, please report it with the relevant hub logcat output.
I tested Nedis ZBWS40WT (Manufacturer: _TZ3000_wkai4ga5 Model: TS0044) with this driver. The device worked with this driver.
More info:
During pairing two error messages to logcat log:
2026-07-20T08:48:02.129976699Z WARN ZCL Controls wonjj6768  Unexpected filesystem lookup for capability concertmirror08464.lastPowerResponseTime
2026-07-20T08:48:02.154771365Z ERROR ZCL Controls wonjj6768  ZCL Controls wonjj6768 thread encountered error: [string "st/dispatcher.lua"]:270: Error encountered while processing event for <ZigbeeDevice: --- Device ID removed  --- [0x0B8D] (ZCL Controls wonjj6768)>:
    arg1: init
"[string "zcl_common/metering.lua"]:108: Capability concertmirror08464.lastPowerResponseTime version 1 definition not found"
2026-07-20T08:48:03.058413032Z WARN ZCL Controls wonjj6768  Unexpected filesystem lookup for capability concertmirror08464.lastPowerResponseTime
2026-07-20T08:48:03.111251615Z ERROR ZCL Controls wonjj6768  ZCL Controls wonjj6768 thread encountered error: [string "st/dispatcher.lua"]:270: Error encountered while processing event for <ZigbeeDevice: a047ee12-e96f-4e24-9178-00e45b4b6846 [0x0B8D] (ZCL Controls wonjj6768)>:
    arg1: infoChanged
    arg2: {device_already_existed=true, old_st_store={_provisioning_state="TYPED", child_ids={}, data={}, device_network_id="0B8D", driver={id="e96a3498-0e62-4667-8a9a-a0e6e7cf11b5", name="ZCL Controls wonjj6768", type="FIELD_DEPRECATED"}, execution_environment="HUBCORE", fingerprinted_endpoint_id=1, id="--- Device ID removed  ---", label="ZCL Controls wonjj6768", network_type="DEVICE_ZIGBEE", parent_device_id="--- Device ID removed  ---", preferences={}, profile={components={button2={capabilities={button={id="button", version=1}}, emit_event=function: 0x1a19f50, id="button2"}, button3={capabilities={button={id="button", version=1}}, emit_event=function: 0x1a1bec0, id="button3"}, button4={capabilities={button={id="button", version=1}}, emit_event=function: 0x1a320a0, id="button4"}, main={capabilities={battery={id="battery", version=1}, button={id="button", version=1}, refresh={id="refresh", version=1}}, emit_event=function: 0x1a32100, id="main"}}, id="adb0535d-7572-361e-a9f0-d43c451c2d8e"}, zigbee_endpoints={{client_clusters={25, 10}, device_id=0, id=1, manufacturer="_TZ3000_wkai4ga5", model="TS0044", profile_id=260, server_clusters={0, 1, 6}}, {client_clusters={}, device_id=0, id=2, profile_id=260, server_clusters={1, 6}}, {client_clusters={}, device_id=0, id=3, profile_id=260, server_clusters={1, 6}}, {client_clusters={}, device_id=0, id=4, profile_id=260, server_clusters={1, 6}}}, zigbee_eui="\xF0\x62\xC0\xFF\xFE\x1B\x97\x84"}}
Thank you for testing the driver and sharing the log. It helped me identify the problem, and the issue has now been fixed.
So i have a tds sensor that paired and seems to work with the ef00 sensors driver but the TDS ppm value doesnt seem to populate. I tried under tap water and under my reverse osmosis water, the value never updates and stays at default 0ppm.
I have the DTS1XM9 by excellux.
Hi @wonjj6768,
Would you be able to add the following device?
Haozee Smart Vibration Alarm, Real-time Monitoring
Model name: ZG-103Z
Manufacturer (Code): Hobeian
Connection Method: Hub (Zigbee)
Vibration Sensor App Version: 2.3.66-1
Much appreciated,
Jeff
See here:
Hi Andreas,
I installed it yesterday, but no luck. ST still doesn’t see it as an available driver.
Can you see if the dp for tds is correct? I think its supposed to be 124. Currently, i get no reading from the tds which sucks.
Hi Jeff,
Support for the HOBEIAN ZG-103Z has been added and published in the latest EF00 Safety driver.
Hi Jason,
I checked it: TDS is correctly mapped to DP124, matching Zigbee2MQTT. Please capture a hub logcat while pressing the physical button on the sensor, as it may trigger the DP124 report.
2026-08-20T19:12:02.545754961Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:12:02.546713836Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC5CF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCC, rssi: -79, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xD4, ZCLCommandId: 0x25 >, GenericBody: AD 84 > >2026-08-20T19:12:02.549561044Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:12:02.576448002Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC5CF, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x11, seqno: 0x00, ZCLCommandId: 0x25 >, GenericBody: AD 01 01 > >
2026-08-20T19:12:02.605691711Z DEBUG EF00 Sensors wonjj6768 ultrasonic device thread event handled
2026-08-20T19:12:13.527882045Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:12:13.537705045Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC5CF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xD0, rssi: -78, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xD5, ZCLCommandId: 0x25 >, GenericBody: AF 84 > >
2026-08-20T19:12:13.541420962Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:12:13.544871045Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC5CF, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x11, seqno: 0x00, ZCLCommandId: 0x25 >, GenericBody: AF 01 01 > >
2026-08-20T19:12:13.569922545Z DEBUG EF00 Sensors wonjj6768 ultrasonic device thread event handled
2026-08-20T19:12:24.519844922Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:12:24.533225255Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC5CF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC8, rssi: -79, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xD6, ZCLCommandId: 0x25 >, GenericBody: B1 84 > >
2026-08-20T19:12:24.539908338Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:12:24.553327880Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC5CF, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x11, seqno: 0x00, ZCLCommandId: 0x25 >, GenericBody: B1 01 01 > >
2026-08-20T19:12:24.577862505Z DEBUG EF00 Sensors wonjj6768 ultrasonic device thread event handled
2026-08-20T19:12:35.346479590Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:12:35.347442090Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 366c0a16-7914-4c75-8da2-c6e3cbc78f67 [0x227A] (front flowers)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x227A, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xD4, rssi: -62, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xDE, ZCLCommandId: 0x02 >, GenericBody: 00 2F 03 02 00 04 00 00 00 60 > >
2026-08-20T19:12:35.350403798Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:12:35.353899381Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 366c0a16-7914-4c75-8da2-c6e3cbc78f67 [0x227A] (front flowers)> emitting event: {“attribute_id”:“soilMoisture”,“capability_id”:“concertmirror08464.soilMoisture”,“component_id”:“main”,“state”:{“unit”:“%”,“value”:96}}
2026-08-20T19:12:35.377498548Z DEBUG EF00 Sensors wonjj6768 front flowers device thread event handled
2026-08-20T19:12:35.495683715Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:12:35.499019465Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 366c0a16-7914-4c75-8da2-c6e3cbc78f67 [0x227A] (front flowers)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x227A, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xD4, rssi: -62, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xDF, ZCLCommandId: 0x02 >, GenericBody: 00 30 66 02 00 04 00 00 13 EF > >
2026-08-20T19:12:35.502909965Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:12:35.506348756Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 366c0a16-7914-4c75-8da2-c6e3cbc78f67 [0x227A] (front flowers)> emitting event: {“attribute_id”:“illuminance”,“capability_id”:“illuminanceMeasurement”,“component_id”:“main”,“state”:{“value”:5103}}
2026-08-20T19:12:35.521606548Z DEBUG EF00 Sensors wonjj6768 front flowers device thread event handled
2026-08-20T19:12:36.535746673Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:12:36.536916756Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC5CF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xBE, rssi: -74, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xD7, ZCLCommandId: 0x25 >, GenericBody: B3 84 > >
2026-08-20T19:12:36.538109631Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:12:36.552428215Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC5CF, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x11, seqno: 0x00, ZCLCommandId: 0x25 >, GenericBody: B3 01 01 > >
2026-08-20T19:12:36.569579381Z DEBUG EF00 Sensors wonjj6768 ultrasonic device thread event handled
2026-08-20T19:12:45.199392966Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:12:45.209396924Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: ce7361c3-2de5-4660-999d-5e6bd47c286d [0xEE9B] (Foyer flowers)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xEE9B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xD4, rssi: -56, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xE4, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint8, ZCLVersion: 0x03 > > > >
2026-08-20T19:12:45.213132674Z DEBUG EF00 Sensors wonjj6768 Foyer flowers device thread event handled
2026-08-20T19:12:47.525681883Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:12:47.533052549Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC5CF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC2, rssi: -74, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xD8, ZCLCommandId: 0x25 >, GenericBody: B5 84 > >
2026-08-20T19:12:47.536845049Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:12:47.540298591Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC5CF, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x11, seqno: 0x00, ZCLCommandId: 0x25 >, GenericBody: B5 01 01 > >
2026-08-20T19:12:47.554304549Z DEBUG EF00 Sensors wonjj6768 ultrasonic device thread event handled
2026-08-20T19:12:58.526101967Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:12:58.527075967Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC5CF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC8, rssi: -76, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xD9, ZCLCommandId: 0x25 >, GenericBody: B7 84 > >
2026-08-20T19:12:58.528270634Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:12:58.528970551Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC5CF, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x11, seqno: 0x00, ZCLCommandId: 0x25 >, GenericBody: B7 01 01 > >
2026-08-20T19:12:58.551508967Z DEBUG EF00 Sensors wonjj6768 ultrasonic device thread event handled
2026-08-20T19:13:04.494607260Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:04.505909676Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 366c0a16-7914-4c75-8da2-c6e3cbc78f67 [0x227A] (front flowers)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x227A, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xD4, rssi: -62, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xE0, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint8, ZCLVersion: 0x03 > > > >
2026-08-20T19:13:04.512318343Z DEBUG EF00 Sensors wonjj6768 front flowers device thread event handled
2026-08-20T19:13:09.505956677Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:09.508662094Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC5CF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC2, rssi: -75, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xDA, ZCLCommandId: 0x25 >, GenericBody: B9 84 > >
2026-08-20T19:13:09.512753635Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:09.516350469Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC5CF, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x11, seqno: 0x00, ZCLCommandId: 0x25 >, GenericBody: B9 01 01 > >
2026-08-20T19:13:09.527951719Z DEBUG EF00 Sensors wonjj6768 ultrasonic device thread event handled
2026-08-20T19:13:12.771892011Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:12.820373219Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x15, ZCLCommandId: 0x02 >, GenericBody: 00 01 04 02 00 04 00 00 00 64 > >
2026-08-20T19:13:12.845950302Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:12.904839177Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:100}}
2026-08-20T19:13:12.959749594Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:13.036142011Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:13.080358011Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xCE, rssi: -69, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x16, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1930 >, < AttributeRecord || AttributeId: 0xFEFE, DataType: Int16, Int16: 134 > > > >
2026-08-20T19:13:13.106202719Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:13.170195969Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:13.195745219Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC2, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x17, ZCLCommandId: 0x02 >, GenericBody: 00 02 01 02 00 04 00 00 00 C1 > >
2026-08-20T19:13:13.196988886Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:13.197692011Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“probeTemperature”,“capability_id”:“concertmirror08464.dts1xm9ProbeTemperature”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:19.3}}
2026-08-20T19:13:13.221798719Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:13.366242011Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:13.380125719Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xD0, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x18, ZCLCommandId: 0x02 >, GenericBody: 00 03 6E 02 00 04 00 00 03 20 > >
2026-08-20T19:13:13.390759928Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:13.394364303Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“probeTemperatureVOne”,“capability_id”:“concertmirror08464.dts1xm9ProbeTemperatureV1”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:80.0}}
2026-08-20T19:13:13.416480928Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:13.633835219Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:13.700599969Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x02, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0xFF, profile: 0x0104, cluster: Identify >, lqi: 0xCE, rssi: -68, body_length: 0x0003, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x11, seqno: 0x19, ZCLCommandId: 0x01 >, < IdentifyQuery || > > >
2026-08-20T19:13:13.707392678Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:13.713651219Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:13.722340803Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xAA, rssi: -68, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x1A, ZCLCommandId: 0x02 >, GenericBody: 00 04 70 04 00 01 00 > >
2026-08-20T19:13:13.726987219Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:13.735499469Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“probeTemperatureWarning”,“capability_id”:“concertmirror08464.dts1xm9ProbeTemperatureWarning”,“component_id”:“main”,“state”:{“value”:“none”}}
2026-08-20T19:13:13.759710928Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:13.874102053Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:13.887598344Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x1B, ZCLCommandId: 0x02 >, GenericBody: 00 05 05 02 00 04 00 00 08 26 > >
2026-08-20T19:13:13.894421886Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:13.902521136Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:20.86}}
2026-08-20T19:13:13.925339428Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:14.039972219Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:14.273969844Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x1C, ZCLCommandId: 0x02 >, GenericBody: 00 06 73 02 00 04 00 00 00 00 > >
2026-08-20T19:13:14.318543094Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:14.334658886Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“airTemperatureVZero”,“capability_id”:“concertmirror08464.dts1xm9AirTemperatureV0”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:0.0}}
2026-08-20T19:13:14.363738053Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:14.367257761Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:14.396407094Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xD0, rssi: -68, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x1D, ZCLCommandId: 0x02 >, GenericBody: 00 07 75 04 00 01 00 > >
2026-08-20T19:13:14.400471678Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:14.409162844Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“airTemperatureWarning”,“capability_id”:“concertmirror08464.dts1xm9AirTemperatureWarning”,“component_id”:“main”,“state”:{“value”:“none”}}
2026-08-20T19:13:14.427801386Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:14.665833386Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:14.666787261Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCA, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x1F, ZCLCommandId: 0x02 >, GenericBody: 00 08 76 02 00 04 00 00 1D B5 > >
2026-08-20T19:13:14.690106594Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:14.724320386Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“humidity”,“capability_id”:“relativeHumidityMeasurement”,“component_id”:“main”,“state”:{“value”:76.05}}
2026-08-20T19:13:14.784613094Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:14.817339011Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:14.818180886Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCA, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x20, ZCLCommandId: 0x02 >, GenericBody: 00 09 78 02 00 04 00 00 03 E8 > >
2026-08-20T19:13:14.819318594Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:14.819991761Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“humidityVZero”,“capability_id”:“concertmirror08464.dts1xm9HumidityV0”,“component_id”:“main”,“state”:{“unit”:“%”,“value”:10.0}}
2026-08-20T19:13:14.864679136Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:15.010492969Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:15.036210303Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -68, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x21, ZCLCommandId: 0x02 >, GenericBody: 00 0A 7A 04 00 01 00 > >
2026-08-20T19:13:15.041450719Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:15.088020511Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“humidityWarning”,“capability_id”:“concertmirror08464.dts1xm9HumidityWarning”,“component_id”:“main”,“state”:{“value”:“none”}}
2026-08-20T19:13:15.100402303Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:15.175748469Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:15.176519178Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC6, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x22, ZCLCommandId: 0x02 >, GenericBody: 00 0B 7D 02 00 04 00 00 19 64 > >
2026-08-20T19:13:15.198677094Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:15.202295178Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“tdsWarningSet”,“capability_id”:“concertmirror08464.dts1xm9TdsThreshold”,“component_id”:“main”,“state”:{“unit”:“ppm”,“value”:6500}}
2026-08-20T19:13:15.222624678Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:15.391544094Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:15.398307886Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCA, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x23, ZCLCommandId: 0x02 >, GenericBody: 00 0C 7F 02 00 04 00 00 00 00 > >
2026-08-20T19:13:15.403866011Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:15.411226969Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“ec”,“capability_id”:“concertmirror08464.dts1xm9Ec”,“component_id”:“main”,“state”:{“unit”:“μS/cm”,“value”:0}}
2026-08-20T19:13:15.421602303Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:15.639371344Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:15.666599219Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xD0, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x24, ZCLCommandId: 0x02 >, GenericBody: 00 0D 81 02 00 04 00 00 27 10 > >
2026-08-20T19:13:15.667821303Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:15.678518594Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“ecVOne”,“capability_id”:“concertmirror08464.dts1xm9EcV1”,“component_id”:“main”,“state”:{“unit”:“μS/cm”,“value”:10000}}
2026-08-20T19:13:15.694367761Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:15.822900053Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:15.857721511Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -67, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x25, ZCLCommandId: 0x02 >, GenericBody: 00 0E 82 04 00 01 01 > >
2026-08-20T19:13:15.876384011Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:15.877161636Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“ecWarning”,“capability_id”:“concertmirror08464.dts1xm9EcWarning”,“component_id”:“main”,“state”:{“value”:“low”}}
2026-08-20T19:13:16.054285386Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:16.060964970Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:16.072931303Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x26, ZCLCommandId: 0x02 >, GenericBody: 00 0F 84 02 00 04 00 00 03 E8 > >
2026-08-20T19:13:16.080209386Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:16.082863053Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:20.151467220Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:20.167100262Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCA, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x27, ZCLCommandId: 0x02 >, GenericBody: 00 10 65 02 00 04 00 00 02 58 > >
2026-08-20T19:13:20.170864678Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:20.189654887Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“samplingInterval”,“capability_id”:“concertmirror08464.dts1xm9SamplingInterval”,“component_id”:“main”,“state”:{“unit”:“s”,“value”:600}}
2026-08-20T19:13:20.208864178Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:20.342088428Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:20.343044720Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xD0, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x28, ZCLCommandId: 0x02 >, GenericBody: 00 11 04 02 00 04 00 00 00 64 > >
2026-08-20T19:13:20.346733262Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:20.351469053Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:100}}
2026-08-20T19:13:20.360529720Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:20.556187137Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:20.567275970Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC5CF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC2, rssi: -82, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xDB, ZCLCommandId: 0x25 >, GenericBody: BB 84 > >
2026-08-20T19:13:20.573759637Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:20.577895803Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC5CF, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x11, seqno: 0x00, ZCLCommandId: 0x25 >, GenericBody: BB 01 01 > >
2026-08-20T19:13:20.593478428Z DEBUG EF00 Sensors wonjj6768 ultrasonic device thread event handled
2026-08-20T19:13:20.615970678Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:20.646400553Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0xCA, rssi: -68, body_length: 0x000B, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x29, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0xC8 >, < AttributeRecord || AttributeId: 0x0020, DataType: Uint8, BatteryVoltage: 0x1E > > > >
2026-08-20T19:13:20.678899970Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:20.682516220Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:20.735488512Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:20.744003970Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xCE, rssi: -68, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x2A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1930 >, < AttributeRecord || AttributeId: 0xFEFE, DataType: Int16, Int16: 134 > > > >
2026-08-20T19:13:20.749843470Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:20.946050303Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:20.948991095Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x2B, ZCLCommandId: 0x02 >, GenericBody: 00 12 01 02 00 04 00 00 00 C1 > >
2026-08-20T19:13:20.953949970Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:20.965175470Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“probeTemperature”,“capability_id”:“concertmirror08464.dts1xm9ProbeTemperature”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:19.3}}
2026-08-20T19:13:20.975178637Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:21.146172303Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:21.147133637Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC6, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x2C, ZCLCommandId: 0x02 >, GenericBody: 00 13 6D 02 00 04 00 00 00 00 > >
2026-08-20T19:13:21.148572137Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:21.150028637Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“probeTemperatureVZero”,“capability_id”:“concertmirror08464.dts1xm9ProbeTemperatureV0”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:0.0}}
2026-08-20T19:13:21.158645970Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:21.346468762Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:21.359526387Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x2D, ZCLCommandId: 0x02 >, GenericBody: 00 14 6E 02 00 04 00 00 03 20 > >
2026-08-20T19:13:21.360726220Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:21.361658262Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“probeTemperatureVOne”,“capability_id”:“concertmirror08464.dts1xm9ProbeTemperatureV1”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:80.0}}
2026-08-20T19:13:21.366552345Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:21.649327054Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:21.650501720Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC8, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x2E, ZCLCommandId: 0x02 >, GenericBody: 00 15 6C 02 00 04 00 00 00 00 > >
2026-08-20T19:13:21.651762887Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:21.652463179Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“probeTemperatureCalibration”,“capability_id”:“concertmirror08464.dts1xm9ProbeTempCalibration”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:0.0}}
2026-08-20T19:13:21.658274387Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:21.806155429Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:21.817709804Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC4, rssi: -67, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x2F, ZCLCommandId: 0x02 >, GenericBody: 00 16 70 04 00 01 00 > >
2026-08-20T19:13:21.818907970Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:21.819585679Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“probeTemperatureWarning”,“capability_id”:“concertmirror08464.dts1xm9ProbeTemperatureWarning”,“component_id”:“main”,“state”:{“value”:“none”}}
2026-08-20T19:13:21.824562345Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:22.146973554Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:22.147941345Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC6, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x30, ZCLCommandId: 0x02 >, GenericBody: 00 17 05 02 00 04 00 00 08 53 > >
2026-08-20T19:13:22.150863887Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:22.156446387Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:21.31}}
2026-08-20T19:13:22.171700220Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:22.335786804Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:22.336742762Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC6, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x31, ZCLCommandId: 0x02 >, GenericBody: 00 18 72 02 00 04 00 00 00 00 > >
2026-08-20T19:13:22.342677054Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:22.347246470Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“airTemperatureCalibration”,“capability_id”:“concertmirror08464.dts1xm9AirTemperatureCalibration”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:0.0}}
2026-08-20T19:13:22.357978637Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:22.846050554Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:22.887397595Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC6, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x32, ZCLCommandId: 0x02 >, GenericBody: 00 19 73 02 00 04 00 00 00 00 > >
2026-08-20T19:13:22.907822762Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:22.993500512Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“airTemperatureVZero”,“capability_id”:“concertmirror08464.dts1xm9AirTemperatureV0”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:0.0}}
2026-08-20T19:13:23.055879554Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:23.056807554Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:23.306426762Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC2, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x33, ZCLCommandId: 0x02 >, GenericBody: 00 1A 74 02 00 04 00 00 0F A0 > >
2026-08-20T19:13:23.311326970Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:23.312097929Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“airTemperatureVOne”,“capability_id”:“concertmirror08464.dts1xm9AirTemperatureV1”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:40.0}}
2026-08-20T19:13:23.341610345Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:23.342338929Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:23.342967804Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -67, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x34, ZCLCommandId: 0x02 >, GenericBody: 00 1B 75 04 00 01 00 > >
2026-08-20T19:13:23.355557804Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:23.357774345Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“airTemperatureWarning”,“capability_id”:“concertmirror08464.dts1xm9AirTemperatureWarning”,“component_id”:“main”,“state”:{“value”:“none”}}
2026-08-20T19:13:23.397870304Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:23.459845054Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:23.493216179Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: RelativeHumidity >, lqi: 0xD0, rssi: -67, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x35, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint16, MeasuredValue: 0x1CB9 >, < AttributeRecord || AttributeId: 0xFEFE, DataType: Uint16, Uint16: 0x0086 > > > >
2026-08-20T19:13:23.507939137Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:23.606357387Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:23.611625095Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x36, ZCLCommandId: 0x02 >, GenericBody: 00 1C 02 02 00 04 00 00 00 49 > >
2026-08-20T19:13:23.620617262Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:23.625045429Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:23.922331054Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:23.926529554Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x37, ZCLCommandId: 0x02 >, GenericBody: 00 1D 76 02 00 04 00 00 1C B9 > >
2026-08-20T19:13:23.938256304Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:24.015329595Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“humidity”,“capability_id”:“relativeHumidityMeasurement”,“component_id”:“main”,“state”:{“value”:73.53}}
2026-08-20T19:13:24.056896804Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:24.105887304Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:24.106835512Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x38, ZCLCommandId: 0x02 >, GenericBody: 00 1E 77 02 00 04 00 00 00 00 > >
2026-08-20T19:13:24.108011929Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:24.108712970Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“humidityCalibration”,“capability_id”:“concertmirror08464.dts1xm9HumidityCalibration”,“component_id”:“main”,“state”:{“unit”:“%”,“value”:0.0}}
2026-08-20T19:13:24.193504804Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:24.245924346Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:24.246690471Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCC, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x39, ZCLCommandId: 0x02 >, GenericBody: 00 1F 78 02 00 04 00 00 03 E8 > >
2026-08-20T19:13:24.276493429Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:24.280086929Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“humidityVZero”,“capability_id”:“concertmirror08464.dts1xm9HumidityV0”,“component_id”:“main”,“state”:{“unit”:“%”,“value”:10.0}}
2026-08-20T19:13:24.306690971Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:24.596057596Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:24.597032721Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x3A, ZCLCommandId: 0x02 >, GenericBody: 00 20 79 02 00 04 00 00 23 28 > >
2026-08-20T19:13:24.608030096Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:24.625695512Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“humidityVOne”,“capability_id”:“concertmirror08464.dts1xm9HumidityV1”,“component_id”:“main”,“state”:{“unit”:“%”,“value”:90.0}}
2026-08-20T19:13:24.664702846Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:24.699276221Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:24.711265762Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -67, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x3B, ZCLCommandId: 0x02 >, GenericBody: 00 21 7A 04 00 01 00 > >
2026-08-20T19:13:24.718092221Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:24.725639012Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“humidityWarning”,“capability_id”:“concertmirror08464.dts1xm9HumidityWarning”,“component_id”:“main”,“state”:{“value”:“none”}}
2026-08-20T19:13:24.747001637Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:24.885504471Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:24.902829387Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCE, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x3C, ZCLCommandId: 0x02 >, GenericBody: 00 22 7C 02 00 04 00 00 00 00 > >
2026-08-20T19:13:24.907666762Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:24.912246429Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“tds”,“capability_id”:“concertmirror08464.dts1xm9Tds”,“component_id”:“main”,“state”:{“unit”:“ppm”,“value”:0}}
2026-08-20T19:13:24.926271637Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:25.038292429Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:25.046107554Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCA, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x3D, ZCLCommandId: 0x02 >, GenericBody: 00 23 7D 02 00 04 00 00 19 64 > >
2026-08-20T19:13:25.052646846Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:25.057858262Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“tdsWarningSet”,“capability_id”:“concertmirror08464.dts1xm9TdsThreshold”,“component_id”:“main”,“state”:{“unit”:“ppm”,“value”:6500}}
2026-08-20T19:13:25.067888679Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:25.247227346Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:25.264287137Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC6, rssi: -67, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x3E, ZCLCommandId: 0x02 >, GenericBody: 00 24 7E 04 00 01 00 > >
2026-08-20T19:13:25.268103054Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:25.271363471Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“tdsWarning”,“capability_id”:“concertmirror08464.dts1xm9TdsWarning”,“component_id”:“main”,“state”:{“value”:“none”}}
2026-08-20T19:13:25.280227971Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:25.466030679Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:25.469067804Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xD0, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x3F, ZCLCommandId: 0x02 >, GenericBody: 00 25 7F 02 00 04 00 00 00 00 > >
2026-08-20T19:13:25.473592929Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:25.477241929Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“ec”,“capability_id”:“concertmirror08464.dts1xm9Ec”,“component_id”:“main”,“state”:{“unit”:“μS/cm”,“value”:0}}
2026-08-20T19:13:25.486444054Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:25.685793512Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:25.686755262Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xD0, rssi: -67, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x40, ZCLCommandId: 0x02 >, GenericBody: 00 26 80 02 00 04 00 00 27 10 > >
2026-08-20T19:13:25.688013096Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:25.688714387Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“ecVZero”,“capability_id”:“concertmirror08464.dts1xm9EcV0”,“component_id”:“main”,“state”:{“unit”:“μS/cm”,“value”:10000}}
2026-08-20T19:13:25.704911762Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:25.946918596Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:25.972641637Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC8, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x41, ZCLCommandId: 0x02 >, GenericBody: 00 27 81 02 00 04 00 00 27 10 > >
2026-08-20T19:13:25.991401887Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:25.994969679Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“ecVOne”,“capability_id”:“concertmirror08464.dts1xm9EcV1”,“component_id”:“main”,“state”:{“unit”:“μS/cm”,“value”:10000}}
2026-08-20T19:13:26.021259054Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:26.087341012Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:26.092849012Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCA, rssi: -68, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x42, ZCLCommandId: 0x02 >, GenericBody: 00 28 82 04 00 01 01 > >
2026-08-20T19:13:26.096885721Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:26.100165346Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“ecWarning”,“capability_id”:“concertmirror08464.dts1xm9EcWarning”,“component_id”:“main”,“state”:{“value”:“low”}}
2026-08-20T19:13:26.152807387Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:26.319429429Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:26.331359304Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC8, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x43, ZCLCommandId: 0x02 >, GenericBody: 00 29 83 02 00 04 00 00 00 00 > >
2026-08-20T19:13:26.335069262Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:26.352390429Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“salinity”,“capability_id”:“concertmirror08464.dts1xm9Salinity”,“component_id”:“main”,“state”:{“unit”:“‰”,“value”:0.1}}
2026-08-20T19:13:26.365146054Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:26.497236721Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:26.503873971Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC2, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x44, ZCLCommandId: 0x02 >, GenericBody: 00 2A 84 02 00 04 00 00 03 E8 > >
2026-08-20T19:13:26.505133429Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:26.508581179Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:26.764086471Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:26.776558804Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xCC, rssi: -68, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x45, ZCLCommandId: 0x02 >, GenericBody: 00 2B 85 01 00 01 00 > >
2026-08-20T19:13:26.805103429Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:26.819441554Z WARN EF00 Sensors wonjj6768 Tuya lookup_from_to missing value: false
2026-08-20T19:13:26.821890804Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:31.511988346Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:31.513862305Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC5CF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xBA, rssi: -83, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xDC, ZCLCommandId: 0x25 >, GenericBody: BD 84 > >
2026-08-20T19:13:31.517727971Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:31.521224013Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC5CF, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x11, seqno: 0x00, ZCLCommandId: 0x25 >, GenericBody: BD 01 01 > >
2026-08-20T19:13:31.540502721Z DEBUG EF00 Sensors wonjj6768 ultrasonic device thread event handled
2026-08-20T19:13:39.034590472Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:39.094550972Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: f28a6d82-3bf5-40ac-80b8-53e887b1ecba [0x87B9] (linen plant)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x87B9, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xC6, rssi: -74, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xD7, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint8, ZCLVersion: 0x03 > > > >
2026-08-20T19:13:39.100872972Z DEBUG EF00 Sensors wonjj6768 linen plant device thread event handled
2026-08-20T19:13:43.046712348Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:43.047873764Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC6, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x46, ZCLCommandId: 0x02 >, GenericBody: 00 2C 65 02 00 04 00 00 02 58 > >
2026-08-20T19:13:43.078645723Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:43.085187806Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“samplingInterval”,“capability_id”:“concertmirror08464.dts1xm9SamplingInterval”,“component_id”:“main”,“state”:{“unit”:“s”,“value”:600}}
2026-08-20T19:13:43.094516973Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:43.216138473Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:43.217110098Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC8, rssi: -68, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x0D, mfg_code: 0x0001, seqno: 0x47, ZCLCommandId: 0x02 >, GenericBody: 00 2D 04 02 00 04 00 00 00 64 > >
2026-08-20T19:13:43.218318181Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:43.226668348Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:100}}
2026-08-20T19:13:43.245749556Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:43.406052139Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:43.424369764Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0xCE, rssi: -68, body_length: 0x000B, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x48, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0xC8 >, < AttributeRecord || AttributeId: 0x0020, DataType: Uint8, BatteryVoltage: 0x1E > > > >
2026-08-20T19:13:43.432384514Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:43.434152973Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
2026-08-20T19:13:43.515950098Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:43.518671014Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC5CF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, lqi: 0xC8, rssi: -79, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0xDD, ZCLCommandId: 0x25 >, GenericBody: BF 84 > >
2026-08-20T19:13:43.527080223Z DEBUG EF00 Sensors wonjj6768 Found ZigbeeMessageDispatcher handler in tuya-universal
2026-08-20T19:13:43.543346931Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: cd1770e6-bd74-4663-a8d3-9e015396d790 [0xC5CF] (ultrasonic)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC5CF, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xEF00 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x11, seqno: 0x00, ZCLCommandId: 0x25 >, GenericBody: BF 01 01 > >
2026-08-20T19:13:43.560445098Z DEBUG EF00 Sensors wonjj6768 ultrasonic device thread event handled
2026-08-20T19:13:43.628525181Z DEBUG EF00 Sensors wonjj6768 Received event with handler zigbee
2026-08-20T19:13:43.661353973Z INFO EF00 Sensors wonjj6768 <ZigbeeDevice: 7b1f1d21-44fa-4b74-845d-fce464bd6bca [0xBF37] (TDS meter)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBF37, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xCC, rssi: -68, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x49, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1930 >, < AttributeRecord || AttributeId: 0xFEFE, DataType: Int16, Int16: 134 > > > >
2026-08-20T19:13:43.670804973Z DEBUG EF00 Sensors wonjj6768 TDS meter device thread event handled
Thanks, @wonjj6768 !
Posted an issue on GH with the outdoor IP54 rated switch not appearing as two devices in Amazon Echo. Timers also don’t appear to work from Smartthings on secondary switch.
Model TS011F
