Thank very much for the help! It works perfectly. I will keep testing the DP and will update in the model file directly.
KR,
Yufan
KR,
Yufan
Withdrawing and deleting my previous message. All resolved. No issues.
Thank you @w35l3y for all the great work you are doing here.
I’m using these drivers for a tuya temperature sensor with a probe. I have the probe in my freezer. The screen shows the accurate temp of -22 degrees Celsius, but the app reports 32 degrees fahrenheit. Is there a way to report temperatures below freezing or is this a device limitation?
Hi @w35l3y , I have just bought new Tuya 24G presence detector. Gets picked up as Generic EF00 Device. When I change to Presence Sensor profile, the illumination works fine. Not picking up the presence DP, which seems to be 9? Not sure why it’s a variable integer. If I set the presence DP to 9 manually, it seems to work OK.
Are you able to add this config to the Presence Sensor profile?
That is a good question.
Teorically, the raw data is supposed to be unsigned.
So it wouldn’t be possible to report negative values.
Change the profile to generic and send a screenshot showing the datapoints listed.
Datapoint 1
Which profile did you choose exactly ?
The profile “Presence sensor” doesn’t have illuminance.
Did you mean “Presence sensor > +Illuminance” ?
If so, which manufacturer did you choose ?
I actually chose Presence Sensor + Illuminance + Breaker. This model has a built-in breaker as well. I can’t see where to choose manufacturer; it seems to have disappeared from the settings options. IIRC, I chose auto.
With DP for Presence Sensor set to 9, everything appears to be working perfectly.
24G with Relay option from here ZigBee Human Presence Sensor 110V/220V MmWave 5.8G 24G Radar Detector Illuminance Lux Detection Tuya/Smart Life Home Automation - AliExpress
Nice.
It seems to be a signed number.
I will confirm later and fix it.
Thanks.
@w35l3y can you add option in settings to stop loging the lux measurements on mmwave presence sensors?
Hi
Bought presence sensor for some time ago on AliExpress. Working perfect with your driver.
Bought some more, but now the type number is changed and cannot be selected in your driver.
Can you add the actual type number?
Hi,
Thanks so much for your effort here,
Bought a cheap amazon presence sensor / sensor but works fine, no reading on the luminescence,
Anyone got any suggestions?
Cheers!
Try going into the settings for the device, go to profile and select '+ illumination"
Could you elaborate your request a little more ?
I didn’t understand very well.
Do you mean the logs from history view in the app ?
I need to see the Debug block.
Is the device working even without the option you mentioned ?
Yes, the logs from history view
For me it’s nice to see presence sensing, but lux readings are very frequent and flooding the history.
Is it possible to log lux only … Every x minutes + when presence triggered?
Tnx in advance
Dusan
Yes, the device is actually working now, so you don’t need to add the new type number
Hi,
I have a Tuya/Moes 2-gang wall switch (TS0601, _TZE200_g1ib5ldv). This works with your generic driver (do you know why there are profiles for 1 gang and 3 gang switches, but not 2 gang?)
There is a backlight on each switch that indicates current state. This worked fine with the old @ygerlovin DTH that I used to use ( [OBSOLETE] Moes 2 and 3 gang Zigbee wall switch ( cluster EF00) - Devices & Integrations - SmartThings Community) but I can’t find an Edge driver that supports this. Is there any way this can be added to the driver?
Because no one had asked to add any device with 2 gang until now.
I will add it some time during this week.
Just take some screenshots of detail view and settings.
Hi everyone, @w35l3y could you check why this temperature sensor doesn’t show humidity values with your driver? I post in pictures data points values and fingerprint.
