[ST Edge] ONVIF-compliant IP Camera Motion Detection & Video Streaming - Testers Wanted!
I think I have found the problem. ONVIF Non-Discoverable.
I just have to figure out how to fix it. After changing to Discoverable and applying, it goes back to Non-Discoverable. Probably I have to make some other changes in settings
That’s interesting - but if it was β€˜non-discoverable’, then how did ONVIF Device Manager discover it?!
All having discovery problems: I really don’t know what’s the root cause yet, but I’ve made an update to the driver to log additional output during discovery so that when one of you can get some log output, we can see (1) if the camera is responding, and (2) what data it is responding with.
I also changed some formatting of the discovery message just in case it was causing issues.
Please make sure you have this latest version before you give it another go:
Driver version 2022-05-05T23:40:28.114978
Yes, I can utilize a method like I’ve done with other drivers and have a β€˜creator’ device where you manually create your devices and use Settings to provide the IP addresses. However discovery should be what really indicates that a device is fully ONVIF compliant. The manual approach also is limited in that it can’t recover from cases where your device might not have a static IP address. It could change for whatever reason at any time, and then you wonder why it’s not working any more. By using auto discovery, IP address changes can be more elegantly handled in the background.
If ONVIF Device Manager is able to discover them, then the problem is with my driver and I need to fix it. Just need to figure out what it is…
C:\dev\edgedrivers>smartthings edge:drivers:logcat 1d68e5c3-03c0-4229-985d-14e225550049 --hub-address 192.168.1.100
connecting… connected
This is all. it just waiting
after some time it came with all of this
2022-05-06T01:00:42.784111785+00:00 TRACE ONVIF Video Camera V1 Setup driver onvifDriver with lifecycle handlers:
DeviceLifecycleDispatcher: onvifDriver
default_handlers:
removed:
init:
added:
driverSwitched:
doConfigure:
deleted:
infoChanged:
child_dispatchers:
2022-05-06T01:00:42.789395202+00:00 TRACE ONVIF Video Camera V1 Setup driver onvifDriver with Capability handlers:
CapabilityCommandDispatcher: onvifDriver
default_handlers:
partyvoice23922.refresh:
push
videoStream:
startStream
stopStream
partyvoice23922.motionevents:
setSwitch
child_dispatchers:
2022-05-06T01:00:42.792443327+00:00 DEBUG ONVIF Video Camera V1 **** ONVIF Driver V1 Start ****
2022-05-06T01:00:42.802988410+00:00 TRACE ONVIF Video Camera V1 Received event with handler environment_info
2022-05-06T01:00:42.806857368+00:00 TRACE ONVIF Video Camera V1 Received event with handler environment_info
2022-05-06T01:00:42.809991452+00:00 DEBUG ONVIF Video Camera V1 Z-Wave hub node ID environment changed.
2022-05-06T01:00:42.813895535+00:00 TRACE ONVIF Video Camera V1 Received event with handler discovery
2022-05-06T01:00:42.819541785+00:00 DEBUG ONVIF Video Camera V1 Starting discovery
2022-05-06T01:00:42.825216410+00:00 DEBUG ONVIF Video Camera V1 Making WS discovery request
2022-05-06T01:00:42.903894868+00:00 DEBUG ONVIF Video Camera V1 Discovery response from: 192.168.1.111
2022-05-06T01:00:42.919868493+00:00 WARN ONVIF Video Camera V1 No Streaming profile in discovered device
2022-05-06T01:00:42.925030368+00:00 DEBUG ONVIF Video Camera V1 Discovery response from: 192.168.1.110
2022-05-06T01:00:42.941176660+00:00 WARN ONVIF Video Camera V1 No Streaming profile in discovered device
2022-05-06T01:01:03.349792003+00:00 DEBUG ONVIF Video Camera V1 Making WS discovery request
2022-05-06T01:01:03.406000170+00:00 DEBUG ONVIF Video Camera V1 Discovery response from: 192.168.1.111
2022-05-06T01:01:03.423182128+00:00 WARN ONVIF Video Camera V1 No Streaming profile in discovered device
2022-05-06T01:01:03.427069961+00:00 DEBUG ONVIF Video Camera V1 Discovery response from: 192.168.1.110
2022-05-06T01:01:03.443204795+00:00 WARN ONVIF Video Camera V1 No Streaming profile in discovered device
2022-05-06T01:01:15.946276842+00:00 TRACE ONVIF Video Camera V1 Received event with handler discovery
2022-05-06T01:01:15.969851509+00:00 TRACE ONVIF Video Camera V1 Received event with handler driver_lifecycle
You can see both ONVIF cameras above
I was thinking if I can add this manually, than we can see CLI logs
No luck with TP-Link Tapo C-100. It should support ONVIF. Edge driver shows completely different ip
than camera app itself.
main component
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ Capability β”‚ Attribute β”‚ Value β”‚
β”œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€
β”‚ videoStream β”‚ stream β”‚ β”‚
β”‚ partyvoice23922.motionevents β”‚ switch β”‚ β€œOff” β”‚
β”‚ motionSensor β”‚ motion β”‚ β€œinactive” β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
info component
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€
β”‚ partyvoice23922.onvifstatus β”‚ status β”‚ β€œNot responding” β”‚
β”‚ partyvoice23922.onvifinfo β”‚ info β”‚ β€œ\n\n\n\ntable, td {\n border: 1px solid black;\n border-collapse: collapse;\n font-size: 11px;\n padding: 3px;\n}\n\n\n\n\n\n\n\n\n\n\n
IP addr: 192.168.0.xxx
Hardware: MODEL
Profile: Streaming
uuid:3fa1fe68-b915-4053-a3e1-28ee524da829
\n\n\n” β”‚
This is what CLI shows
Very helpful, thank you! The camera is not reporting the expected profile, so that’s why it’s being ignored. Did you run this with the new driver I pushed out earlier? There should be additional log messages showing the discovery data for the responding devices. Once I see this, I can probably fix the issue. I have to believe your cameras support the streaming profile, as it’s the most basic one. It could be something as simple as the camera calling it something different in the data it is sending.
Hi - Can you please confirm that you have the latest driver installed? It should show as version 2022-05-05T23:40:28.114978.
Then can you please start logging with the CLI with this command?
You will be prompted to provide the IP address of your hub, and select the ONVIF Video Camera driver.
Then using the mobile app, do a device discovery. Capture that sequence in the log output and post back here, surrounding the logging data with ``` (three back-slashes) at the beginning and at the end of the logging data.
Thank you.
EDIT: Before you do the device discovery, delete whatever device you might have already had created. This will ensure a complete re-discovery process.
FYI, for those of you with the CLI, you don’t have to wait for new drivers to get pushed out to your hub. You can get the updates installed immediately with this command:
smartthings edge:drivers:install
You’ll be prompted to select hub, channel, and driver. Once you do this, if your logging is active in another window, you’ll see the driver restart.
I was away for couple of hours. I’ll install new driver with CLI, and try again
Did you manually change the IP address with the β€˜xxx’ for purposes of posting?
I was trying to figure out how that IP could have happened!!
Can you also just clarify what exactly happened? It looks like a camera did get found and created in SmartThings. Did the β€˜Not responding’ happen after you configured the userid & password and then hit the refresh button?
It may be you don’t have a discovery problem at all, but some other subsequent command to the camera is failing. If so, my previous instructions to capture the discovery sequence may not be needed, but rather you need to capture the log output after you press the Refresh button.
Is this the latest driver?
4 β”‚ 1d68e5c3-03c0-4229-985d-14e225550049 β”‚ ONVIF Video Camera V1 β”‚ β”‚ 2022-05-05T23:40:28.114978 β”‚ 42512f35-e905-416d-8696-479587f23fe2 β”‚ 863beb73-c3bc-6a21-10fc-0ed0a77ea3dc
Yes, that’s the latest. It should be outputting much more logging info during discovery. Just to be sure it got properly installed, trying doing it again with the CLI. Keep logging active in another window so you can monitor it to confirm the driver restarts.
Check your logging output and you should see the driver restart.
2022-05-06T04:22:41.119358894+00:00 TRACE ONVIF Video Camera V1 Setup driver onvifDriver with lifecycle handlers:
default_handlers:
added:
doConfigure:
init:
deleted:
infoChanged:
removed:
driverSwitched:
child_dispatchers:
2022-05-06T04:22:41.130208936+00:00 TRACE ONVIF Video Camera V1 Setup driver onvifDriver with Capability handlers:
default_handlers:
setSwitch
push
videoStream:
startStream
stopStream
child_dispatchers:
2022-05-06T04:22:41.133187644+00:00 DEBUG ONVIF Video Camera V1 **** ONVIF Driver V1 Start ****
2022-05-06T04:22:41.154688269+00:00 TRACE ONVIF Video Camera V1 Received event with handler environment_info
2022-05-06T04:22:41.163907394+00:00 TRACE ONVIF Video Camera V1 Received event with handler environment_info
2022-05-06T04:22:41.169596352+00:00 DEBUG ONVIF Video Camera V1 Z-Wave hub node ID environment changed.
2022-05-06T04:22:41.176303852+00:00 TRACE ONVIF Video Camera V1 Received event with handler driver_lifecycle
2022-05-06T04:22:41.185581019+00:00 TRACE ONVIF Video Camera V1 Received event with handler discovery
2022-05-06T04:22:41.201069019+00:00 DEBUG ONVIF Video Camera V1 Starting discovery
2022-05-06T04:22:41.212004061+00:00 DEBUG ONVIF Video Camera V1 Making WS discovery request
2022-05-06T04:22:41.282083602+00:00 DEBUG ONVIF Video Camera V1 Discovery response from: 192.168.1.111
2022-05-06T04:22:41.328935061+00:00 DEBUG ONVIF Video Camera V1 Envelope table: 0xfaca98
2022-05-06T04:22:41.332911144+00:00 DEBUG ONVIF Video Camera V1 Header table: 0xfad9d8
2022-05-06T04:22:41.338697311+00:00 DEBUG ONVIF Video Camera V1 AppSequence table: 0xfb23b0
2022-05-06T04:22:41.344643977+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfb2460
2022-05-06T04:22:41.350279852+00:00 DEBUG ONVIF Video Camera V1 MessageNumber 150
2022-05-06T04:22:41.360379686+00:00 DEBUG ONVIF Video Camera V1 InstanceId 1100000001
2022-05-06T04:22:41.363421186+00:00 DEBUG ONVIF Video Camera V1 ReplyTo table: 0xf64598
2022-05-06T04:22:41.366595686+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfb2288
2022-05-06T04:22:41.369800936+00:00 DEBUG ONVIF Video Camera V1 mustUnderstand true
2022-05-06T04:22:41.379860519+00:00 DEBUG ONVIF Video Camera V1 Address WS-Addressing Anonymous Role
2022-05-06T04:22:41.382921394+00:00 DEBUG ONVIF Video Camera V1 RelatesTo uuid:bd26a53c-c043-4e00-9d2e-d8469c7808ee
2022-05-06T04:22:41.386073186+00:00 DEBUG ONVIF Video Camera V1 MessageID uuid:f00b262f-653a-c64e-ba58-96cf3dc1377b
2022-05-06T04:22:41.389019852+00:00 DEBUG ONVIF Video Camera V1 To table: 0xfb24b0
2022-05-06T04:22:41.400540102+00:00 DEBUG ONVIF Video Camera V1 1 WS-Addressing Anonymous Role
2022-05-06T04:22:41.403480602+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfb24f0
2022-05-06T04:22:41.406460519+00:00 DEBUG ONVIF Video Camera V1 mustUnderstand true
2022-05-06T04:22:41.409717644+00:00 DEBUG ONVIF Video Camera V1 Action table: 0xfb22d8
2022-05-06T04:22:41.412869936+00:00 DEBUG ONVIF Video Camera V1 1 http://schemas.xmlsoap.org/ws/2005/04/discovery/ProbeMatches
2022-05-06T04:22:41.420436269+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfb2318
2022-05-06T04:22:41.423383394+00:00 DEBUG ONVIF Video Camera V1 mustUnderstand true
2022-05-06T04:22:41.430015894+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xf64160
2022-05-06T04:22:41.432942811+00:00 DEBUG ONVIF Video Camera V1 trt http://www.onvif.org/ver10/media/wsdl
2022-05-06T04:22:41.441567561+00:00 DEBUG ONVIF Video Camera V1 wsa5 WS-Addressing 1.0 Namespace
2022-05-06T04:22:41.444574894+00:00 DEBUG ONVIF Video Camera V1 tptz http://www.onvif.org/ver20/ptz/wsdl
2022-05-06T04:22:41.450388769+00:00 DEBUG ONVIF Video Camera V1 wsa http://schemas.xmlsoap.org/ws/2004/08/addressing
2022-05-06T04:22:41.455761311+00:00 DEBUG ONVIF Video Camera V1 wsnt http://docs.oasis-open.org/wsn/b-2
2022-05-06T04:22:41.461197769+00:00 DEBUG ONVIF Video Camera V1 xop http://www.w3.org/2004/08/xop/include
2022-05-06T04:22:41.466641477+00:00 DEBUG ONVIF Video Camera V1 SOAP-ENC http://www.w3.org/2003/05/soap-encoding
2022-05-06T04:22:41.472148811+00:00 DEBUG ONVIF Video Camera V1 chan http://schemas.microsoft.com/ws/2005/02/duplex
2022-05-06T04:22:41.480497103+00:00 DEBUG ONVIF Video Camera V1 wsu http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd
2022-05-06T04:22:41.485665894+00:00 DEBUG ONVIF Video Camera V1 xsd XML Schema
2022-05-06T04:22:41.490727436+00:00 DEBUG ONVIF Video Camera V1 xmime Bing
2022-05-06T04:22:41.496169394+00:00 DEBUG ONVIF Video Camera V1 SOAP-ENV http://www.w3.org/2003/05/soap-envelope
2022-05-06T04:22:41.501528061+00:00 DEBUG ONVIF Video Camera V1 xsi http://www.w3.org/2001/XMLSchema-instance
2022-05-06T04:22:41.506364561+00:00 DEBUG ONVIF Video Camera V1 wsc Web Services Secure Conversation Language (WS-SecureConversation)
2022-05-06T04:22:41.511929353+00:00 DEBUG ONVIF Video Camera V1 wsse http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd
2022-05-06T04:22:41.517285394+00:00 DEBUG ONVIF Video Camera V1 c14n Exclusive XML Canonicalization Version 1.0
2022-05-06T04:22:41.522422103+00:00 DEBUG ONVIF Video Camera V1 ds XML-Signature Syntax and Processing
2022-05-06T04:22:41.527667853+00:00 DEBUG ONVIF Video Camera V1 tdn http://www.onvif.org/ver10/network/wsdl
2022-05-06T04:22:41.533727686+00:00 DEBUG ONVIF Video Camera V1 xenc XML Encryption Syntax and Processing
2022-05-06T04:22:41.538643103+00:00 DEBUG ONVIF Video Camera V1 tt http://www.onvif.org/ver10/schema
2022-05-06T04:22:41.543934519+00:00 DEBUG ONVIF Video Camera V1 wstop http://docs.oasis-open.org/wsn/t-1
2022-05-06T04:22:41.549583853+00:00 DEBUG ONVIF Video Camera V1 tds http://www.onvif.org/ver10/device/wsdl
2022-05-06T04:22:41.554621269+00:00 DEBUG ONVIF Video Camera V1 wsdd Web Services Dynamic Discovery (WS-Discovery)
2022-05-06T04:22:41.559713394+00:00 DEBUG ONVIF Video Camera V1 wsrfbf http://docs.oasis-open.org/wsrf/bf-2
2022-05-06T04:22:41.564997811+00:00 DEBUG ONVIF Video Camera V1 Body table: 0xfad1e0
2022-05-06T04:22:41.569995394+00:00 DEBUG ONVIF Video Camera V1 ProbeMatches table: 0xfadbf8
2022-05-06T04:22:41.575144894+00:00 DEBUG ONVIF Video Camera V1 ProbeMatch table: 0xf63ea8
2022-05-06T04:22:41.579120894+00:00 DEBUG ONVIF Video Camera V1 Types tdn:NetworkVideoTransmitter
2022-05-06T04:22:41.583650603+00:00 DEBUG ONVIF Video Camera V1 XAddrs http://192.168.1.111:889/onvif/device_service
2022-05-06T04:22:41.588933894+00:00 DEBUG ONVIF Video Camera V1 Scopes onvif://www.onvif.org/type/Network_Video_Transmitter onvif://www.onvif.org/type/video_encoder onvif://www.onvif.org/type/audio_encoder onvif://www.onvif.org/hardware/IPC-model onvif://www.onvif.org/name/IPC-model onvif://www.onvif.org/type/ptz onvif://www.onvif.org/location/country/china
2022-05-06T04:22:41.594125936+00:00 DEBUG ONVIF Video Camera V1 EndpointReference table: 0xf63ef8
2022-05-06T04:22:41.599153269+00:00 DEBUG ONVIF Video Camera V1 PortType tt1
2022-05-06T04:22:41.604244228+00:00 DEBUG ONVIF Video Camera V1 Address urn:uuid:88d87a05-d7f7-7e45-b1e9-00626E6EAF76
2022-05-06T04:22:41.611871644+00:00 DEBUG ONVIF Video Camera V1 MetadataVersion 1
2022-05-06T04:22:41.617186186+00:00 WARN ONVIF Video Camera V1 No Streaming profile in discovered device
2022-05-06T04:22:41.623448061+00:00 DEBUG ONVIF Video Camera V1 Discovery response from: 192.168.1.110
2022-05-06T04:22:41.665502686+00:00 DEBUG ONVIF Video Camera V1 Envelope table: 0xfcccd0
2022-05-06T04:22:41.674023853+00:00 DEBUG ONVIF Video Camera V1 Header table: 0xfcdb08
2022-05-06T04:22:41.679760269+00:00 DEBUG ONVIF Video Camera V1 AppSequence table: 0xfd1328
2022-05-06T04:22:41.685228228+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfd13d8
2022-05-06T04:22:41.691510228+00:00 DEBUG ONVIF Video Camera V1 MessageNumber 110
2022-05-06T04:22:41.696834478+00:00 DEBUG ONVIF Video Camera V1 InstanceId 1100000001
2022-05-06T04:22:41.702384353+00:00 DEBUG ONVIF Video Camera V1 ReplyTo table: 0xfd11f8
2022-05-06T04:22:41.707949353+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfd1270
2022-05-06T04:22:41.713014228+00:00 DEBUG ONVIF Video Camera V1 mustUnderstand true
2022-05-06T04:22:41.718152228+00:00 DEBUG ONVIF Video Camera V1 Address WS-Addressing Anonymous Role
2022-05-06T04:22:41.723199894+00:00 DEBUG ONVIF Video Camera V1 RelatesTo uuid:bd26a53c-c043-4e00-9d2e-d8469c7808ee
2022-05-06T04:22:41.728287519+00:00 DEBUG ONVIF Video Camera V1 MessageID uuid:15c5d538-a9d1-344-8999-57420b9feca
2022-05-06T04:22:41.733141394+00:00 DEBUG ONVIF Video Camera V1 To table: 0xfd1428
2022-05-06T04:22:41.738749561+00:00 DEBUG ONVIF Video Camera V1 1 WS-Addressing Anonymous Role
2022-05-06T04:22:41.743826019+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfd1468
2022-05-06T04:22:41.748896186+00:00 DEBUG ONVIF Video Camera V1 mustUnderstand true
2022-05-06T04:22:41.753989603+00:00 DEBUG ONVIF Video Camera V1 Action table: 0xfd1298
2022-05-06T04:22:41.759118269+00:00 DEBUG ONVIF Video Camera V1 1 http://schemas.xmlsoap.org/ws/2005/04/discovery/ProbeMatches
2022-05-06T04:22:41.764173478+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfd1220
2022-05-06T04:22:41.769606269+00:00 DEBUG ONVIF Video Camera V1 mustUnderstand true
2022-05-06T04:22:41.774849561+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfd0b28
2022-05-06T04:22:41.828169019+00:00 DEBUG ONVIF Video Camera V1 trt http://www.onvif.org/ver10/media/wsdl
2022-05-06T04:22:41.833534228+00:00 DEBUG ONVIF Video Camera V1 wsa5 WS-Addressing 1.0 Namespace
2022-05-06T04:22:41.841267978+00:00 DEBUG ONVIF Video Camera V1 tptz http://www.onvif.org/ver20/ptz/wsdl
2022-05-06T04:22:41.858662519+00:00 DEBUG ONVIF Video Camera V1 wsa http://schemas.xmlsoap.org/ws/2004/08/addressing
2022-05-06T04:22:41.891299561+00:00 DEBUG ONVIF Video Camera V1 wsnt http://docs.oasis-open.org/wsn/b-2
2022-05-06T04:22:41.901021269+00:00 DEBUG ONVIF Video Camera V1 xop http://www.w3.org/2004/08/xop/include
2022-05-06T04:22:41.918398436+00:00 DEBUG ONVIF Video Camera V1 SOAP-ENC http://www.w3.org/2003/05/soap-encoding
2022-05-06T04:22:41.938125186+00:00 DEBUG ONVIF Video Camera V1 chan http://schemas.microsoft.com/ws/2005/02/duplex
2022-05-06T04:22:41.970257144+00:00 DEBUG ONVIF Video Camera V1 wsu http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd
2022-05-06T04:22:41.988424436+00:00 DEBUG ONVIF Video Camera V1 xsd XML Schema
2022-05-06T04:22:42.018774936+00:00 DEBUG ONVIF Video Camera V1 xmime Bing
2022-05-06T04:22:42.053028311+00:00 DEBUG ONVIF Video Camera V1 SOAP-ENV http://www.w3.org/2003/05/soap-envelope
2022-05-06T04:22:42.066882269+00:00 DEBUG ONVIF Video Camera V1 xsi http://www.w3.org/2001/XMLSchema-instance
2022-05-06T04:22:42.097684311+00:00 DEBUG ONVIF Video Camera V1 wsc Web Services Secure Conversation Language (WS-SecureConversation)
2022-05-06T04:22:42.115979686+00:00 DEBUG ONVIF Video Camera V1 wsse http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd
2022-05-06T04:22:42.128462061+00:00 DEBUG ONVIF Video Camera V1 c14n Exclusive XML Canonicalization Version 1.0
2022-05-06T04:22:42.135523644+00:00 DEBUG ONVIF Video Camera V1 ds XML-Signature Syntax and Processing
2022-05-06T04:22:42.145880561+00:00 DEBUG ONVIF Video Camera V1 tdn http://www.onvif.org/ver10/network/wsdl
2022-05-06T04:22:42.153902228+00:00 DEBUG ONVIF Video Camera V1 xenc XML Encryption Syntax and Processing
2022-05-06T04:22:42.170245603+00:00 DEBUG ONVIF Video Camera V1 tt http://www.onvif.org/ver10/schema
2022-05-06T04:22:42.181036020+00:00 DEBUG ONVIF Video Camera V1 wstop http://docs.oasis-open.org/wsn/t-1
2022-05-06T04:22:42.185927811+00:00 DEBUG ONVIF Video Camera V1 tds http://www.onvif.org/ver10/device/wsdl
2022-05-06T04:22:42.197390520+00:00 DEBUG ONVIF Video Camera V1 wsdd Web Services Dynamic Discovery (WS-Discovery)
2022-05-06T04:22:42.201719186+00:00 DEBUG ONVIF Video Camera V1 wsrfbf http://docs.oasis-open.org/wsrf/bf-2
2022-05-06T04:22:42.208982520+00:00 DEBUG ONVIF Video Camera V1 Body table: 0xfcd408
2022-05-06T04:22:42.214230186+00:00 DEBUG ONVIF Video Camera V1 ProbeMatches table: 0xfcdcf8
2022-05-06T04:22:42.221330020+00:00 DEBUG ONVIF Video Camera V1 ProbeMatch table: 0xfd09e0
2022-05-06T04:22:42.231249228+00:00 DEBUG ONVIF Video Camera V1 Types tdn:NetworkVideoTransmitter
2022-05-06T04:22:42.236096145+00:00 DEBUG ONVIF Video Camera V1 XAddrs http://192.168.1.110:888/onvif/device_service
2022-05-06T04:22:42.249217186+00:00 DEBUG ONVIF Video Camera V1 Scopes onvif://www.onvif.org/type/Network_Video_Transmitter onvif://www.onvif.org/type/video_encoder onvif://www.onvif.org/type/audio_encoder onvif://www.onvif.org/hardware/IPC-model onvif://www.onvif.org/name/IPC-model onvif://www.onvif.org/type/ptz onvif://www.onvif.org/location/country/china
2022-05-06T04:22:42.256502311+00:00 DEBUG ONVIF Video Camera V1 EndpointReference table: 0xfd0a30
2022-05-06T04:22:42.266172061+00:00 DEBUG ONVIF Video Camera V1 PortType tt1
2022-05-06T04:22:42.278107978+00:00 DEBUG ONVIF Video Camera V1 Address urn:uuid:88d87a05-d7f7-7e45-b1e9-00626E82AFCD
2022-05-06T04:22:42.283225895+00:00 DEBUG ONVIF Video Camera V1 MetadataVersion 1
2022-05-06T04:22:42.298762895+00:00 WARN ONVIF Video Camera V1 No Streaming profile in discovered device
2022-05-06T04:23:01.748117112+00:00 DEBUG ONVIF Video Camera V1 Making WS discovery request
2022-05-06T04:23:01.811382237+00:00 DEBUG ONVIF Video Camera V1 Discovery response from: 192.168.1.111
2022-05-06T04:23:01.847689696+00:00 DEBUG ONVIF Video Camera V1 Envelope table: 0xf48ab0
2022-05-06T04:23:01.945720404+00:00 DEBUG ONVIF Video Camera V1 Header table: 0xfe6038
2022-05-06T04:23:01.953515196+00:00 DEBUG ONVIF Video Camera V1 AppSequence table: 0xfd2df0
2022-05-06T04:23:02.071596612+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfd2ea0
2022-05-06T04:23:02.086020612+00:00 DEBUG ONVIF Video Camera V1 MessageNumber 151
2022-05-06T04:23:02.138120279+00:00 DEBUG ONVIF Video Camera V1 InstanceId 1100000001
2022-05-06T04:23:02.147825154+00:00 DEBUG ONVIF Video Camera V1 ReplyTo table: 0xfd87b8
2022-05-06T04:23:02.162067112+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfd8830
2022-05-06T04:23:02.180074862+00:00 DEBUG ONVIF Video Camera V1 mustUnderstand true
2022-05-06T04:23:02.196974404+00:00 DEBUG ONVIF Video Camera V1 Address WS-Addressing Anonymous Role
2022-05-06T04:23:02.203488237+00:00 DEBUG ONVIF Video Camera V1 RelatesTo uuid:bd26a53c-c043-4e00-9d2e-d8469c7808ee
2022-05-06T04:23:02.208646071+00:00 DEBUG ONVIF Video Camera V1 MessageID uuid:ec66408c-8d94-7f4a-9781-77858e8e4536
2022-05-06T04:23:02.227677821+00:00 DEBUG ONVIF Video Camera V1 To table: 0xfd2ef0
2022-05-06T04:23:02.230759529+00:00 DEBUG ONVIF Video Camera V1 1 WS-Addressing Anonymous Role
2022-05-06T04:23:02.233730946+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfd2f18
2022-05-06T04:23:02.249087862+00:00 DEBUG ONVIF Video Camera V1 mustUnderstand true
2022-05-06T04:23:02.254135862+00:00 DEBUG ONVIF Video Camera V1 Action table: 0xfd2d78
2022-05-06T04:23:02.259118779+00:00 DEBUG ONVIF Video Camera V1 1 http://schemas.xmlsoap.org/ws/2005/04/discovery/ProbeMatches
2022-05-06T04:23:02.267832029+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfd87e0
2022-05-06T04:23:02.279573487+00:00 DEBUG ONVIF Video Camera V1 mustUnderstand true
2022-05-06T04:23:02.282679029+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xfbf958
2022-05-06T04:23:02.286566321+00:00 DEBUG ONVIF Video Camera V1 trt http://www.onvif.org/ver10/media/wsdl
2022-05-06T04:23:02.295547029+00:00 DEBUG ONVIF Video Camera V1 wsa5 WS-Addressing 1.0 Namespace
2022-05-06T04:23:02.303824112+00:00 DEBUG ONVIF Video Camera V1 tptz http://www.onvif.org/ver20/ptz/wsdl
2022-05-06T04:23:02.317886862+00:00 DEBUG ONVIF Video Camera V1 wsa http://schemas.xmlsoap.org/ws/2004/08/addressing
2022-05-06T04:23:02.320864737+00:00 DEBUG ONVIF Video Camera V1 wsnt http://docs.oasis-open.org/wsn/b-2
2022-05-06T04:23:02.330166696+00:00 DEBUG ONVIF Video Camera V1 xop http://www.w3.org/2004/08/xop/include
2022-05-06T04:23:02.338823321+00:00 DEBUG ONVIF Video Camera V1 SOAP-ENC http://www.w3.org/2003/05/soap-encoding
2022-05-06T04:23:02.348987362+00:00 DEBUG ONVIF Video Camera V1 chan http://schemas.microsoft.com/ws/2005/02/duplex
2022-05-06T04:23:02.359232571+00:00 DEBUG ONVIF Video Camera V1 wsu http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd
2022-05-06T04:23:02.366262404+00:00 DEBUG ONVIF Video Camera V1 xsd XML Schema
2022-05-06T04:23:02.371514821+00:00 DEBUG ONVIF Video Camera V1 xmime Bing
2022-05-06T04:23:02.383229362+00:00 DEBUG ONVIF Video Camera V1 SOAP-ENV http://www.w3.org/2003/05/soap-envelope
2022-05-06T04:23:02.386290404+00:00 DEBUG ONVIF Video Camera V1 xsi http://www.w3.org/2001/XMLSchema-instance
2022-05-06T04:23:02.397833779+00:00 DEBUG ONVIF Video Camera V1 wsc Web Services Secure Conversation Language (WS-SecureConversation)
2022-05-06T04:23:02.400896946+00:00 DEBUG ONVIF Video Camera V1 wsse http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd
2022-05-06T04:23:02.403846071+00:00 DEBUG ONVIF Video Camera V1 c14n Exclusive XML Canonicalization Version 1.0
2022-05-06T04:23:02.406758862+00:00 DEBUG ONVIF Video Camera V1 ds XML-Signature Syntax and Processing
2022-05-06T04:23:02.409921696+00:00 DEBUG ONVIF Video Camera V1 tdn http://www.onvif.org/ver10/network/wsdl
2022-05-06T04:23:02.417760196+00:00 DEBUG ONVIF Video Camera V1 xenc XML Encryption Syntax and Processing
2022-05-06T04:23:02.420727612+00:00 DEBUG ONVIF Video Camera V1 tt http://www.onvif.org/ver10/schema
2022-05-06T04:23:02.423879404+00:00 DEBUG ONVIF Video Camera V1 wstop http://docs.oasis-open.org/wsn/t-1
2022-05-06T04:23:02.438122779+00:00 DEBUG ONVIF Video Camera V1 tds http://www.onvif.org/ver10/device/wsdl
2022-05-06T04:23:02.441057946+00:00 DEBUG ONVIF Video Camera V1 wsdd Web Services Dynamic Discovery (WS-Discovery)
2022-05-06T04:23:02.444085404+00:00 DEBUG ONVIF Video Camera V1 wsrfbf http://docs.oasis-open.org/wsrf/bf-2
2022-05-06T04:23:02.447221196+00:00 DEBUG ONVIF Video Camera V1 Body table: 0xf740c0
2022-05-06T04:23:02.450337779+00:00 DEBUG ONVIF Video Camera V1 ProbeMatches table: 0xfdfe18
2022-05-06T04:23:02.453440904+00:00 DEBUG ONVIF Video Camera V1 ProbeMatch table: 0xfdb7e0
2022-05-06T04:23:02.456544738+00:00 DEBUG ONVIF Video Camera V1 Types tdn:NetworkVideoTransmitter
2022-05-06T04:23:02.463348363+00:00 DEBUG ONVIF Video Camera V1 XAddrs http://192.168.1.111:889/onvif/device_service
2022-05-06T04:23:02.466365279+00:00 DEBUG ONVIF Video Camera V1 Scopes onvif://www.onvif.org/type/Network_Video_Transmitter onvif://www.onvif.org/type/video_encoder onvif://www.onvif.org/type/audio_encoder onvif://www.onvif.org/hardware/IPC-model onvif://www.onvif.org/name/IPC-model onvif://www.onvif.org/type/ptz onvif://www.onvif.org/location/country/china
2022-05-06T04:23:02.471480613+00:00 DEBUG ONVIF Video Camera V1 EndpointReference table: 0xfdb830
2022-05-06T04:23:02.474444821+00:00 DEBUG ONVIF Video Camera V1 PortType tt1
2022-05-06T04:23:02.477508488+00:00 DEBUG ONVIF Video Camera V1 Address urn:uuid:88d87a05-d7f7-7e45-b1e9-00626E6EAF76
2022-05-06T04:23:02.480417404+00:00 DEBUG ONVIF Video Camera V1 MetadataVersion 1
2022-05-06T04:23:02.483628904+00:00 WARN ONVIF Video Camera V1 No Streaming profile in discovered device
2022-05-06T04:23:02.487630113+00:00 DEBUG ONVIF Video Camera V1 Discovery response from: 192.168.1.110
2022-05-06T04:23:02.513428821+00:00 DEBUG ONVIF Video Camera V1 Envelope table: 0xfac740
2022-05-06T04:23:02.516389946+00:00 DEBUG ONVIF Video Camera V1 Header table: 0xfad530
2022-05-06T04:23:02.519527238+00:00 DEBUG ONVIF Video Camera V1 AppSequence table: 0xf92bb8
2022-05-06T04:23:02.522471863+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xf92c68
2022-05-06T04:23:02.525331613+00:00 DEBUG ONVIF Video Camera V1 MessageNumber 111
2022-05-06T04:23:02.534916404+00:00 DEBUG ONVIF Video Camera V1 InstanceId 1100000001
2022-05-06T04:23:02.538046488+00:00 DEBUG ONVIF Video Camera V1 ReplyTo table: 0xf92a88
2022-05-06T04:23:02.541017113+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xf92b00
2022-05-06T04:23:02.543893279+00:00 DEBUG ONVIF Video Camera V1 mustUnderstand true
2022-05-06T04:23:02.546742696+00:00 DEBUG ONVIF Video Camera V1 Address WS-Addressing Anonymous Role
2022-05-06T04:23:02.549778029+00:00 DEBUG ONVIF Video Camera V1 RelatesTo uuid:bd26a53c-c043-4e00-9d2e-d8469c7808ee
2022-05-06T04:23:02.552631071+00:00 DEBUG ONVIF Video Camera V1 MessageID uuid:eb535738-a62d-1340-8fbc-aaf76c5ce04b
2022-05-06T04:23:02.555669654+00:00 DEBUG ONVIF Video Camera V1 To table: 0xf92cb8
2022-05-06T04:23:02.558674529+00:00 DEBUG ONVIF Video Camera V1 1 WS-Addressing Anonymous Role
2022-05-06T04:23:02.569534321+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xf92cf8
2022-05-06T04:23:02.572432404+00:00 DEBUG ONVIF Video Camera V1 mustUnderstand true
2022-05-06T04:23:02.575393696+00:00 DEBUG ONVIF Video Camera V1 Action table: 0xf92b28
2022-05-06T04:23:02.585066863+00:00 DEBUG ONVIF Video Camera V1 1 http://schemas.xmlsoap.org/ws/2005/04/discovery/ProbeMatches
2022-05-06T04:23:02.588538029+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xf92ab0
2022-05-06T04:23:02.591645113+00:00 DEBUG ONVIF Video Camera V1 mustUnderstand true
2022-05-06T04:23:02.596459654+00:00 DEBUG ONVIF Video Camera V1 _attr table: 0xf923b8
2022-05-06T04:23:02.611552238+00:00 DEBUG ONVIF Video Camera V1 trt http://www.onvif.org/ver10/media/wsdl
2022-05-06T04:23:02.619316404+00:00 DEBUG ONVIF Video Camera V1 wsa5 WS-Addressing 1.0 Namespace
2022-05-06T04:23:02.628919404+00:00 DEBUG ONVIF Video Camera V1 tptz http://www.onvif.org/ver20/ptz/wsdl
2022-05-06T04:23:02.632094654+00:00 DEBUG ONVIF Video Camera V1 wsa http://schemas.xmlsoap.org/ws/2004/08/addressing
2022-05-06T04:23:02.635050238+00:00 DEBUG ONVIF Video Camera V1 wsnt http://docs.oasis-open.org/wsn/b-2
2022-05-06T04:23:02.644491154+00:00 DEBUG ONVIF Video Camera V1 xop http://www.w3.org/2004/08/xop/include
2022-05-06T04:23:02.647572488+00:00 DEBUG ONVIF Video Camera V1 SOAP-ENC http://www.w3.org/2003/05/soap-encoding
2022-05-06T04:23:02.650570779+00:00 DEBUG ONVIF Video Camera V1 chan http://schemas.microsoft.com/ws/2005/02/duplex
2022-05-06T04:23:02.653523571+00:00 DEBUG ONVIF Video Camera V1 wsu http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd
2022-05-06T04:23:02.656525238+00:00 DEBUG ONVIF Video Camera V1 xsd XML Schema
2022-05-06T04:23:02.659574029+00:00 DEBUG ONVIF Video Camera V1 xmime Bing
2022-05-06T04:23:02.662611238+00:00 DEBUG ONVIF Video Camera V1 SOAP-ENV http://www.w3.org/2003/05/soap-envelope
2022-05-06T04:23:02.665465654+00:00 DEBUG ONVIF Video Camera V1 xsi http://www.w3.org/2001/XMLSchema-instance
2022-05-06T04:23:02.668609529+00:00 DEBUG ONVIF Video Camera V1 wsc Web Services Secure Conversation Language (WS-SecureConversation)
2022-05-06T04:23:02.671555321+00:00 DEBUG ONVIF Video Camera V1 wsse http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd
2022-05-06T04:23:02.674418446+00:00 DEBUG ONVIF Video Camera V1 c14n Exclusive XML Canonicalization Version 1.0
2022-05-06T04:23:02.677328196+00:00 DEBUG ONVIF Video Camera V1 ds XML-Signature Syntax and Processing
2022-05-06T04:23:02.680620988+00:00 DEBUG ONVIF Video Camera V1 tdn http://www.onvif.org/ver10/network/wsdl
2022-05-06T04:23:02.683531404+00:00 DEBUG ONVIF Video Camera V1 xenc XML Encryption Syntax and Processing
2022-05-06T04:23:02.686426363+00:00 DEBUG ONVIF Video Camera V1 tt http://www.onvif.org/ver10/schema
2022-05-06T04:23:02.689513779+00:00 DEBUG ONVIF Video Camera V1 wstop http://docs.oasis-open.org/wsn/t-1
2022-05-06T04:23:02.692467738+00:00 DEBUG ONVIF Video Camera V1 tds http://www.onvif.org/ver10/device/wsdl
2022-05-06T04:23:02.695491363+00:00 DEBUG ONVIF Video Camera V1 wsdd Web Services Dynamic Discovery (WS-Discovery)
2022-05-06T04:23:02.698573238+00:00 DEBUG ONVIF Video Camera V1 wsrfbf http://docs.oasis-open.org/wsrf/bf-2
2022-05-06T04:23:02.701843446+00:00 DEBUG ONVIF Video Camera V1 Body table: 0xface48
2022-05-06T04:23:02.704936029+00:00 DEBUG ONVIF Video Camera V1 ProbeMatches table: 0xfad720
2022-05-06T04:23:02.708065863+00:00 DEBUG ONVIF Video Camera V1 ProbeMatch table: 0xf92270
2022-05-06T04:23:02.711051488+00:00 DEBUG ONVIF Video Camera V1 Types tdn:NetworkVideoTransmitter
2022-05-06T04:23:02.713946988+00:00 DEBUG ONVIF Video Camera V1 XAddrs http://192.168.1.110:888/onvif/device_service
2022-05-06T04:23:02.716938779+00:00 DEBUG ONVIF Video Camera V1 Scopes onvif://www.onvif.org/type/Network_Video_Transmitter onvif://www.onvif.org/type/video_encoder onvif://www.onvif.org/type/audio_encoder onvif://www.onvif.org/hardware/IPC-model onvif://www.onvif.org/name/IPC-model onvif://www.onvif.org/type/ptz onvif://www.onvif.org/location/country/china
2022-05-06T04:23:02.720052654+00:00 DEBUG ONVIF Video Camera V1 EndpointReference table: 0xf922c0
2022-05-06T04:23:02.723015238+00:00 DEBUG ONVIF Video Camera V1 PortType tt1
2022-05-06T04:23:02.725900029+00:00 DEBUG ONVIF Video Camera V1 Address urn:uuid:88d87a05-d7f7-7e45-b1e9-00626E82AFCD
2022-05-06T04:23:02.728871404+00:00 DEBUG ONVIF Video Camera V1 MetadataVersion 1
2022-05-06T04:23:02.732202779+00:00 WARN ONVIF Video Camera V1 No Streaming profile in discovered device
2022-05-06T04:23:13.108309909+00:00 TRACE ONVIF Video Camera V1 Received event with handler discovery
2022-05-06T04:23:13.219883409+00:00 TRACE ONVIF Video Camera V1 Received event with handler driver_lifecycle
I got this just from installing new driver. How can I restart the driver?
Perfect! I can confirm what the problem is now. The camera is indeed not providing its supported profiles, so that’s why things are not working.
So in order to get this to work with not-so-conformant cameras, I guess I’ll have to remove the check in my code and just assume that the Streaming profile is supported. If it’s not errors will happen during the initialization sequence. Give me a few minutes and I’ll push out a new driver with the check removed for now, to see if your discovery process proceeds.
I know that my cameras have two streams each, 1080p and 720p
Thanks for the previous log; I’ve updated the driver and pushed it out:
Driver version 2022-05-06T04:40:52.429177
You can install this right away by using the CLI command:
I’m hopeful your devices will now be discovered OK and then we’ll have to see what the next issue is :-).
