[ST Edge/Beta] Zigbee dimmer driver (supports MOES)
How do I connect this device? I installed the driver but what do I choose in SmartThings App? There is nothing like “Moe’s” or anything. I switched it on and off 10 times but nothing happens. Anyone got this working?
You need to use Scan Near-By when using Edge Drivers.
Hi @ygerlovin any chance that you give another try to 2-gang version?
Any chance to add this one?
Hi there @ygerlovin. Thanks for the support. I have the MOES zigbee 2 gang dimmer device (MS-105BZ). How can I share with you the log needed?
Cheers
hi @ygerlovin
Using Moes MS-105Z Dimmer with your Edge driver for a couple of months now without issue.
Starting this week (Smartthings transition??) my Zigbee Dimmer Module shuts down the lights cca 7-10 minutes after turned on.
Looking at history within ST app it looks that the “turned” off happens imediatly after loging the RSSI data (happens to be 68-71 dBi).
Can you help ?
Within these few months my other zigbee devices are at the same locations, even there are more of them so i don’t think it’s the signal issue.
Hi All,
Did the 2gang ever get added?
Hi @ygerlovin
i finally add your edge drivers for moes 3gang wall switch
in backlight i can’t choose something have always there a ! (exclamation mark)
and as it is backlight is always off so i can’t know if is the switch on (does not change as is always off)
any fix?
Hi, Yakov!
Would it be possible to add Edge Drivers to this Dimmer Switch?
  • application: 52
  • endpointId: 01
  • manufacturer: _TZE200_ebwgzdqq
  • model: TS0601
  • zigbeeNodeType: ROUTER
    01 0104 0051 00 05 0000 000A 0004 0005 EF00 01 0019
Larkkey Smart Zigbee Dimmer\Fan\Curtain switch
Thank you!
Hi @ygerlovin
thanks for creating this driver. I just purchased the latest version of MS-105Z from Aliexpress and it works
immediately with your driver.
Is it possible to add an action to increase/decrease the dimming% by a given amount? I would like to use a switch to trigger an increase or decrease in the brightness in steps.
I use @Mariano_Colmenarejo driver for Ikea bulbs, and this supports “Level by external steps”.
Thank you in advance
Ian
Hi,
@ygerlovin
Recently installed 2 new Moes zigbee dimmers MS-105Z. Installation and setup was perfect with this driver… also they started to work fine, but few hours later both dimmers stoped working in ST… although they were still operative when I use phisycal switch.
The problem is solved restarting the hub, but few hours later again and again…
Could you please help on this?
Thanks in advance for your contribution to this community.
See below log:
Log Zigbee Dimmer Driver 20230403
│ # │ Label │ Name │ Type │ Device Id │
│ 1 │ Dimmer1 │ Dimmer Single Gang (YG) │ ZIGBEE │ 273a449b-9e88-4a0c-8f68-2529b262a066 │
│ 2 │ Dimmer2 │ Dimmer Single Gang (YG) │ ZIGBEE │ 420f2d47-cf12-4364-8e05-2963b730cab1 │
│ 3 │ Hub Aeotec │ SmartThings v3 Hub │ HUB │ 651e4a48-6570-410c-a479-67e159b7eb93 │
│ 4 │ Luz Salón │ single-switch │ ZIGBEE │ b579bc4f-cc8a-4929-868f-783aab6a7ffe │
│ 5 │ Sensor mov 1 │ fibaro-motion-sensor │ ZWAVE │ 68da209a-b706-42b4-bb5c-01cffabaafca │
│ 6 │ Sensor mov 2 │ fibaro-motion-sensor │ ZWAVE │ fce119d4-cb5e-40fc-b482-b3a164d127aa │
│ # │ Driver Id │ Name │
│ 1 │ 9d00eaef-fd7f-4719-9af3-1392a23a0592 │ Hue Motion Sensor │
│ 2 │ fba178cd-203e-4b7c-bfa0-d4f07197b527 │ Matter Sensor │
│ 3 │ 054cf51f-0171-4d25-acd2-9dc739cce921 │ Virtual Things Edge Driver [YG] │
│ 4 │ d58d8432-ea22-4d38-8300-2bd75fdf1358 │ Z-Wave Sensor │
│ 5 │ 78da112c-9b9c-4359-b1b7-202a8a040157 │ Zigbee Button Remote Driver [YG] 1.3.8 │
│ 6 │ a89371c4-8765-404b-9de9-e9882cc48bd8 │ Zigbee Dimmer Driver [YG] │
│ 7 │ c6008edc-9630-465a-a4ea-0c6432c677fc │ Zigbee Multi Gang Switch [YG] v2.1.6 │
│ 8 │ e9bfd289-1d51-499e-8c64-d564d1868ad2 │ Zigbee Multi Switch and Child Mc │
│ 9 │ 5ab64dc7-5d08-44a4-9806-5a5b823a18d2 │ Zigbee Sensors Edge Driver [YG] 1.8.16 │
│ 10 │ bc53adfe-d18f-4ea4-9610-6aade6696b7a │ Zigbee Switch Mc │
│ 11 │ 3724840a-2b1d-4f6b-9683-e8e0155445ee │ Zigbee Thing [YG] v1.0.2 │
? Select a driver. 6
2023-04-03T22:49:02.679515033+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:49:02.683657753+00:00 DEBUG Zigbee Dimmer Driver [YG] Dimmer1 device thread event handled
2023-04-03T22:49:23.341625454+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler zigbee
2023-04-03T22:49:23.342809454+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 420f2d47-cf12-4364-8e05-2963b730cab1 [0xDA60] (Dimmer2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA60, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xC6, rssi: -83, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x31, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0001, DataType: Uint8, ApplicationVersion: 0x44 >, < AttributeRecord || AttributeId: 0xFFE2, DataType: Uint8, Uint8: 0x1F >, < AttributeRecord || AttributeId: 0xFFE4, DataType: Uint8, Uint8: 0x00 > > > >
2023-04-03T22:49:23.371644121+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:49:23.372467121+00:00 DEBUG Zigbee Dimmer Driver [YG] Dimmer2 device thread event handled
2023-04-03T22:49:31.517822121+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:50:01.636269458+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:50:31.504616462+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:51:01.518375132+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:51:31.524630469+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:51:32.698177469+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler zigbee
2023-04-03T22:51:32.699331803+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 273a449b-9e88-4a0c-8f68-2529b262a066 [0xB4A2] (Dimmer1)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB4A2, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xCC, rssi: -76, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x61, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0001, DataType: Uint8, ApplicationVersion: 0x44 >, < AttributeRecord || AttributeId: 0xFFE2, DataType: Uint8, Uint8: 0x1F >, < AttributeRecord || AttributeId: 0xFFE4, DataType: Uint8, Uint8: 0x00 > > > >
2023-04-03T22:51:32.707500136+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:51:32.708313136+00:00 DEBUG Zigbee Dimmer Driver [YG] Dimmer1 device thread event handled
2023-04-03T22:52:01.537937473+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:52:22.824675142+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler zigbee
2023-04-03T22:52:22.825864809+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 420f2d47-cf12-4364-8e05-2963b730cab1 [0xDA60] (Dimmer2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA60, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xD0, rssi: -79, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x32, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0001, DataType: Uint8, ApplicationVersion: 0x44 >, < AttributeRecord || AttributeId: 0xFFE2, DataType: Uint8, Uint8: 0x1F >, < AttributeRecord || AttributeId: 0xFFE4, DataType: Uint8, Uint8: 0x00 > > > >
2023-04-03T22:52:22.827916142+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:52:22.829128142+00:00 DEBUG Zigbee Dimmer Driver [YG] Dimmer2 device thread event handled
2023-04-03T22:52:31.547948143+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:53:01.547939593+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:53:31.557933232+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:54:01.558342913+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:54:08.198249916+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler capability
2023-04-03T22:54:08.201575249+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 273a449b-9e88-4a0c-8f68-2529b262a066 [0xB4A2] (Dimmer1)> received command: {“args”:{},“capability”:“switch”,“command”:“on”,“component”:“main”,“positional_args”:{}}
2023-04-03T22:54:08.209783249+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:08.210608916+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:08.211814582+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:08.221119582+00:00 TRACE Zigbee Dimmer Driver [YG] Found CapabilityCommandDispatcher handler in Zigbee dimmer driver → Zigbee Tuya dimmer driver
2023-04-03T22:54:08.225131916+00:00 DEBUG Zigbee Dimmer Driver [YG] HandlerSwitch Dimmer1 event={args={}, capability=“switch”, command=“on”, component=“main”, positional_args={}}
2023-04-03T22:54:08.230244582+00:00 DEBUG Zigbee Dimmer Driver [YG] MultiGangSwitch.handle_event_all() value=1 vmt={NAME=“HandlerSwitch”, component_name_to_ep=function: 0xb7fd78, ep_to_component_name=function: 0xb7fdd8, handle_command=function: 0xb6b418, handle_event=function: 0xb83f90, init=function: 0xb6f3b0, send_command=function: 0xb852f8}
2023-04-03T22:54:08.240136583+00:00 DEBUG Zigbee Dimmer Driver [YG] MultiGangSwitch: default_handler_main_component_event send to main value=1
2023-04-03T22:54:08.240982583+00:00 WARN Zigbee Dimmer Driver [YG] component_name_to_ep(): switch1->1
2023-04-03T22:54:08.242202583+00:00 ERROR Zigbee Dimmer Driver [YG] Dimmer1 thread encountered error: [string “st/dispatcher.lua”]:233: Error encountered while processing event for <ZigbeeDevice: 273a449b-9e88-4a0c-8f68-2529b262a066 [0xB4A2] (Dimmer1)>:
arg1: table: 0xb81930
[string “st/zigbee/data_types/base_defs/UintABC.lua”]:69: Uint8 too large for type
2023-04-03T22:54:08.248357583+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler capability
2023-04-03T22:54:08.249636249+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 273a449b-9e88-4a0c-8f68-2529b262a066 [0xB4A2] (Dimmer1)> received command: {“args”:{“level”:14},“capability”:“switchLevel”,“command”:“setLevel”,“component”:“main”,“positional_args”:[14]}
2023-04-03T22:54:08.258227916+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:08.259435916+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:08.260623249+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:08.278414249+00:00 TRACE Zigbee Dimmer Driver [YG] Found CapabilityCommandDispatcher handler in Zigbee dimmer driver → Zigbee Tuya dimmer driver
2023-04-03T22:54:08.279447249+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_ts0601_event_handler_set_level(): event={args={level=14}, capability=“switchLevel”, command=“setLevel”, component=“main”, positional_args={14}}
2023-04-03T22:54:08.280768583+00:00 DEBUG Zigbee Dimmer Driver [YG] HandlerDimmer Dimmer1 event={args={level=14}, capability=“switchLevel”, command=“setLevel”, component=“main”, positional_args={14}}
2023-04-03T22:54:08.282322249+00:00 DEBUG Zigbee Dimmer Driver [YG] HandlerDimmer.handle_change_level() component=main value=14
2023-04-03T22:54:08.283625916+00:00 ERROR Zigbee Dimmer Driver [YG] Dimmer1 thread encountered error: [string “st/dispatcher.lua”]:233: Error encountered while processing event for <ZigbeeDevice: 273a449b-9e88-4a0c-8f68-2529b262a066 [0xB4A2] (Dimmer1)>:
arg1: table: 0xb4ac98
2023-04-03T22:54:08.298261583+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler capability
2023-04-03T22:54:08.299473249+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 420f2d47-cf12-4364-8e05-2963b730cab1 [0xDA60] (Dimmer2)> received command: {“args”:{},“capability”:“switch”,“command”:“on”,“component”:“main”,“positional_args”:{}}
2023-04-03T22:54:08.301345583+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:08.302612583+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:08.303987583+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:08.309547583+00:00 TRACE Zigbee Dimmer Driver [YG] Found CapabilityCommandDispatcher handler in Zigbee dimmer driver → Zigbee Tuya dimmer driver
2023-04-03T22:54:08.310825249+00:00 DEBUG Zigbee Dimmer Driver [YG] HandlerSwitch Dimmer2 event={args={}, capability=“switch”, command=“on”, component=“main”, positional_args={}}
2023-04-03T22:54:08.312035583+00:00 DEBUG Zigbee Dimmer Driver [YG] MultiGangSwitch.handle_event_all() value=1 vmt={NAME=“HandlerSwitch”, component_name_to_ep=function: 0xb7fd78, ep_to_component_name=function: 0xb7fdd8, handle_command=function: 0xb6b418, handle_event=function: 0xb83f90, init=function: 0xb6f3b0, send_command=function: 0xb852f8}
2023-04-03T22:54:08.313280916+00:00 DEBUG Zigbee Dimmer Driver [YG] MultiGangSwitch: default_handler_main_component_event send to main value=1
2023-04-03T22:54:08.314628583+00:00 WARN Zigbee Dimmer Driver [YG] component_name_to_ep(): switch1->1
2023-04-03T22:54:08.315873583+00:00 ERROR Zigbee Dimmer Driver [YG] Dimmer2 thread encountered error: [string “st/dispatcher.lua”]:233: Error encountered while processing event for <ZigbeeDevice: 420f2d47-cf12-4364-8e05-2963b730cab1 [0xDA60] (Dimmer2)>:
arg1: table: 0xb91828
2023-04-03T22:54:08.323683583+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler capability
2023-04-03T22:54:08.325852583+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 420f2d47-cf12-4364-8e05-2963b730cab1 [0xDA60] (Dimmer2)> received command: {“args”:{“level”:15},“capability”:“switchLevel”,“command”:“setLevel”,“component”:“main”,“positional_args”:[15]}
2023-04-03T22:54:08.328594249+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:08.331118249+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:08.334074249+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:08.336334916+00:00 TRACE Zigbee Dimmer Driver [YG] Found CapabilityCommandDispatcher handler in Zigbee dimmer driver → Zigbee Tuya dimmer driver
2023-04-03T22:54:08.338623583+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_ts0601_event_handler_set_level(): event={args={level=15}, capability=“switchLevel”, command=“setLevel”, component=“main”, positional_args={15}}
2023-04-03T22:54:08.340825583+00:00 DEBUG Zigbee Dimmer Driver [YG] HandlerDimmer Dimmer2 event={args={level=15}, capability=“switchLevel”, command=“setLevel”, component=“main”, positional_args={15}}
2023-04-03T22:54:08.343025916+00:00 DEBUG Zigbee Dimmer Driver [YG] HandlerDimmer.handle_change_level() component=main value=15
2023-04-03T22:54:08.345353583+00:00 ERROR Zigbee Dimmer Driver [YG] Dimmer2 thread encountered error: [string “st/dispatcher.lua”]:233: Error encountered while processing event for <ZigbeeDevice: 420f2d47-cf12-4364-8e05-2963b730cab1 [0xDA60] (Dimmer2)>:
arg1: table: 0xb58640
2023-04-03T22:54:18.197269921+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler capability
2023-04-03T22:54:18.233669921+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 273a449b-9e88-4a0c-8f68-2529b262a066 [0xB4A2] (Dimmer1)> received command: {“args”:{},“capability”:“switch”,“command”:“off”,“component”:“main”,“positional_args”:{}}
2023-04-03T22:54:18.247599587+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:18.248842254+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:18.250028254+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:18.251197587+00:00 TRACE Zigbee Dimmer Driver [YG] Found CapabilityCommandDispatcher handler in Zigbee dimmer driver → Zigbee Tuya dimmer driver
2023-04-03T22:54:18.252535587+00:00 DEBUG Zigbee Dimmer Driver [YG] HandlerSwitch Dimmer1 event={args={}, capability=“switch”, command=“off”, component=“main”, positional_args={}}
2023-04-03T22:54:18.254157921+00:00 DEBUG Zigbee Dimmer Driver [YG] MultiGangSwitch.handle_event_all() value=0 vmt={NAME=“HandlerSwitch”, component_name_to_ep=function: 0xb7fd78, ep_to_component_name=function: 0xb7fdd8, handle_command=function: 0xb6b418, handle_event=function: 0xb83f90, init=function: 0xb6f3b0, send_command=function: 0xb852f8}
2023-04-03T22:54:18.255462921+00:00 DEBUG Zigbee Dimmer Driver [YG] MultiGangSwitch: default_handler_main_component_event send to main value=0
2023-04-03T22:54:18.258974921+00:00 WARN Zigbee Dimmer Driver [YG] component_name_to_ep(): switch1->1
2023-04-03T22:54:18.260256921+00:00 ERROR Zigbee Dimmer Driver [YG] Dimmer1 thread encountered error: [string “st/dispatcher.lua”]:233: Error encountered while processing event for <ZigbeeDevice: 273a449b-9e88-4a0c-8f68-2529b262a066 [0xB4A2] (Dimmer1)>:
arg1: table: 0xb8f858
2023-04-03T22:54:18.264089587+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler capability
2023-04-03T22:54:18.272467921+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 420f2d47-cf12-4364-8e05-2963b730cab1 [0xDA60] (Dimmer2)> received command: {“args”:{},“capability”:“switch”,“command”:“off”,“component”:“main”,“positional_args”:{}}
2023-04-03T22:54:18.273866921+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:18.276012587+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:18.278234254+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:18.280365921+00:00 TRACE Zigbee Dimmer Driver [YG] Found CapabilityCommandDispatcher handler in Zigbee dimmer driver → Zigbee Tuya dimmer driver
2023-04-03T22:54:18.282676921+00:00 DEBUG Zigbee Dimmer Driver [YG] HandlerSwitch Dimmer2 event={args={}, capability=“switch”, command=“off”, component=“main”, positional_args={}}
2023-04-03T22:54:18.284907254+00:00 DEBUG Zigbee Dimmer Driver [YG] MultiGangSwitch.handle_event_all() value=0 vmt={NAME=“HandlerSwitch”, component_name_to_ep=function: 0xb7fd78, ep_to_component_name=function: 0xb7fdd8, handle_command=function: 0xb6b418, handle_event=function: 0xb83f90, init=function: 0xb6f3b0, send_command=function: 0xb852f8}
2023-04-03T22:54:18.287563254+00:00 DEBUG Zigbee Dimmer Driver [YG] MultiGangSwitch: default_handler_main_component_event send to main value=0
2023-04-03T22:54:18.289707254+00:00 WARN Zigbee Dimmer Driver [YG] component_name_to_ep(): switch1->1
2023-04-03T22:54:18.291846921+00:00 ERROR Zigbee Dimmer Driver [YG] Dimmer2 thread encountered error: [string “st/dispatcher.lua”]:233: Error encountered while processing event for <ZigbeeDevice: 420f2d47-cf12-4364-8e05-2963b730cab1 [0xDA60] (Dimmer2)>:
arg1: table: 0xb1ef90
2023-04-03T22:54:24.678167590+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler zigbee
2023-04-03T22:54:24.679325590+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 273a449b-9e88-4a0c-8f68-2529b262a066 [0xB4A2] (Dimmer1)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB4A2, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xC8, rssi: -75, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x62, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0001, DataType: Uint8, ApplicationVersion: 0x44 >, < AttributeRecord || AttributeId: 0xFFE2, DataType: Uint8, Uint8: 0x1F >, < AttributeRecord || AttributeId: 0xFFE4, DataType: Uint8, Uint8: 0x00 > > > >
2023-04-03T22:54:24.688143257+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:54:24.688965924+00:00 DEBUG Zigbee Dimmer Driver [YG] Dimmer1 device thread event handled
2023-04-03T22:54:31.557065927+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:55:01.567921608+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:55:22.319532618+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler zigbee
2023-04-03T22:55:22.321147618+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 420f2d47-cf12-4364-8e05-2963b730cab1 [0xDA60] (Dimmer2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA60, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xCE, rssi: -88, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x33, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0001, DataType: Uint8, ApplicationVersion: 0x44 >, < AttributeRecord || AttributeId: 0xFFE2, DataType: Uint8, Uint8: 0x1F >, < AttributeRecord || AttributeId: 0xFFE4, DataType: Uint8, Uint8: 0x00 > > > >
2023-04-03T22:55:22.403089285+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:55:22.403928285+00:00 DEBUG Zigbee Dimmer Driver [YG] Dimmer2 device thread event handled
2023-04-03T22:55:31.577913289+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:56:01.588000637+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:56:31.597916318+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:57:01.597917490+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:57:18.288229096+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler zigbee
2023-04-03T22:57:18.289409096+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 273a449b-9e88-4a0c-8f68-2529b262a066 [0xB4A2] (Dimmer1)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB4A2, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xD0, rssi: -76, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x63, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0001, DataType: Uint8, ApplicationVersion: 0x44 >, < AttributeRecord || AttributeId: 0xFFE2, DataType: Uint8, Uint8: 0x1F >, < AttributeRecord || AttributeId: 0xFFE4, DataType: Uint8, Uint8: 0x00 > > > >
2023-04-03T22:57:18.299969762+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer1’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:57:18.300784096+00:00 DEBUG Zigbee Dimmer Driver [YG] Dimmer1 device thread event handled
2023-04-03T22:57:31.595438769+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:58:01.596091450+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:58:18.837126125+00:00 TRACE Zigbee Dimmer Driver [YG] Received event with handler zigbee
2023-04-03T22:58:18.838290458+00:00 INFO Zigbee Dimmer Driver [YG] <ZigbeeDevice: 420f2d47-cf12-4364-8e05-2963b730cab1 [0xDA60] (Dimmer2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDA60, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xC6, rssi: -80, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x34, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0001, DataType: Uint8, ApplicationVersion: 0x44 >, < AttributeRecord || AttributeId: 0xFFE2, DataType: Uint8, Uint8: 0x1F >, < AttributeRecord || AttributeId: 0xFFE4, DataType: Uint8, Uint8: 0x00 > > > >
2023-04-03T22:58:18.872831791+00:00 DEBUG Zigbee Dimmer Driver [YG] tuya_can_handle(): true ‘Dimmer2’ _TZE200_la2c2uo9/TS0601
2023-04-03T22:58:18.873650458+00:00 DEBUG Zigbee Dimmer Driver [YG] Dimmer2 device thread event handled
2023-04-03T22:58:31.605249131+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:59:01.615176478+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T22:59:31.615848826+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
2023-04-03T23:00:01.624193507+00:00 DEBUG Zigbee Dimmer Driver [YG] driver device thread event handled
listening for logs… /
For the zigbee 2 gang dimmer, would the log give u what u need to add it?
The 105BZ 2 gang zigbee dimmer, is there some log info or similar that I could send u?
Hi. Installation and working fine on ms-105z. But after a few moves, it doesn’t work in ST. Could you please help on this?
I have the same problem as you. Have you solved the problem?
Hi,
As far as I know, No solution for this issue.
My dimmers are working now as normal switches.
What a pity.
Hi, I only read the topic now, but I had already purchased a Moes 2 Gang zigbee dimmer. Has a suitable driver been developed in the meantime? Thank you
Hi, I’ve purchased two Moes 2-gang zigbee dimmers (MS-105BZ) recently. Finally manage to make them work with Smartthings.
I try to make everything step by step below.
  1. Check [ST Edge] Personal Tuya Devices - Generic EF00 Device developed by @w35l3y . Install “Personal Tuya Devices - main” driver. (Invitation link
    https://api.smartthings.com/invite/6Vjd4YPVJwjN )
  2. Connect a retractive switch to S1 and power up the dimmer according to the wiring diagram carefully.
  3. Add the Moes dimmer device to Smartthings. (Press the retractive switch connected to S1 10 times for pairing mode.)
  4. Go to the device added in Smartthings app and go to “Settings” with 3 dots in top right corner.
  5. Set the “Profile” to “Generic”.
  6. Click “OK” and return to pervious level in the app.
  7. Select the device and tap “Settings” again.
  8. Set the “Profile” to “2 dimmers” then “OK”.
  9. “OK” again to return to pervious level.
  10. Select the device and go to “Settings” again with three vertical dots.
  11. Set the followings for the Datapoints (DP).
    a. Minimum Level 1: 3
    b. Minimum Level 2: 9
    c. DP for Switch 1: 1
    d. DP for Switch Level 1: 2
    e. DP for Switch 2: 7
    f. DP for Switch Level 2: 8
  12. Try to stimulate the dimmer. (For example, cutting and reconnecting the power (be careful!!), toggling the retractive switch and so on.)
  13. The dimmer level and power status should be seen in the app in about 5 mins or shorter. Then we can control the dimmer normally.
  14. (Optional) Create child device in “Settings” menu.
Good luck my friends. :slight_smile:
You could stop at step 8.
There is only 1 device using this profile (normal-multi-dimmer-v2) and it uses the exact same datapoints as yours.
So, it is safe to say that step 11 could be 0 in all fields.
Can anyone please confirm,. What is the current state of this edge driver and ZM-105-M-MS?
Does it work? Thanks
