How to add Moes zigbee dimmer module into Smartthings
Hi, Can anyone tell me how to add a Moes zigbee dimmer as a new device in Smartthings ?
Moes smart dimmer module:
N+L
Zigbee 3.0
105B
So it has connected to Smartthings as a ‘zigbee thing’ but there are no controls presented to do anything with it.
Is there a way to get this working ?
Do I somehow need to download an edge driver from somewhere or someone ?
Did you check if the Smartthings support those Zigbee Light Dimmers?
Have you tried @Mariano_Colmenarejo 's " Zigbee Switch Mc" driver.
https://api.smartthings.com/invitation-web/accept?id=6b68563b-1905-4654-8d2b-e677a2997424
If that does not work post the finger prints (mfg. Code and model) you can find that at Samsung account
Did you get this to work?
No not working yet.
I am thinking of buying a Tuya hub and then linking that to Smartthings. But I would like to link it directly. It is the only 2 gang dimmer I am aware of and I have 17 light switches I’d like automated dimming for including 4 gang switches.
Trying to incorporate smart controls into my extension build.
Hi, i have a moes dimmer Moes MS-105Z Dimmer and is working with edge drivers.
Try this drivers:
Or
In this one you need change profile under options
Hi Pyralamo,
I have tried to use your Moes dimmer edge driver, however it gives an error ‘ensure driver has a valid fingerprint match with this device’.
I have a different model of Moes dimmer. I am using the 2 gang zigbee dimmer module MS-105BZ. It has 3L, 2S, and 1N connection and controls 2 switches.
I have also tried your Zigbee thing driver but cannot seem to load it to the device at all.
Is there some way to see your edge driver script/code ?
Sorry i can’t help.
Try install this
https://account.smartthings.com/?redirect=https%3A%2F%2Fapi.smartthings.com%2Finvite%2F6Vjd4YPVJwjN%3F
Pair your device again and make sure your device is using the driver [ST Edge] Personal Tuya Devices - Generic EF00 Device. You may need Change fisically on/off/dimmer to the driver load your datapoints. After
Go to settings and Change profile to 2dimmer and see if works. Mine work if i Change profile to 1dimmer…
I assume your device have ef00 cluster like mine. But its better check… Post a screenshot of your fingerprint.
Hi. Thank you @Pyrylamo . I’ve just managed to make the MS-105BZ dimmer work with the [ST Edge] Personal Tuya Devices - Generic EF00 Device. I’ve written down the steps I took in [ST Edge/Beta] Zigbee dimmer driver (supports MOES) - #38 by Kelvin.Left . I hope you guys will find it useful. :pray:
