The last couple of days I have not been receiving text/notification messages from my running routines. Otherwise, the routines run to finish without issue. When I do see a text/notification message, it usually the first entry only….and sometimes I receive no text message whatsoever….
I’ve performed all the processes to stop/uninstall/reinstall the ST app, restart Android phone, restart my Hubs, etc…but with the same results.
Also, @z4ib55, is there a reason why you created this post with the label webCore? I’m guessing you’re using the native option of sending texts/notifications in the SmartThings app, right?
I mentioned the part of the SMS notifications to the engineering team, and they are working on it.
However, since the push notification belongs to a different service, we need your help to investigate it further. So, please, help us collect the following information:
The name of the routine so we can look for it in your account
Trigger the routine, since the notification should appear instantly, collect the app logs right after triggering it:
Go to Menu > Gear Icon > About SmartThings
Tap the SmartThings logo 10 times.
This will open the developer’s space > tap ‘report a problem’
This will send you to the report page. Select a frequency and write a short description of the issue.
Click on “Report” and a log file will be generated for you to send over email, please do to build@smartthings.com
Take note of the date and time when the notification should have appeared so we have a good time reference and we can look for it in the Cloud logs and confirm the app logs captured the event as well.
I’m following up on this issue, have you had the chance to collect the info requested? Or, please also confirm if the Routines that send push notifications are working correctly.
I’m looking for logs regarding push notifications failing to be sent. The SMS/Text message not being sent is a known issue, so there’s no need to collect further info.
Can you confirm if your Routines that send Push notifications are failing or if they are working correctly, please?
