iOS 26.2 + SmartThings App 1.7.41.12 — SMS/Text Messaging Completely Broken (App Crashes + STHM Loses Recipients + Routines Don’t Send Texts)
Hi everyone — I’m reporting a major new issue with SMS/text notifications in SmartThings for iOS. I cannot find any threads about this and older posts only reference delivery problems, not app crashes.
Environment
  • iPhone 15
  • iOS 26.2
  • SmartThings iOS App 1.7.41.12
  • U.S. region
What’s Happening
There appear to be three problems:
1. SmartThings App Crashes When Setting SMS Recipient
If I create a Routine → “Send a text message,” or go to
Home Monitor → Settings → Reactions → Send a text message,
tapping the recipient field instantly crashes the app.
2. Home Monitor Lost Its Previously‑Configured SMS Recipient
If STHM had a text‑message recipient before the app update:
  • the recipient disappears,
  • it can’t be re‑added (because tapping the field crashes the app),
  • Home Monitor no longer sends SMS alerts at all.
3. Routines Retain Old Recipient but Don’t Send the Text
Routines created before the update still show a stored recipient,
but when triggered:
  • no text message is sent,
  • editing the action is impossible due to the crash.
Impact
This breaks all SMS‑based safety notifications for:
  • intrusion alerts
  • leak alerts
  • smoke/CO alerts
Push notifications work, but SMS functionality is currently unusable.
Ask
Can anyone else on iOS 26.2 confirm this?
I have sent this to SmartThings support on 1/18/2026.
And can SmartThings staff flag this for engineering?
I am on 26.3 and not experiencing app crashes when creating Routines using SMS. I did notice they changed the selection of contacts. When I set up limited access to my contacts and selected a user, it did not seem to let me select that user. Said Permission denied and I would be allowed to set up later but couldn’t proceed any further but I could enter the phone number manually and finish setting up the Routine. I will test more on the limited selection. When I set access to full access to my contacts, it allowed me to select my contacts.
SmartThings staff will likely direct you to contact Support directly as Engineering is not involved with the app - that is a separate group and they can’t talk directly with that group.
Thanks! I checked and SmartThings has Full Access to my Contact. When I try to add a phone number or a name in the Text Message “Enter number or select contact” box, the second I type a number or a letter, the app crashes. :frowning: I have also noticed that every time there is an update to the App, I must go back into each Add Text Message Recipients entry and redo it. That’s been going on for years. But this is a new “feature”!
Hi, @jkp
You’re also on iOS, right?
I heard of this issue from another user who had iOS version 18.5 and the SmartThings app version 1.7.38.26. I reported it, but I didn’t receive updates on it being solved, so it might be an individual issue.
@SomeoneKind, has Customer Support requested any information from you?
yes… only difference is I am on iOS 26.3 (beta)
It’s not iOS 26, I’m facing the same issue with iOS 18. Originally posted here
Customer service hasn’t responded to me
Hi, @SomeoneKind
I asked my team, and they saw that the Customer Support team asked you for some information, including a video reproducing the error and app logs.
Since we have an existing report about this, we can add you to it, so please provide the following:
  1. Support access to your account.
  1. App logs, but first enable the creation of additional logs in the app:
  1. In the ST app, go to “menu” > “settings”.
  2. At the bottom of that page, you’ll find a section called “Troubleshooting”. Please, enable the option that says “Create Additional SmartThings Log”.
  3. Restart the app
    If you
Then, replicate the error while recording your screen and get the app logs as follows:
  1. In the app menu, go to “contact us”
  2. Then, tap on “Error reports”
  3. On the opened page, tap 10 times on the title/label “What is the error about?” or until the prompt to create a log appears.
  4. Click on “ok” and wait for the process to finish. Then, save the generated file in the place you prefer and share it with us at build@smartthings.com
Please provide the date and time at which you made this exercise and share it with us including your timezone.
Any update to this? I had sent across videos reproducing the issue but never heard back.
Hi Nayelyz,
Here’s some information that I hope you find helpful. Note a workaround I discovered near the bottom of the text.
Summary
The SmartThings iOS app in version 1.7.41.12 appears to have a regression affecting all SMS/text‑message features across SmartThings Home Monitor (STHM) and Automations.
The issue consists of three failures:
1. App Crash on Editing SMS Recipient
When attempting to configure “Send a text message” (in either STHM → Reactions or Routines → Actions), the app crashes immediately upon tapping the recipient field.
2. Home Monitor Loses Previously‑Saved SMS Recipient
If SmartThings Home Monitor was previously configured with an SMS recipient:
  • The recipient disappears after the app update.
  • The setting is missing, and the user cannot re‑add it due to the crash.
  • No SMS messages are sent, even when STHM detects an intrusion/leak/smoke event.
3. Routines Retain Old Recipient but Do Not Send the SMS
For routines created before the update:
  • The recipient appears to remain stored internally.
  • The routine does NOT send the text when triggered.
  • Editing the action is impossible because tapping the field crashes the app.
Steps to Reproduce
Hi, Here’s the workaround I discovered that worked for me.
Workaround
To continue to have the app text from all SMS Text feature implementations, follow these steps:
  1. In iOS settings, in the SmartThings settings, select Contacts and set the setting to Limited Access. In the Edit selected contacts, select 1 contact (the contact you wish to notify). Note: I have only tested this with one contact because I only need 1 contact.
  2. In SmartThings, in the Home Monitor app or any other place the SMS Text feature is used, go to the field that holds the Contact number (or name), and enter the Contact’s phone number. (Name did NOT work for me).
Suspected Cause
Based on repeated observations over multiple app releases, this issue appears to surface whenever the SmartThings iOS app is updated, often requiring users to re‑enter SMS recipients and, in many cases, encountering app crashes during that process. With the most recent update, the behavior changed slightly in that the issue did not resolve at all until the workaround described above was applied.
One possible contributing factor may be the app’s interaction with iOS Contacts. In environments where a user has a large number of contacts, or where contacts are synchronized from external sources such as Microsoft Exchange (as is the case for me), the app appears to become unstable when accessing the contact list. In testing, limiting SmartThings’ contact access to a single contact allowed the feature to function reliably, which may indicate a scalability or memory‑handling issue when processing larger contact datasets. This may be worth validating against test environments with higher contact counts.
This behavior has been observable for several years, across multiple versions of the app, and has been discussed periodically in community forums. While I understand the challenges of prioritization and resource allocation, the recurring nature of this issue suggests an opportunity for a more permanent fix. Since I have identified a consistent workaround and provided detailed reproduction steps and observations above, I hope this information is helpful in diagnosing the underlying cause and improving the reliability of this feature for users who depend on SMS notifications for safety and security events.
Attachments / Notes
  • Behavior reproducible 100% of the time with 800 contacts and set to Full Access under SmartThings settings.
Hi, It looks like the system cut off my email response, so here it is again.
Summary
Steps to Reproduce
  1. Open SmartThings for iOS (v1.7.41.12).
  2. Create or edit any Routine.
  3. Add an action: Notify → Send a text message.
  4. Tap the recipient field to type a name or phone number.
  5. App crashes instantly.
-or-
  1. Open SmartThings Home Monitor → Settings → Reactions.
  2. Choose Security / Smoke / Leak.
  3. Select Send a text message.
  4. Tap the recipient fieldApp crashes.
Actual Results
  • App force‑closes every time the user taps the SMS recipient field.
  • Home Monitor no longer has an SMS recipient and cannot send texts.
  • Routines with pre‑existing SMS actions still trigger but never send the text.
  • SMS functionality is effectively 100% broken across the entire app.
Expected Results
  • User should be able to type a phone number or choose a contact.
  • STHM and Routines should send SMS messages as configured.
  • Previously stored SMS recipients should persist across app updates.
Impact Severity
Critical — affects core safety/security notifications:
  • Intrusion alerts
  • Leak alerts
  • Smoke/CO alerts
Users relying on SMS for emergency notifications may receive no alerts at all, despite events being logged in history.
Workaround
Suspected Cause
Attachments / Notes
Hey jkp, your posted triggered a workaround for me. Thanks! Here’s the workaround for anyone out there having this issue, that worked for me.
Workaround
Suspected Cause
Attachments / Notes
I was going to add that today I noticed that even adding a sms recipient to a routine causes to the app to crash on iOS. I have to select a contact from the address book, if I try to enter a name in the search field it crashes.
I just noticed something. In the phone it’s crashing on I have 1200+ contacts in my address book.
