SONOS not working as before
This is the old documentation. The new capabilities documentation doesn’t even list Audio Notification
https://smartthings.developer.samsung.com/docs/api-ref/capabilities.html
What SmartApp is what you are trying to use? Could you give me a link to it or PM me the original code?
I saw that. That’s why I contacted support today and asked them to update the documentation on the developer portal. Actually they have separate support group too. If you want, try to contact them directly. I haven’t searched for their contact address, so you need to first find it.
It’s the SmartThings " Speaker Notify with Sound" but heavily modified. If looking at original, line 95 if left as is will no longer show Sonos speakers. If you change line 95 to capability.musicPlayer, Sonos speaker will show up, but will not work.
And then I think lines 280, 283, and 286 may need changed. But right now, I’m thinking line 95 is the issue.
Ok, I’ve tried it, and it works correctly with my Sonos.
Here is the code. And just to confirm for @HA_fanatic, I tried the custom message option too, by just typing there Open, and the textToSpeech is working too.
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  Speaker Custom Message
 *  Author: SmartThings
 *  Date: 2014-1-29
definition(
	name: "Speaker Notify with Sound",
	namespace: "smartthings",
	author: "SmartThings",
	description: "Play a sound or custom message through your Speaker when the mode changes or other events occur.",
	category: "SmartThings Labs",
	iconUrl: "https://s3.amazonaws.com/smartapp-icons/Partner/sonos.png",
	iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Partner/sonos@2x.png"
preferences {
	page(name: "mainPage", title: "Play a message on your Speaker when something happens", install: true, uninstall: true)
	page(name: "chooseTrack", title: "Select a song or station")
	page(name: "timeIntervalInput", title: "Only during a certain time") {
		section {
			input "starting", "time", title: "Starting", required: false
			input "ending", "time", title: "Ending", required: false
def mainPage() {
	dynamicPage(name: "mainPage") {
		def anythingSet = anythingSet()
		if (anythingSet) {
			section("Play message when"){
				ifSet "motion", "capability.motionSensor", title: "Motion Here", required: false, multiple: true
				ifSet "contact", "capability.contactSensor", title: "Contact Opens", required: false, multiple: true
				ifSet "contactClosed", "capability.contactSensor", title: "Contact Closes", required: false, multiple: true
				ifSet "acceleration", "capability.accelerationSensor", title: "Acceleration Detected", required: false, multiple: true
				ifSet "mySwitch", "capability.switch", title: "Switch Turned On", required: false, multiple: true
				ifSet "mySwitchOff", "capability.switch", title: "Switch Turned Off", required: false, multiple: true
				ifSet "arrivalPresence", "capability.presenceSensor", title: "Arrival Of", required: false, multiple: true
				ifSet "departurePresence", "capability.presenceSensor", title: "Departure Of", required: false, multiple: true
				ifSet "smoke", "capability.smokeDetector", title: "Smoke Detected", required: false, multiple: true
				ifSet "water", "capability.waterSensor", title: "Water Sensor Wet", required: false, multiple: true
				ifSet "button1", "capability.button", title: "Button Press", required:false, multiple:true //remove from production
				ifSet "triggerModes", "mode", title: "System Changes Mode", required: false, multiple: true
				ifSet "timeOfDay", "time", title: "At a Scheduled Time", required: false
		def hideable = anythingSet || app.installationState == "COMPLETE"
		def sectionTitle = anythingSet ? "Select additional triggers" : "Play message when..."
		section(sectionTitle, hideable: hideable, hidden: true){
			ifUnset "motion", "capability.motionSensor", title: "Motion Here", required: false, multiple: true
			ifUnset "contact", "capability.contactSensor", title: "Contact Opens", required: false, multiple: true
			ifUnset "contactClosed", "capability.contactSensor", title: "Contact Closes", required: false, multiple: true
			ifUnset "acceleration", "capability.accelerationSensor", title: "Acceleration Detected", required: false, multiple: true
			ifUnset "mySwitch", "capability.switch", title: "Switch Turned On", required: false, multiple: true
			ifUnset "mySwitchOff", "capability.switch", title: "Switch Turned Off", required: false, multiple: true
			ifUnset "arrivalPresence", "capability.presenceSensor", title: "Arrival Of", required: false, multiple: true
			ifUnset "departurePresence", "capability.presenceSensor", title: "Departure Of", required: false, multiple: true
			ifUnset "smoke", "capability.smokeDetector", title: "Smoke Detected", required: false, multiple: true
			ifUnset "water", "capability.waterSensor", title: "Water Sensor Wet", required: false, multiple: true
			ifUnset "button1", "capability.button", title: "Button Press", required:false, multiple:true //remove from production
			ifUnset "triggerModes", "mode", title: "System Changes Mode", description: "Select mode(s)", required: false, multiple: true
			ifUnset "timeOfDay", "time", title: "At a Scheduled Time", required: false
		section{
			input "actionType", "enum", title: "Action?", required: true, defaultValue: "Bell 1", options: [
				"Custom Message",
				"Bell 1",
				"Bell 2",
				"Dogs Barking",
				"Fire Alarm",
				"The mail has arrived",
				"A door opened",
				"There is motion",
				"Smartthings detected a flood",
				"Smartthings detected smoke",
				"Someone is arriving",
				"Piano",
				"Lightsaber"]
			input "message","text",title:"Play this message", required:false, multiple: false
		section {
			input "sonos", "capability.audioNotification", title: "On this Speaker player", required: true
        //input "sonos", "capability.musicPlayer", title: "On this Speaker player", required: true
		section("More options", hideable: true, hidden: true) {
			input "resumePlaying", "bool", title: "Resume currently playing music after notification", required: false, defaultValue: true
			href "chooseTrack", title: "Or play this music or radio station", description: song ? state.selectedSong?.station : "Tap to set", state: song ? "complete" : "incomplete"
			input "volume", "number", title: "Temporarily change volume", description: "0-100%", required: false
			input "frequency", "decimal", title: "Minimum time between actions (defaults to every event)", description: "Minutes", required: false
			href "timeIntervalInput", title: "Only during a certain time", description: timeLabel ?: "Tap to set", state: timeLabel ? "complete" : "incomplete"
			input "days", "enum", title: "Only on certain days of the week", multiple: true, required: false,
				options: ["Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday"]
			if (settings.modes) {
        	input "modes", "mode", title: "Only when mode is", multiple: true, required: false
			input "oncePerDay", "bool", title: "Only once per day", required: false, defaultValue: false
		section([mobileOnly:true]) {
			label title: "Assign a name", required: false
			mode title: "Set for specific mode(s)", required: false
def chooseTrack() {
	dynamicPage(name: "chooseTrack") {
		section{
			input "song","enum",title:"Play this track", required:true, multiple: false, options: songOptions()
private songOptions() {
	// Make sure current selection is in the set
	def options = new LinkedHashSet()
	if (state.selectedSong?.station) {
		options << state.selectedSong.station
	else if (state.selectedSong?.description) {
		// TODO - Remove eventually? 'description' for backward compatibility
		options << state.selectedSong.description
	// Query for recent tracks
	def states = sonos.statesSince("trackData", new Date(0), [max:30])
	def dataMaps = states.collect{it.jsonValue}
	options.addAll(dataMaps.collect{it.station})
	log.trace "${options.size()} songs in list"
	options.take(20) as List
private saveSelectedSong() {
	try {
		def thisSong = song
		log.info "Looking for $thisSong"
		def songs = sonos.statesSince("trackData", new Date(0), [max:30]).collect{it.jsonValue}
		log.info "Searching ${songs.size()} records"
		def data = songs.find {s -> s.station == thisSong}
		log.info "Found ${data?.station}"
		if (data) {
			state.selectedSong = data
			log.debug "Selected song = $state.selectedSong"
		else if (song == state.selectedSong?.station) {
			log.debug "Selected existing entry '$song', which is no longer in the last 20 list"
		else {
			log.warn "Selected song '$song' not found"
	catch (Throwable t) {
		log.error t
private anythingSet() {
	for (name in ["motion","contact","contactClosed","acceleration","mySwitch","mySwitchOff","arrivalPresence","departurePresence","smoke","water","button1","timeOfDay","triggerModes","timeOfDay"]) {
		if (settings[name]) {
			return true
	return false
private ifUnset(Map options, String name, String capability) {
	if (!settings[name]) {
		input(options, name, capability)
private ifSet(Map options, String name, String capability) {
def installed() {
	log.debug "Installed with settings: ${settings}"
	subscribeToEvents()
def updated() {
	log.debug "Updated with settings: ${settings}"
	unsubscribe()
	unschedule()
	subscribeToEvents()
def subscribeToEvents() {
	subscribe(app, appTouchHandler)
	subscribe(contact, "contact.open", eventHandler)
	subscribe(contactClosed, "contact.closed", eventHandler)
	subscribe(acceleration, "acceleration.active", eventHandler)
	subscribe(motion, "motion.active", eventHandler)
	subscribe(mySwitch, "switch.on", eventHandler)
	subscribe(mySwitchOff, "switch.off", eventHandler)
	subscribe(arrivalPresence, "presence.present", eventHandler)
	subscribe(departurePresence, "presence.not present", eventHandler)
	subscribe(smoke, "smoke.detected", eventHandler)
	subscribe(smoke, "smoke.tested", eventHandler)
	subscribe(smoke, "carbonMonoxide.detected", eventHandler)
	subscribe(water, "water.wet", eventHandler)
	subscribe(button1, "button.pushed", eventHandler)
	if (triggerModes) {
		subscribe(location, modeChangeHandler)
	if (timeOfDay) {
		schedule(timeOfDay, scheduledTimeHandler)
	if (song) {
		saveSelectedSong()
	loadText()
def eventHandler(evt) {
	log.trace "eventHandler($evt?.name: $evt?.value)"
	if (allOk) {
		log.trace "allOk"
		def lastTime = state[frequencyKey(evt)]
		if (oncePerDayOk(lastTime)) {
			if (frequency) {
				if (lastTime == null || now() - lastTime >= frequency * 60000) {
					takeAction(evt)
				else {
					log.debug "Not taking action because $frequency minutes have not elapsed since last action"
			else {
				takeAction(evt)
		else {
			log.debug "Not taking action because it was already taken today"
def modeChangeHandler(evt) {
	log.trace "modeChangeHandler $evt.name: $evt.value ($triggerModes)"
	if (evt.value in triggerModes) {
		eventHandler(evt)
def scheduledTimeHandler() {
	eventHandler(null)
def appTouchHandler(evt) {
	takeAction(evt)
private takeAction(evt) {
	log.trace "takeAction()"
	if (song) {
		sonos.playSoundAndTrack(state.sound.uri, state.sound.duration, state.selectedSong, volume)
	else if (resumePlaying){
		sonos.playTrackAndResume(state.sound.uri, volume)
    //sonos.playTrackAndResume(state.sound.uri, state.sound.duration, volume)
	else {
	sonos.playTrackAndRestore(state.sound.uri, volume)
		//sonos.playTrackAndRestore(state.sound.uri, state.sound.duration, volume)
	if (frequency || oncePerDay) {
		state[frequencyKey(evt)] = now()
	log.trace "Exiting takeAction()"
private frequencyKey(evt) {
	"lastActionTimeStamp"
private dayString(Date date) {
	def df = new java.text.SimpleDateFormat("yyyy-MM-dd")
	if (location.timeZone) {
		df.setTimeZone(location.timeZone)
	else {
		df.setTimeZone(TimeZone.getTimeZone("America/New_York"))
	df.format(date)
private oncePerDayOk(Long lastTime) {
	def result = true
	if (oncePerDay) {
		result = lastTime ? dayString(new Date()) != dayString(new Date(lastTime)) : true
		log.trace "oncePerDayOk = $result"
	result
// TODO - centralize somehow
private getAllOk() {
	modeOk && daysOk && timeOk
private getModeOk() {
	def result = !modes || modes.contains(location.mode)
	log.trace "modeOk = $result"
	result
private getDaysOk() {
	def result = true
	if (days) {
		def df = new java.text.SimpleDateFormat("EEEE")
		else {
		def day = df.format(new Date())
		result = days.contains(day)
	log.trace "daysOk = $result"
	result
private getTimeOk() {
	def result = true
	if (starting && ending) {
		def currTime = now()
		def start = timeToday(starting, location?.timeZone).time
		def stop = timeToday(ending, location?.timeZone).time
		result = start < stop ? currTime >= start && currTime <= stop : currTime <= stop || currTime >= start
	log.trace "timeOk = $result"
	result
private hhmm(time, fmt = "h:mm a")
	def t = timeToday(time, location.timeZone)
	def f = new java.text.SimpleDateFormat(fmt)
	f.setTimeZone(location.timeZone ?: timeZone(time))
	f.format(t)
private getTimeLabel()
	(starting && ending) ? hhmm(starting) + "-" + hhmm(ending, "h:mm a z") : ""
// TODO - End Centralize
private loadText() {
	switch ( actionType) {
		case "Bell 1":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", duration: "10"]
			break;
		case "Bell 2":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/bell2.mp3", duration: "10"]
			break;
		case "Dogs Barking":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/dogs.mp3", duration: "10"]
			break;
		case "Fire Alarm":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/alarm.mp3", duration: "17"]
			break;
		case "The mail has arrived":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/the+mail+has+arrived.mp3", duration: "1"]
			break;
		case "A door opened":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/a+door+opened.mp3", duration: "1"]
			break;
		case "There is motion":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/there+is+motion.mp3", duration: "1"]
			break;
		case "Smartthings detected a flood":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/smartthings+detected+a+flood.mp3", duration: "2"]
			break;
		case "Smartthings detected smoke":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/smartthings+detected+smoke.mp3", duration: "1"]
			break;
		case "Someone is arriving":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/someone+is+arriving.mp3", duration: "1"]
			break;
		case "Piano":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/piano2.mp3", duration: "10"]
			break;
		case "Lightsaber":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/lightsaber.mp3", duration: "10"]
			break;
		case "Custom Message":
			if (message) {
				state.sound = textToSpeech(message instanceof List ? message[0] : message) // not sure why this is (sometimes) needed)
			else {
				state.sound = textToSpeech("You selected the custom message option but did not enter a message in the $app.label Smart App")
			break;
		default:
			break;
Just to confirm. I haven’t fiddled around with the selected song option. It is not fixed. Please excuse me. I haven’t wrote clearly.
Just updated my smartapp with your changes, and it works! Where do I send the beer? :):grinning:
How did you fix the tts issue?
It looks like the original SmartApp is using an undocumented textToSpeech() method. From what I can tell, it looks like a platform level method that returns an object with a URI to a ‘track’.
My guess is it’s using cloud services to perform the TTS → file conversion (eg. Polly, etc)
The new driver is still fundamentally missing the speak()or playText() methods that you might be accustomed to… but it looks like the textToSpeech() approach used in this SmartApp could be used in other SmartApps (and might be what they are using internally in the Custom Automation ‘Notify Members’ feature that’s available with the new Sonos websocket driver)
Ha! you are sneaky I don’t know when or who made the changes, but picking up the audioNotification capability and removing the “duration” was smart :wink:
It is all in my previous post. About the Audio Notification capability.
As I understand, speak() and playText() are supported only by the speechSynthesis capability.
Even looking at the RemindR, it uses textToSpeech() for Sonos devices. It requires only a little change in the code too to make it work again. Starting with the selection of audioNotification, and not musicPlayer anymore. And further down the removal of durations and adjusting commands according the audioNotification capability.
I have found an ObiThing DTH, where speak() is defined with textToSpeech() and has the speechSynthesis capability.
Is there any other textToSpeech() way, then using a third party API and passing it to the playTrack()?
Correction, I’ve found an old documentation, playText() was part of the musicPlayer. speak() is only speechSynthesis. Anyhow textToSpeech() is working. Probably it does the same as what playText() did before.
this function used to return a uri and a duration. It looks like duration is no longer returned, so apps using playTrackAndSomething (uri, duration, volume) like Big Talker and RemindR, are currently broken unless the authors remove the duration parameter. I found more details about the textToSpeech function here:
where did you get this code?
it looks familiar
It’s available in the SmartThings GitHub repo:
You can find several SmartApps using the textToSpeech() method with a search of the repo:
https://github.com/SmartThingsCommunity/SmartThingsPublic/search?q=textToSpeech&unscoped_q=textToSpeech
The challenge is that playText() was part of the core device.
Which meant that users could use apps like WebCoRE or SharpTools.io to build arbitrary rules that used these commands however they see fit. The textToSpeech() method seems like a great fit for people building custom SmartApps… but not so great for more abstract rule builders.
(Sure, users can use whatever cloud based TTS engine of their choosing and still use the playTrack() and related methods with a prerendered TTS track, but the playText() method was really convenient)
Ok. I understand you. It make sense.
Can’t you put a layer in between? Either a SmartApp or a Virtual device? Something what would utilize the textToSpeech() and pass the result to the speaker?
I am just thinking loudly…
Yes, see the final parenthetical in my previous message. :smile:
To me, it’s not a question of if there are possible workarounds for it - there are obviously approaches available - just that functionality that people were using is no longer working.
The title of this thread summarized it very well: “SONOS not working as before” :smiley:
The point is to make it working again, like as before. :wink:
