Something has started triggering my presence at 22:30 each day and I have no idea what it is. I’ve looked at the history in the SmartThings app and I just see the devices turning off or on. I’ve checked all the routines and nothing is set at 22:30
What could be causing this and is there any way I can locate the problem?
Are you looking at the device history or the more general app history? The latter (menu, history) will give you a broader view of scenes and routines firing and might help trace the origin - see screen cap below. If there’s no obvious trigger there, if you use Alexa devices, have you checked if hunches are enabled? You can check the activity history there too for additional clues.
It’s when your Echo device starts doing things based on it’s understanding of what you might want. Examples below (Alexa, settings, hunches - in the Alexa preferences section of the menu)
No Alexa here. Just automations I’ve set up in ST and they run via IFTTT. Again nothing in IFTTT set to trigger at 22:30. I just can’t track down what the cause is.
Do you have Scheduling enabled on your Blink sync module? Although when you say “turning the blink off it’s it’s on or on if it’s off” that is something Blink doesn’t do.
Do you happen to have any Smart Lighting things set up that could be using those virtual switches?
Whille you’re waiting for ST support to get back to you, it dawned on me that you should install the ST CLI and turn on logging for all the drivers. It may give you a clue about what is firing around that time that is triggering the change.
It’s actually pretty straight forward. Simply download the CLI binary from the link above. If you are on Windows, open a command window and type the command above. If you are on a Mac or Linux machine, open a terminal window and use the same command. If you don’t know your hub’s IP address, you can find it in the legacy IDE here.
