Solid Blue light. Not getting ip from dhcp
I booted up my first Smartthings hub last night. I was running fine for most of the night but now it is stuck with a blue / white solid light.
Tried to reboot it / reset it but still not going on-line. From the dhcp router I can see it’s not picking up any ip’s nor is it trying to. Seems like it is stuck.
I have changed cables, moved ports etc etc.
Please advise. Pretty bad start :wink:
No I don’t.
No, why should that be an issue? It’s not pulling any ip’s and no leds blinking on the NIC.
Have you rebooted everything?
Of course yes,
I found the issue. Most likely due to a faulty power supply that was not feeding the hub with enough power and the backup batteries were drained.
