tgauchat
64
Myself and various others have seen and report this type of error message from time to time, but has multiple possible causes. I think the most common is when some non-official Device Type is in use, but definitely not always the reason.
Can you run Live Logging please and capture the lines right around when the error occurs? Browser console / Javascript debugging is a further step, but letās try Live Logging first.
Best to move your case to email: Support@SmartTiles.click and weāll share the results later here.
tgauchat
65
Trying to come up with uses for 5 unique Dashboards?
Just got inspired by a nifty Temperatures Dashboard native SmartApp by Johnā¦
So⦠not as compact and efficient, but in SmartTiles āstyleā, I created thisā¦
I have version 5.4.1-M that was installed with the old āfrom codeā method. Previously when a new release came out I would cut and paste the new code in place of the old code and be upgraded.
I assume that there is no cut and paste upgrade like before so what are my options to upgrade?
HA! OK, first offā¦how could anyone not know what to do with their 5 instances? I want one in every room in the house (i.e. every room will have a wall-mounted Android device with SmartTiles on it, and I will eventually have each one configured for things specific to that room - plus relevant whole-house stuff, of course) lol
I have done the ātempsā thing in one of my instances. Not that I will leave it there like that forever, but just something to play around with. I did the same thing for all lights/switches. Haha, for me, neither category is very jam-packed yet. So, itās not unruly. Mostly, I just wanted to have that view of EVERYTHING all in one screen.
tgauchat
69
Correct, unfortunately. We canāt distribute the source code anymore.
So⦠keep any instances that you have as bonuses (there are no serious known risks as of the time of writing), and install the new SmartTiles (Connect) to create up to 5 additional dashboards per Account Location.
Has someone tried to use html5 music player on android and then link the page from smart tiles?
Would it be possible to have a music player integrated in a single tile, something similar to the weather tile?
tgauchat
71
Anything is possible ⦠well, except time travel.
SmartTiles V6 will have more flexibility for us to create specialized Tiles. As youāre aware, SmartThings has a growing API for creating UIās that are a part of each Device Type Handler (i.e., the various sub-tiles, sliders, colors, etc.). SmartTiles can currently offer somewhat more eloquent designs, but thatās because we can directly use HTML and CSS elements.
SmartThings does not give us access to the metadata that defines the UI for a Device Type. We can just access the same Attributes and Commands as any other SmartApp. The Weather Tile is pulling all itās data from the optional SmartThings Smart Weather Station Device.
So in regards to enhancing media player control, the question rises whether or not it should start with a SmartThings Device Type, or if we develop our own specifications for customized tiles, or if they are to be done on a case-by-case one-off basis.
For example, weād love to integrate more closely with Keen Home Smart Vents. Amazing product and they deserve a customized control (or at least a control that reflects the unique features of a controllable vent as opposed to any other type of Switchā¦). Weāre working on itā¦
Iām a little confused (most of the time) but it appears this is the right place to ask questions - please correct me if Iām wrong!
My Hive thermostat is not a thing recognised by ST, but it can respond to SMS messages. It can understand āboostā commands (heating on for one hour), and it can set temperature either permanently (not so useful) or temporarily until the next programmed temperature takes over (more useful)
IFTTT can send text messages.
Soooooo⦠is there any way of having a button on my SmartTiles that can fire off a text message? Just the Boost would be good, if the temperature can be done too then thatās a bonus. It just needs to send a string as a text when pressed for boost.
need help with a dashboard video config. any help appreciated. I have setup a video stream tile in the past that I no longer want. How can I go about deleting it. Once you put something in the video stream (title/address) box, blanking out the setting will not save nor can I find a delete stream button. anybody have any suggestions?
tgauchat
74
This is a known issue in SmartTiles ā although, frankly, weāre not sure yet if it may actually be a SmartThings bug, though it that case, we may have to come up with a workaround anyway. Some people are reporting that this happens with SMS/text message numbers too.
Let me know your mobile OS and SmartThings app version.
thanks. Iāve only asked since it wasnt in the FAQ section. Not a big deal if you donāt find a solution. my work around now would be to find another public stream to fill the empty tile (maybe a puppy stream).
android STv2.05.
tgauchat
76
Yah⦠adding to SmartTiles.click FAQ is a good idea⦠though I wonder how many people actually read that page ⦠Oh⦠over 100 hits / day to the info page in general.
You could create a Simulated button as a new device in the ide.
Then using the SmartThings app setup the Notify Me When app to send a text when the button is pushed and put the required message in the message details section.
Now add this button to the SmartTiles dashboard.
Repeat for the second text requirements and youāre all set.
Great, thatās a fantastic start thanks.
Unfortunately Iāve run into two problems - the first is that Hive doesnāt support āBoostā over text - you can only set the temperature, or turn on and off. I have no idea why I thought it did, but itās a feature thatās been requested and no more.
So, to Boost Iād need to send a text, and then wait an hour and send another - the first saying āHEAT 22ā and the one an hour later saying āHEAT AUTOā. That will emulate the boost function.
The second problem is a bit more severe - I canāt get Notify Me When to send a text! It does a push notification fine, but I put my own phone number in to debug it (I need to see what number the text arrives from, in order to whitelist that number with Hive) and the message never arrives via SMS.
Back to the drawing board⦠but thanks for the help mechanimal82.
Thanks, Iāve run into a more serious problem though. Well, one serious and one irritating.
The irritating one is that Hive doesnāt support a Boost text command, I can only turn heating on/off and set temperature. So to emulate a Boost Iād need to send a command (āHEAT AUTO 22ā) and then wait an hour before sending āHEAT AUTOā to put it back to schedule. This timeout seems to be an issue with Notify Me When, Iāll go and check Rules Machine
The dealbreaker though is that Hive will only accept a +44 UK number to go on itās whitelist of numbers allowed to control the heating. SmartThings SMS messages come from a +1 202 number. Iāve reached out to Hive support to see if this can be overriden, I suspect my answer will be something relevant to the fact theyāre just about to launch their own ST style devices (bulbs, sockets, motion sensors, door sensors) and theyād rather not provide cross-platform compatibility.
Binned the simulated button, went for a switch.
Used IFTTT (since it works with switches, not buttons) to send a HEAT AUTO 22 message from my phone to Hive when turned on, and HEAT AUTO message from my phone when turned off. So Iām using IFTTT to generate the texts from my own phone, hence itās a UK number, and theyāre quite happy with that.
So the remaining issue is to work out how to toggle a switch back off when itās been on for 60 minutes. I saw someone mention something about an energy SmartApp so Iāll go hunt that out.
