SmartTiles Dashboard 5.4.2 - July 13 (www.SmartTiles.click)
I’m also hoping we can eventually get support for Real Time Streaming Protocol (RTSP) as well – between RTSP and streaming MPEG, that would cover the vast majority of the IP cameras out there.
I don’t know of anyway with HTML5 that supports rtsp without using flash, active x.
But I haven’t looked into it a ton.
It might be that part of the reason Dropcam won’t move beyond Flash is to keep it difficult for people to capture and save streams so that their subscription system can’t be bypassed.
are your blue iris cameras running h264? (rtsp)? and they works with smart tiles?
You are not going to be able to use rtsp on smart tiles, you setup different streams, but HTML 5 doesn’t support rtsp so you have to use jpeg or mjpegs.
I have been using BlueIris, but i’ve turned off my server and using direct to different Foscams so let me check my old settings and let you know what i have setup.
I do this with my dropcam to display an image, not video though, the image just updates as the dashboard refreshes. Also doesn’t require the camera to be public. Just requires you log into your dropcam account on the same browser. So on my android tablet, I open up chrome, login to dropcam account and then go back to my home screen and then I click on my SmartTiles link to go into fullscreen and I get an image of my DropCam.
@huydnguyen - thanks, I will try your idea for Dropcam. I am able to get a live feed by using a browser that supports Flash, but I do have to make my camera public.
I am using blue iris with a couple of rtsp cams. Out to SmartTiles with mjpg and they work fine.
thanks Navat604 :slight_smile: just to confirm you’re cams are still set to rtsp right? and blue iris converts to mjpeg?
yeah, I wondered about that too? So I can output any rtsp cam to the blue iris software and then configure a conversion to mpeg format (within the blue iris software?) so that I can push/relay it SmartTiles for easy viewing?
That’s correct @joel_eggenhuize and @dhsemp. Let’s not bog up this thread and move to this thread if you guys still want more info
Great job! Loving it! However, recently, my weather has stopped updating automatically. If I refresh it from the dashboard it doesn’t update, have to go into the ST app and refresh it from my “things” list.
Suggestions?
I can’t find the dashboard URL anymore in preferences. Please clue me in! Thanks!
Go to SmartTiles settings by clicking on the gear icon in the upper right corner
Click Next in the upper right corner.
Choose how you want to get the URL, copied from the screen, or by SMS.
Click Done in upper right to exit settings, or click return to Settings at bottom to go back.
@625alex - Hi Alex, I am having a problem with one device in particular. It is a wall outlet http://www.lowes.com/pd_339582-1353-45636___?productId=3707742&pl=1&Ntt=iris+wall+outlet
ST knows the on/off status of the device and can control it fine. It is using the standard z-wave switch device type. I am able to get the switch to show up in the Smart Tiles dashboard, but it is not able to control the on/off of the device and does not accurately display it’s current state. I have tried adding and removing the device from ST, but that did not help. ST seems to connect to the device fine. Any ideas?
I’m back!
Thanks for the tip that Puffin browser works with Dropcam on iOS.
Did you change tile size by any chance?
Dropcam is an excellent plug and play camera, but you have to do everything through them and I don’t like that. Also, I think it’s way too expensive.
I don’t see a problem with making a camera public. The URL of a public stream is meant to be unguessable (just like any ST endpoint URL) and it’s not published or shared anywhere. The chance of discovering a stream token is negligible.
I hear that there is a problem with schedules at ST back end. Weather is scheduled to refresh every 15 minutes If scheduler dies, the weather won’t get updated.
The only workaround I’m aware of is to step through SmartTiles app preferences again, no need to change anything. This will reset the scheduler, but it may die again eventually.
I will look into a more permanent solution.
Did you figure it out?
This is interesting. SmartTiles is agnostic to the brand/make of a device and operates only on it’s capabilities.
Although I can imagine a few characteristics of your particular device that may cause it not work with the dashboard. Send me a PM and we can debug it together.
