My version just updated to 5.1.1 automagically! Great job @625alex! I wish all smartapps did this!
Awesome work! if u want beta testers tell me
So you get a tile with green icon, right? Does it open in browser or in a standalone app window?
I thought you already are a beta tester! Aren’t we all? ![]()
5.1.1 Nest Cooling Temp change is working now.
Is there a way to create a virtual Dimming Tile. I have some Cree Connected lights in the same room, and I would like to control them on the dashboard with one tile, right now I can only see the on/off tile with no dimming. Is there one that can dim both lights together?
Check out the “Dim with Me” SmartApp
Could you share the css for the armn and disarm alarm icons?
looks sweet
Thank you!
I also had to use Better Dimmer Device to make it work the way i wanted
@625alex, actually, not a green tile
And it looks really nice when open.
I really want to echo the Thanks offered by many others. If I ever get anything functionally useful in the SmartThings ecosystem, I plan to thank Alex in a more objective manner.
@Eduardo_Veras, I will post what I did in the “theme” post for SmartTiles tomorrow sometime. It probably does not belong in this post, anyway. Keep in mind, the smart apps are pretty terrible…but work for me
Sorry if it’s already been asked, but is there a way to add a tile to the dashboard that when clicked will execute a smartapp? I have some scene machine scenes that I’d like to be able to call up from the smarttiles dashboard.
Alternatively, if the dashboard is limited to showing Things, does anybody have a virtual switch that calls a smartapp? I’ve used virtual device types before, but I’m not sure how to call a custom smart app from within a device’s groovy code.
Is there something like Push to GET for sending PUT requests? I’m trying to start a color loop on my Hue bulbs:
Very nice! Is it possible to add text size as an option?
Awesome work !
thanks for this
Are you addressing my work specifically? What font did you want to change?
I toyed with the font size on the event list but decided to just leave it at default after a while.
@jazzyjayx, yes, sorry. Not necessarily the font, just the size if possible. Not a big deal though since it’s not always on display like the main dashboard.
I still don’t understand how to create multiple instances of the dashboard. you keep saying it like it’s a simple thing to do:
“create as many instances as necessary in the ST Mobile App. Each instance has it’s own set of preferences.”
i don’t see anything on my phone that indicates I can install multiple instances. under “smartthings labs” on the initial dashboard, I just see one instance.
EDIT: found it ALLLL the way to the right under “my apps.”
