I’m trying to swap out my Xfinity provider modem router combo with a modem connected to my smartthings wifi.
Smartthings refuses to get an internet connection.
What I’ve tried:
I’ve tried a couple different modem brands including the Motorola mb8600, aris sb6183, net gear cm700.
Resetting the smartthings Wi-Fi - doesn’t get an ip and asks to manually enter details
Connected to a router in the middle - this works but isn’t the setup I want.
I’d guess that the ET-WV525 is in bridge mode. Use the Plume App and set the Network Mode to Router Only instead of Auto Mode and it should work connected directly to your modem.
Can you plug a computer into the modem to see what it is providing? I am unfamiliar with the Smartthings wifi device, but without knowing what is being provided by the upstream device it is very hard to troubleshoot.
What is your local IP address? If it is a private address (192.168.x.x) that tells you the upstream device is providing dhcp, if it is a public address then the device is in a passthrough mode.
Then it’s just a matter of adjusting the config of the smartthings device to work with that configuration. Does the smartthings device act as a router/firewall?
Make sure the cable from the xfinity box is plugged into the WAN port on the wv525. Fire up the plume app and make sure the Network Mode is set to Auto. Save the settings. Then power everything off.
Turn on the xfinity modem, wait for it to come online.
If the Wi-Fi hub is not detected, tap Add device on the dashboard. Then, tap under ADD DEVICE MANUALLY → Wi-Fi/Hub → SmartThings Wifi, and tap your Wi-Fi hub’s name.
