Last friday (June 16) i tried to build ST SDK firmware to our WiFi outlet device (MCU: ESP32) for Direct connected devices and im not changes anythings on my code but last monday (June 20) when i rebuild the firmware there was a problem on
[811/840] Building C object esp-idf/main/iotcore/src/CMakeFiles/iotcore.dir/iot_wt.c.obj
FAILED: esp-idf/main/iotcore/src/CMakeFiles/iotcore.dir/iot_wt.c.obj
In file included from <command-line>:
~/st-device-sdk-c-ref/iot-core/src/include/iot_common.h:22:10: fatal error: iot_bsp_custom.h: No such file or directory
**#include "iot_bsp_custom.h"**
compilation terminated.
[812/840] Building C object esp-idf/main/iotcore/src/CMakeFiles/iotcore.dir/iot_capability.c.obj
FAILED: esp-idf/main/iotcore/src/CMakeFiles/iotcore.dir/iot_capability.c.obj
~st-device-sdk-c-ref/iot-core/src/include/iot_common.h:22:10: fatal error: iot_bsp_custom.h: No such file or directory
[813/840] Building C object esp-idf/main/iotcore/src/CMakeFiles/iotcore.dir/iot_api.c.obj
FAILED: esp-idf/main/iotcore/src/CMakeFiles/iotcore.dir/iot_api.c.obj
[814/840] Building C object esp-idf/main/iotcore/src/CMakeFiles/iotcore.dir/iot_main.c.obj
FAILED: esp-idf/main/iotcore/src/CMakeFiles/iotcore.dir/iot_main.c.obj
[816/840] Building C object esp-idf/main/iotcore/src/CMakeFiles/iotcore.dir/iot_uuid.c.obj
FAILED: esp-idf/main/iotcore/src/CMakeFiles/iotcore.dir/iot_uuid.c.obj
I’ve checked file #include “iot_bsp_custom.h” which is already in ~st-device-sdk-c-ref\iot-core\src\include\bsp\esp32 but when rebuild firmware again that messages error :
fatal error: iot_bsp_custom.h: No such file or directory appears again
what is the cause and what solution should I do? ask for suggestion
