cannot solve this problem. Help
Hey, @Parkminsue
Very welcome!!
Just to double-check, are you able to setup, build, and flash if you use the SDK’s python scripts, e.g.:
# setup
python setup.py esp8266
# build app
python build.py apps/esp8266/switch_example
# flash app
Note: You may need to reconfigure your “python” symbolic link because in some cases it points to Python2 which is EOL. To do so run:
sudo update-alternatives --install \
/usr/bin/python python \
/usr/bin/python3 1 # pointing your default python version
