Is there a location to retrieve the SmartThings Motion Sensor Device Source Code? I want to use it to add a denounce option to the device. So that for example motion sensor outside want to make sure if more then just 1 motion, but rather 2 or 3 before alerted the motion event. Getting false alarms for trees moving, but still want them within range.
If you log into the IDE and create a new device, you can chose “From Template” and the ST device type code is there
perfect! thanks @kevintierney. I always just did “from code”. lesson learned should play around with IDE more.
this sounds really interesting to me. Will you be sharing your device type?
I made publication request to SmartThings, but in meantime. From template of Aeon I added:
preferences {
input(“debounce”, “number”, title:“Debounce Motion?”, description: “default: 0”, defaultValue:0)
replaced:
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd) {
def map = [:]
map.name = “motion”
def value = cmd.sensorValue ? “active” : “inactive”
if (value == “active”)
state.bounce = state.bounce + 1
else
state.bounce = 0
map.name = “motion”
if (state.bounce > settings.“debounce”.toInteger())
map.value = “active”
map.descriptionText = “$device.displayName detected motion”
else
map.value = “inactive”
map.descriptionText = “$device.displayName motion has stopped”
map
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
def map = [:]
def value = cmd.value ? “active” : “inactive”
else
state.bounce = 0
map.name = “motion”
else
map
SmartThings Motion Sensor:
added same input and replaced:
private String parseValue(String description) {
if (isZoneType19(description))
if (translateStatusZoneType19(description))
else
state.bounce = 0
if (state.bounce > settings."debounce".toInteger()) { return "active" } else { return "inactive" }}
description
*** Update ****
Actually I am wrong sensor only sends messages on changes, so will have to think about this longer then 5 minutes now on how best to do it with a timer of some sort…
Thanks for the update was just about to install this!
@justinlhudson How well is it working for you?
I tried this one (made during lunch break) a couple times seems to work for Aeon Motion sensor. Simulator was acting up, so will just see what real world does.
Search for “bounce” and “debounce” and “state.descriptionPrev” and you see what I changed/added
Two inputs… Debounce and Period (amount of time before state should change). Period seems to be about 10 seconds for this sensor before it says inactive after being active with no motion. So figure that 10 or 15 seconds be good number with 1 debounce will show is motion for longer then 1 small instance proving was real motion.
metadata {
// Automatically generated. Make future change here.
definition (name: “Aeon Multisensor - Debounce”, namespace: “smartthings”, author: “SmartThings”) {
capability “Motion Sensor”
capability “Temperature Measurement”
capability “Relative Humidity Measurement”
capability “Configuration”
capability “Illuminance Measurement”
capability “Sensor”
capability “Battery”
fingerprint deviceId: "0x2001", inClusters: "0x30,0x31,0x80,0x84,0x70,0x85,0x72,0x86"}
simulator {
// messages the device returns in response to commands it receives
status “motion (basic)” : “command: 2001, payload: FF”
status “no motion (basic)” : “command: 2001, payload: 00”
status “motion (binary)” : “command: 3003, payload: FF”
status “no motion (binary)” : “command: 3003, payload: 00”
for (int i = 0; i <= 100; i += 20) { status "temperature ${i}F": new physicalgraph.zwave.Zwave().sensorMultilevelV2.sensorMultilevelReport( scaledSensorValue: i, precision: 1, sensorType: 1, scale: 1).incomingMessage() }
for (int i = 0; i <= 100; i += 20) { status "humidity ${i}%": new physicalgraph.zwave.Zwave().sensorMultilevelV2.sensorMultilevelReport( scaledSensorValue: i, precision: 0, sensorType: 5).incomingMessage() }
for (int i = 0; i <= 100; i += 20) { status "luminance ${i} lux": new physicalgraph.zwave.Zwave().sensorMultilevelV2.sensorMultilevelReport( scaledSensorValue: i, precision: 0, sensorType: 3).incomingMessage() } for (int i = 200; i <= 1000; i += 200) { status "luminance ${i} lux": new physicalgraph.zwave.Zwave().sensorMultilevelV2.sensorMultilevelReport( scaledSensorValue: i, precision: 0, sensorType: 3).incomingMessage() }
for (int i = 0; i <= 100; i += 20) { status "battery ${i}%": new physicalgraph.zwave.Zwave().batteryV1.batteryReport( batteryLevel: i).incomingMessage() }}
preferences {
input(“period”, “number”, title:“Period Active?”, description: “default: 10”, defaultValue:10)
tiles {
standardTile(“motion”, “device.motion”, width: 2, height: 2) {
state “active”, label:‘motion’, icon:“st.motion.motion.active”, backgroundColor:“#53a7c0”
state “inactive”, label:‘no motion’, icon:“st.motion.motion.inactive”, backgroundColor:“#ffffff”
valueTile(“temperature”, “device.temperature”, inactiveLabel: false) {
state “temperature”, label:‘${currentValue}°’,
backgroundColors:[
[value: 31, color: “#153591”],
[value: 44, color: “#1e9cbb”],
[value: 59, color: “#90d2a7”],
[value: 74, color: “#44b621”],
[value: 84, color: “#f1d801”],
[value: 95, color: “#d04e00”],
[value: 96, color: “#bc2323”]
valueTile(“humidity”, “device.humidity”, inactiveLabel: false) {
state “humidity”, label:‘${currentValue}% humidity’, unit:“”
valueTile(“illuminance”, “device.illuminance”, inactiveLabel: false) {
state “luminosity”, label:‘${currentValue} ${unit}’, unit:“lux”
valueTile(“battery”, “device.battery”, inactiveLabel: false, decoration: “flat”) {
state “battery”, label:‘${currentValue}% battery’, unit:“”
standardTile(“configure”, “device.configure”, inactiveLabel: false, decoration: “flat”) {
state “configure”, label:‘’, action:“configuration.configure”, icon:“st.secondary.configure”
main(["motion", "temperature", "humidity", "illuminance"]) details(["motion", "temperature", "humidity", "illuminance", "battery", "configure"])}
// Parse incoming device messages to generate events
def parse(String description)
state.descriptionCurrent = description
def result =
def cmd = zwave.parse(description, [0x31: 2, 0x30: 1, 0x84: 1])
if (cmd) {
if( cmd.CMD == “8407” ) { result << new physicalgraph.device.HubAction(zwave.wakeUpV1.wakeUpNoMoreInformation().format()) }
result << createEvent(zwaveEvent(cmd))
log.debug “Parse returned ${result}”
return result
// Event Generation
def zwaveEvent(physicalgraph.zwave.commands.wakeupv1.WakeUpNotification cmd)
[descriptionText: “${device.displayName} woke up”, isStateChange: false]
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv2.SensorMultilevelReport cmd)
def map = [:]
switch (cmd.sensorType) {
case 1:
// temperature
def cmdScale = cmd.scale == 1 ? “F” : “C”
map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision)
map.unit = getTemperatureScale()
map.name = “temperature”
break;
case 3:
// luminance
map.value = cmd.scaledSensorValue.toInteger().toString()
map.unit = “lux”
map.name = “illuminance”
break;
case 5:
// humidity
map.unit = “%”
map.name = “humidity”
break;
map
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [:]
map.name = “battery”
map.value = cmd.batteryLevel > 0 ? cmd.batteryLevel.toString() : 1
map.unit = “%”
map.displayed = false
map
def map = [:]
map.name = “motion”
log.debug “hello1”
def bounceFlag = false
bounceFlag = true
else
state.bounce = 0
map.name = “motion”
else
if(bounceFlag == true)
state.descriptionPrev = state.descriptionCurrent // safe prev state
def now = new Date() def runTime = new Date(now.getTime() + (1000 * settings."period".toInteger())) runOnce(runTime, reParse, [overwrite: true]) }
map.value = "inactive" map.descriptionText = "$device.displayName motion has stopped"}
map
public def reParse(){
parse(state.descriptionPrev)
def map = [:]
log.debug “hello2”
bounceFlag = true
else
state.bounce = 0
map.name = “motion”
else
map
log.debug “Catchall reached for cmd: ${cmd.toString()}}”
def configure() {
delayBetween([
// send binary sensor report instead of basic set for motion
zwave.configurationV1.configurationSet(parameterNumber: 5, size: 1, scaledConfigurationValue: 2).format(),
// send no-motion report 15 seconds after motion stops zwave.configurationV1.configurationSet(parameterNumber: 3, size: 2, scaledConfigurationValue: 15).format(),
// send all data (temperature, humidity, illuminance & battery) periodically zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 225).format(),
// set data reporting period to 5 minutes zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 300).format()])
seems to be working for me! so done (until proven broke)
