It certainly isn’t the current one, but it was authored by SmartThings back in 2015. It is designed to report power status (usb vs battery), in addition to motion on the original Smartsense motion sensor.
Here it is in its entirety:
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "SmartSense Motion with Power", namespace: "smartthings", author: "SmartThings") {
capability "Signal Strength"
capability "Motion Sensor"
capability "Sensor"
capability "Battery"
fingerprint profileId: "0104", deviceId: "013A", inClusters: "0000", outClusters: "0006"
fingerprint profileId: "FC01", deviceId: "013A"
simulator {
status "active": "zone report :: type: 19 value: 0031"
status "inactive": "zone report :: type: 19 value: 0030"
tiles {
standardTile("motion", "device.motion", width: 2, height: 2) {
state("active", label:'motion', icon:"st.motion.motion.active", backgroundColor:"#53a7c0")
state("inactive", label:'no motion', icon:"st.motion.motion.inactive", backgroundColor:"#ffffff")
valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false) {
state "battery", label:'${currentValue}% battery', unit:""/*, backgroundColors:[
[value: 5, color: "#BC2323"],
[value: 10, color: "#D04E00"],
[value: 15, color: "#F1D801"],
[value: 16, color: "#FFFFFF"]
valueTile("lqi", "device.lqi", decoration: "flat", inactiveLabel: false) {
state "lqi", label:'${currentValue}% signal', unit:""
main "motion"
details(["motion", "battery"/*, "lqi"*/])
def results
if (isZoneType19(description) || !isSupportedDescription(description)) {
results = parseBasicMessage(description)
else if (isMotionStatusMessage(description)){
results = parseMotionStatusMessage(description)
results
private Map parseBasicMessage(description) {
def name = parseName(description)
def value = parseValue(description)
def linkText = getLinkText(device)
def descriptionText = parseDescriptionText(linkText, value, description)
def handlerName = value
def isStateChange = isStateChange(device, name, value)
def results = [
value: value,
linkText: linkText,
descriptionText: descriptionText,
handlerName: handlerName,
isStateChange: isStateChange,
displayed: displayed(description, isStateChange)
log.debug "Parse returned $results.descriptionText"
return results
private String parseName(String description) {
if (isSupportedDescription(description)) {
return "motion"
null
private String parseValue(String description) {
if (isZoneType19(description)) {
if (translateStatusZoneType19(description)) {
return "active"
else {
return "inactive"
description
private parseDescriptionText(String linkText, String value, String description) {
switch(value) {
case "active": return "$linkText detected motion"
case "inactive": return "$linkText motion has stopped"
default: return value
private Boolean isMotionStatusMessage(String description) {
// "raw:7D360000001D55FF, dni:7D36, motion:00, battery:00, powerSource:00, rssi:1D, lqi:55, other:FF" - old (incorrect dev-conn parse)
// "raw:7D360000001D55FF, dni:7D36, motion:00, powerSource:0000, battery:00, rssi:1D, lqi:55, other:FF" - old (correct dev-conn parse)
// "raw:7D360000001D55FF, dni:7D36, motion:00, powerSource:00, battery:00, batteryDivisor:00, rssi:1D, lqi:55, other:FF" - new
description ==~ /raw:.*dni:.*motion:.*battery:.*powerSource:.*rssi:.*lqi:.*/ || description ==~ /raw:.*dni:.*motion:.*powerSource:.*battery:.*rssi:.*lqi:.*/
private List parseMotionStatusMessage(String description) {
def results = []
def parts = description.split(',')
parts.each { part ->
part = part.trim()
if (part.startsWith('motion:')) {
def motionResult = getMotionResult(part, description)
if (motionResult) {
results << motionResult
else if (part.startsWith('powerSource:')) {
def powerSourceResult = getPowerSourceResult(part, description)
if (powerSourceResult) {
results << powerSourceResult
else if (part.startsWith('battery:')) {
def batteryResult = getBatteryResult(part, description)
if (batteryResult) {
results << batteryResult
else if (part.startsWith('rssi:')) {
def rssiResult = getRssiResult(part, description)
if (rssiResult) {
results << rssiResult
else if (part.startsWith('lqi:')) {
def lqiResult = getLqiResult(part, description)
if (lqiResult) {
results << lqiResult
results
private getMotionResult(part, description) {
def name = "motion"
def valueString = part.split(":")[1].trim()
def valueInt = Integer.parseInt(valueString, 16)
def value = valueInt == 0 ? "inactive" : "active"
value: value,
linkText: linkText,
handlerName: value,
private getPowerSourceResult(part, description) {
def name = "powerSource"
def value = valueInt == 0 ? "battery" : "powered"
def descriptionText
if (value == "battery") {
descriptionText = "$linkText is ${value} powered"
else {
descriptionText = "$linkText is plugged in"
value: value,
linkText: linkText,
handlerName: name,
displayed: false
private getBatteryResult(part, description) {
def name = "battery"
// Temporarily disallow zero as a valid result b/c the current firmware has a bug where zero is only value being sent
// This effectively disables battery reporting for this device, so needs to be removed once FW is updated
if (valueInt == 0) return null
def batteryDivisor = description.split(",").find {it.split(":")[0].trim() == "batteryDivisor"} ? description.split(",").find {it.split(":")[0].trim() == "batteryDivisor"}.split(":")[1].trim() : null
def value = zigbee.parseSmartThingsBatteryValue(part, batteryDivisor)
def unit = "%"
def descriptionText = "$linkText battery was ${value}${unit}"
value: value,
unit: unit,
linkText: linkText,
handlerName: name,
displayed: false
private getRssiResult(part, description) {
def name = "rssi"
def parts = part.split(":")
if (parts.size() != 2) return null
def valueString = parts[1].trim()
def value = (valueInt - 128).toString()
def descriptionText = "$linkText was $value dBm"
value: value,
unit: "dBm",
linkText: linkText,
handlerName: null,
displayed: false
* Use LQI (Link Quality Indicator) as a measure of signal strength. The values
* are 0 to 255 (0x00 to 0xFF) and higher values represent higher signal
* strength. Return as a percentage of 255.
* Note: To make the signal strength indicator more accurate, we could combine
* LQI with RSSI.
private getLqiResult(part, description) {
def name = "lqi"
def percentageOf = 255
def value = Math.round((valueInt / percentageOf * 100)).toString()
def unit = "%"
def descriptionText = "$linkText Signal (LQI) was ${value}${unit}"
value: value,
unit: unit,
linkText: linkText,
handlerName: null,
displayed: false
