Smartthings Classic App craches when adding SmartApp
Hi all,
In SmartThigns Classic App for Androis (Huawei device), I go on the SmartApp screen and if I press Add SmartApp, the app crashes and closes. In the marketplace I see nothing… the list is empty.
Also I noticed that if I press “Add Manually” while adding a Thing, the app crashes but instead of closing it goes back to the My Home page on the My Things tab.
Those crashes are preventing me from using any SmartApp which I need :slight_smile: .
I tried to install and publish some SmartApp (ABC SmartApp) from the web portal but I cannot see them in the Classic App.
My hub is new and is from UK, while when I log in SmartThings with a Samsung account, I’m directed to graph-na04-useast2.api.smartthings.com which seems to be in US East.
Hub info:
Firmware Version is 000.027.00009
Hardware Version is hub v2, UK customer
I red that I should try to change the region of the Hub, so I reset it, but to be reconfigured it just asks a code from the hardware box and does not prompt me a country choise. After I reinstall it all was the same as before the reset…
Anyone that had the same problems can help?
Tnx.
Hi @Stefano_Liboni,
You could install the Samsung Internet App
Let us know if it helps.
Cheers.
Hi,
I sorted it out. The problem was the HUB is Uk and my Location was in US. I created a new Location in UK and all is working now: SmartApp can be installed and are there!
Tnx.
