Have you tried re-saving and publishing the device handler?
Thank you prjct92eh2
I’m using custom device handlers with the devices that are working ok. The problem is that the ST doesn’t see the new ones that I’m trying to pair.
Visualising the log on the IDE nothing is detected. Anyway, I will try to save and publish the Handlers again.
c66eaa6a-b33e-4d25-81f8-7755e72f9912 9:56:20 AM: debug detecting status for 4c0313b1-2a96-42ef-a909-72744b1b4017 : true
c66eaa6a-b33e-4d25-81f8-7755e72f9912 9:56:20 AM: trace in ssdpDiscover
c66eaa6a-b33e-4d25-81f8-7755e72f9912 9:56:20 AM: debug scheduled run, numberOfRuns: 4
c66eaa6a-b33e-4d25-81f8-7755e72f9912 9:56:20 AM: trace in discovery
c66eaa6a-b33e-4d25-81f8-7755e72f9912 9:56:13 AM: debug No devices to add, verified devices: [:]
There is a cache issue with custom device handlers. Did you open it, save and publish again?
Hi, did you solve your issue? I have the exact same, with multiple qubinos. I’ve tried everything with the DHs
any help would be much appreciated!
Yes, mine works fine. The bathroom tile wall was blocking the signal.
