czohar
(zohar)
April 2, 2019, 6:57am
1
Hello
I have many devices types connected to SmartThings, and I enjoy it very much.
A few weeks ago, one of my “Qubino flush shutter” devices was removed from “my devices” completely.
The buttons for activating it disappeared from the app devices and from the favorite on the home screen.
Some routines and scenes that used this device were stopped from working.
And I had to fix them manually.
I thought that the Qubino device was the problem, and bought a new one to replace it.
But I can’t get the device to pair to ST hub, I have tried many many times (I have installed several Qubino devices before with success)
I have also tried this -
Thanks for the feedback, here are some conclusions.
I am trying to use the device as a dry contact to activate some remote control push buttons.
It is impossible to pair/exclude the device when it is feeding with 24VDC. It only happens when it is feeding with 220VAC.
Using the DH from Eric Maycock the devices can be paired using the instructions below:
Once paired (turning on and off many times) the devices seems to work well using the classic app. The main device and the child can be turned on and off independently, although every time I’ve tried to do the same in the new AP the hub restart/reboot itself.
I disable the Secure Mode in the Hub’s options and the new Smarthings app was able to turn on and of the main Qubino device. For the childs it says the device can not be reach, an…
But with no success.
As I mentioned, a few weeks ago the device (that worked perfectly) was suddenly removed from the app like it wasn’t ever there…
Yes, I have the most updated Device Handler
*Other Qubino devices I have installed are still running ok
Any idea?
If you are using custom code for the dth, try going into the ide and republishing it.
czohar
(zohar)
April 16, 2019, 6:55am
4
TonyFleisher:
dth
Thanks, tried it but with no success…
chefj
(Jonathan)
August 12, 2020, 6:47pm
5
I, too, have this problem. @TheSmartestHouse (after trying to troubleshoot with me via phone for >30min) replaced one of my modules that was still under warranty, and I also bought a new one to replace another of my modules that had lost connectivity. Neither of the 2 NEW modules would connect to my SmartThings hub. Of course, Samsung wants nothing to do with this, as Qubino doesn’t “work with SmartThings.”
Anybody have any further advice? I bought a new module and have nothing to show for it. I’ve tried about 20+ times to pair the new modules, and nothing…
