You may have a 2nd Home (phantom) Location that was added as a result of installing and logging into the NEW SmartThings app at some point. Just a guess.
If you are using the SmartThings Classic app then you need to go-to the Dashboard page, press the 3 Horizontal bars (upper left), then click on the down arrow for the location drop-down and select the other Location in the drop down.
If above is the issue, then you can permanently remove the bogus Home location by following the steps in the post below:
