Smartthings and Hue Bridge via Hue B Smart
I’m attempting to connect to my Hue Bridge from the Smart App, Hue B Smart. The app was unable to find the bridge until I completely removed it from ST.
The app now sees the bridge, asks me to hit the connect button on top of the bridge, then goes around in circles and says “you are not authorized to perform the requested operation.”
Anyone have any clue what I’m doing wrong?
Here’s a screenshot of the error:
Hi, I have the same problem - did you find a solution?
Thanks,
jon
The original code no longer works
I have forked it and fixed it
Update app and DH from here
Hello - I installed your version but the hub is still never found. :confused:
Any advice?
Thank you!
sounds like the DH for the hub or the app hasnt been changed to mine or you forgot to publish
I would recommend deleting the app and all DHs and starting fresh
Ok. I will try that. Do I need to remove the hue bridge from Smartthings before installing your version?
yes all current hue apps and devices need to be removed
How to actually install this app ?
