SmartTag Belongs to Another Person
Hi,
I registered 7 SmartTags with my previous S8. Recently I changed to an S22 and removed my old phone from the Samsung account. With this step or due to any other migration issue, the tags probably ended up in Nirvana:
  • I cannot see the tags in SmartThings on my new phone.
  • I performed the reset procedure with one of the tags (battery removal, etc.) and started the adding.
  • Then a message appears: “This tag belongs to some other person. Remove it from its SmartThings app first”
Can anyone help me with some advice on a working recovery procedure other than buying new tags?
Whenever I think I get a handle on how the SmartTags work someone reports their adventures with the things and I start questioning what I think I know.
As long as you used the same Samsung/SmartThings account on the new phone I would have expected you to be able to see and control the SmartTags. The SmartThings API references the Samsung Account that onboarded them by the short form reference, and also has an ownerId which is SmartThings way of referring to the same account as a UUID. There is nothing that seems to bind them to a particular phone.
So perhaps the first thing to confirm is whether you are indeed using the same Samsung Account with SmartThings.
If you are using the same account make sure that you are using the correct SmartThings Location in the SmartThings app. That should appear at the top of the page when viewing Favourites or devices in Rooms. Sometimes you can end up with more than one without realising it.
Thanks for your reply! Everything you say sounds reasonable. I believe that it worked originally after having changed the phone with the Smart Switch app. The problem is that I cannot tell for sure when the issue occurred. I remember having updated all installed Samsung apps and SmartThings seemed to run me through a new setup afterwards. Honestly I cannot tell, if I then messed up something with the Samsung account. At least I am not aware of having more than 1 account, which works. Could be that I was asked to “use my phone for sign-in” in the setup? I doubt, if I get it fixed on my own (no rooms or devices added / visible). Any idea, if Samsung could do an account / ownerId and devices check for me?
Samsung was able to tell me, that I had two registered e-mail addresses. So @orangebucket was right. There was another zombie account, which I was not aware of anymore. I finally managed to delete it. Afterwards I could reset the SmartTags and newly register them without any issue.
I ran into the same problem when I tried to link my Samsung tablet to my Samsung phone which used two different emails in which the Samsung tablet took over my phone and deleted my Smarttag2’s from my phone. I’m not a techie, and older at that… but I googled the Samsung Customer service and called them 1-800-726-7864. The Samsung rep was able to be remoted into my phone and tablet where my Samsung account with my Smarttag 2’s were found. She showed me how to sign in with the email that had the tags on my phone and the app and my tags were restored and she helped me use the same email as my tags were on for my tablet so I wouldn’t get mixed up again. They are open from 12:PM to 9 PM eastern M-S. They are friendly too.
SOLVED!
It is registered on another phone. Good luck finding the other phone. Might be family member, coworker or friend you hang with or shared an App with. My smart tag was on my wifes phone and she didn’t even have find app or smartthings app on her phone. We have separate Samsung accounts, and don’t share any apps. No idea how my smarttag got on my wife’s phone. When I installed smartthings app for the first time, on wife’s phone, to install her new smarttag2, I found my smart tag listed. I deleted my smart tag off her phone and then installed my smarttag on my phone and her new smarttag2 on her phone.
Good luck finding the other phone it installed on.
