On my way home tonight at 5:37pm, my phone’s presence sensor came within range of my house, and triggered the “We’re Home!” routine, which set the mode to “Home” and set the SmartHome Monitor to “Disarm”.
Five minutes later, I executed my “Alarm: Off” routine (which just disarms SmartHome Monitor, just to be SURE it’s disarmed). Then, I executed a routine to open the garage door, and SmartHome Monitor immediately triggered an intrusion event.
The logs show that it had been disarmed TWICE in the previous 5 minutes, yet it still triggered and intrusion event, turned all the lights on, and triggered notifications.
And to be clear, this isn’t due to lack of presence detection. It detected my presence and ran the “We’re Home” routine (disarming SHM) 5 minutes before I opened the door and triggered the intrusion event.
It happened to me too (actually my wife). She was real excited about it. At the time, I thought it was a timing issue (messages processed out of order), but I don’t know. I’m leary of using it. It needs some sort of delay before sounding the alarm (like a real alarm system).
Mode misfires have been happening on ST platform for a while. Support has been saying that it is being worked on. I would assume that this issue is related to the same thing.
I’ve got a ticket in with support about this too. My home keeps changing back to away mode no matter how many times I disarm it. It’s probably hurting their infrastructure, because now it’s recording video to the cloud every time my motion sensors go off, which is basically constantly when we’re home! Haven’t heard back yet, but I’ll update when I do.
5:37pm Central Daylight Time (GMT -05:00), United States.
Yes, the “mode” is irrelevant, but as noted, the SmartHome Monitor was set to “Disarmed” (twice) and never re-armed in the 5 minutes prior to it generating an intrusion alarm.
I’m having a similar issue. Also once the intrusion is detected, it keeps showing “intrusion detected” even though it’s 48 hrs past and keeps sending me reminders (I have push and text enabled). Very annoying… And no response from Support since I opened the ticket 2 days back.
Once the intrusion event occurs, you have to go into the app and clear the alert, or it will keep notifying you. In SmartHome Monitor, if there’s been an event, the “Ok” status changes to something like “View Alert” (I can’t see it right now because I haven’t had an Intrusion event today). But you have to go in to that, and clear the alert.
