Smarthings V2 Hub not Registering Correctly
I had the need to delete and re-register my old V2 hub. I was able to register, once I found the welcome code. BUT the device did not download the normal range of Edge drivers. Namely none of the Smarthings stardard drivers loaded, not even the ZigBee Thing driver. (It did load a bunch of third party drivers, which are no use to me)
I was unable to connect any of my devices. I have managed to find a couple of channels to force a download of nonstandard drivers. (Like Sonoff). I even found aa official Smarthings channel, but they claim they are only beta drivers.
Is the a way to force the standard drivers to download, or is there a Channel I can register with to download the standard, non-beta drivers?
Try this link
Thanks for the info. However, I get an error when accessing the channel.
UnexpectedError: A non-recoverable error condition occurred.
I suggest going thru the factory reset on the hub again.
That is to be expected as they are intended to be installed automatically when needed, though from what you said later it sounds like this might not have happened for you.
It is possible to subscribe to the production default channel as you can with other channels. The invitation URL is on:
The previously quoted URL was a subscription URL that expects you to have already accepted the invitation (aka subscribed). It would be nice if it had failed more elegantly.
Thank you. That was helpful.
But some magic just happened to the drivers I have already loaded via a couple of beta channels.. They updated to the latest versions? So, I am happy.
