Does anyone know why some of my SmartApps are not showing up in the GitHub Column and are highlighted in Green? I assume I won’t be able to update them…
hey never noticed that before - I think you are right. My guess, if the original author deleted or moved his shared github, then you are left with a standalone ST device type.
You can edit it yourself anyway. Yeah, not what you meant.
http://docs.smartthings.com/en/latest/tools-and-ide/github-integration.html#color-coded-names
If the smartapp or device handler is missing the github repository link, you can add it back. Just click on properties and go to the source code options. There is a pull- down menu where you can select the appropriate repository. If the repository is not there, you will need to add it in the settings at the top of Smartapps or device handlers.
