Not Showing updated GitHub Code in IDE
for the last month or so i have noticed that my device types and smart apps aren’t being highlighted when the github repo changes i have to go through all of them one at a time to see if something was updated.
is anyone else having this issue?
I have the same problem. By any chance did you ever use IDE GitHub integration with Rule Machine or any other smartapp that has had its repo removed? I think it might be related to that but I haven’t been able to reset it back to working.
I had the same problem and I removed the repository from the App Settings of Rule and Rule Machine, but it didn’t fix the problem.
What I didn’t initially do was delete the Rule Machine repository from the Settings, but once I did that, everything started working again.
