Smart voltage sensor
I have googled and searched to no avail. I don’t even know what to properly call what I am looking for. I am looking for a sensor the can sense a current change and send a notification. Anyone seen anything like this?
hi is this any good
There’s multiple ways to do it. Many smart plugs have power sensors, some devices called Home Energy Monitors (HEMs) use a clamp around the conductors to sense current.
It REALLY depends on
  1. your use case (a US 15a/110v plug won’t do a US 40a/220v dryer)
  2. what geography you’re in, because power requirement, device spec and availability varies GREATLY by geography
I’m wanting to have a sensor, that when current is applied, it sends a message. Like say I wanted to be notified when my septic high water alarm goes off. Alarm goes off, it triggers current to a warning light, the sensor reads the change and alerts hub. I want to tap into the wires. Not looking for a specific measurement, just a change from 0 to a 1.
You can accomplish this with a smart plug like this if you have a zwave hub
https://aeotec.com/products/aeotec-smart-switch-7/
You can create an automation based on the wattage being used. Just set a low threshold amount. If it goes over that amount, you know it is running.
