Hi guys,
in my flat I have only 2 wires in my switches (L and ground), no travellers wire.
Is there any option how to connect smart switch into this infrastructure?
Hi guys,
A traveler wire is used between two switches that control the same lamp. It’s easy to get around that by using a “virtual three-way“ (“virtual two-way” if you are in the EU). But I suspect that’s not what you’re really asking about.
If you are in the EU, a “two wire“ versus “three wire“ light switch is one that does not have a neutral.. A neutral is required for most smart switches to power the radio. But it is not required for all.
If you’re in the EU, see the following recent thread:
FAQ: Light switch no neutral (UK) (2019)
If you’re in the US or Canada see the following:
FAQ: SmartThings-Compatible Switches that Don’t Require Neutral (US, 2019)
Thank you JDRoberts, I will g thru the article you postedd (I am in EU)
but I am glad it seems 2 wires are not an obstacle to have such home setup. I then just need to find some nice “EU style”
switch
Livolo seems to be nice design, but I will google if it is even compatible with ST
