Random events indeed! Modes are totally hosed. I already have too many tickets related to mode since long. In fact the background refresh of the app does not appear to happen as well.
Maybe Iām missing something, but is there no way to set the alarm state via a door lock?
Like if I unlocked my front door, set the alarm to disarmed.
I canāt see away to do it via modes under automaticallyā¦
You can do it with a contact sensor opening.
I think to use the lock would take some indirection with a small app to catch the unlocked event, and then do something to cause the alarm to disarm.
Iām not using Smart Home Monitor at all and Iām seeing craziness in the presence handling. Setting a virtual presence sensor to ādepartedā using SharpTools actually shows in the log as the device being set to āarrivedā
But setting it to āarrivedā leaves it that way, so itās not like some crazy Opposite Day thing or anything.
Seems like setting the house to āhome modeā when people arrive fires up some of the associated events, but not others, while setting the house to āaway modeā doesnāt do anything (supposedly because the presence sensors are not detected as having left).
Iāve seen this with just setting the sensor state manually, to rule out GPS / geofence issues or anything else of the sort⦠just changing the house mode seems to be making things all sorts of wonky.
With all due respect, this thread is about Smart Home Monitor, not SharpTools and presence issues. ![]()
I do have contact sensors on both. But if someone breaks in, then the contact sensor is going to disarm the alarm.
Although the force needed would trigger the alarm on the lock and push notifications.
Hoping JoeC will build alarm state control into simple rule builder. Then itās an easy fix.
We all agree that Locks has to be an integral part of SHM.
Or, become an option in āAutomatically Performā in Routines. There are contact sensors there, and adding locks would make sense. Then you could have a Routine that runs automatically when a lock is locked or unlocked. Thatās right up there with presence for usefulness.
And, this can be done with a tiny app, that is, the tiny app could run a Routine upon lock or unlock.
Here is a small app that allows you to run a Routine when a lock is unlocked. From there, you can do whatever you want!
* Unlock Runs Routine
* Copyright 2015 Bruce Ravenel
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Unlock Runs Routine",
namespace: "bravenel",
author: "Bruce Ravenel",
description: "Run a routine when a lock is unlocked",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
page(name: "selections")
def selections() {
dynamicPage(name: "selections", title: "Select your Routine and Lock", uninstall: true, install: true) {
def phrases = location.helloHome?.getPhrases()*.label
section("Routine") {
input "myPhrase", "enum", title: "Routine", required: true, options: phrases
section("Lock") {
input "myLock", "capability.lock", title: "Lock", required: true
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
subscribe(myLock, "lock.unlocked", unlockedHandler)
def unlockedHandler(evt) {
location.helloHome.execute(myPhrase)
So I was just testing out the Smart Home Monitor with my motion sensors, where I only enabled āAlert with Lightsā on my Fortrezz Z-Wave Siren, except instead of just using the strobe function, it set off the siren as well.
Anyone else seeing similar?
By any chance were you previously using a custom device type? And if so, what device type is a device using now?
Nope, not a custom device type. Just the default one. And the independent āStrobeā button on the āThingsā page for it works. Based on my log, it seems like the Smart Home Monitor just sends the āBothā command to it.
So, do you now receive alerts on arm and disarm?
I have a support ticket in for this issue now for a few days. Iām not sure whatās up, so I pinged support for an update. If you havenāt emailed in a ticket, please do.
I did open a ticket, they replied with itās a bug in the app. Iām on Android so Iām not sure if that applies to ios as well
SHM wizard asks for our Away sensors, then our Stay sensors, then only one set of options to alarm.
This does not cover the Use Case of using lights to alert ā
ā If Away, Turn on lights IN the house
ā If Stay, Turn on lights OUTSIDE the house
Am I missing something?
Clips and the sami camā¦
Of the 20 odd intrusions that I have detected over the past few days, I have about 5 clips that actually are playable.
Hereās a few of the clip states that I have seen.
Some make sense, others do not:
Makes sense:
Whatās this mean?
Or how about this one?
Hereās what a good one looks like, however it seems to take F O R E V E R for these to actually get encoded, if they ever do.
Iām probably at a 30% success rate in getting actual clips availableā¦
Anyone else?
Iāve had one incident that looked like your second screen shot. The rest have loaded fine. But Iāve only had 6 incidents.
How about a push message when the Smart Home Monitor changes status?
Thx
Yes, any word on the āContactsā option for Smart Home Monitor? I want to be notified of things⦠my wife, however, does not.
Are all the people working on this thing single or living with other techies? If not, that would re-prioritize a LOT of features!
