with the V3 hub and new app, you have to pick a device from the list manually and then acknowledge the security warning before the hub will go into general inclusion mode. you can tell it is in pairing mode when the green led is flashing on the hub.
Hello ,
I have a urgent problem. I have a customer that I have previously added Sinope Zigbee thermostats to.
I have added some more yesterday and they wont pair. I look at the logs and the logs state
" 2019-02-20 6:34:20.380 AM PST moments ago HUB zwStatus include search Z-Wave include search started"
i chose manual include device and then chose a GE smart Dimmer Zigbee. The device handler has been installed and working fine with the previous installed thermostat.
was there a update or something. Am i doing something wrong.
Please help , I need to finish up.
I have a few of those thermostats with a hub v3. I followed the instructions from the Sinope website with the Device Handlers posted there and everything works great. You need to use the Classic app.
The time and exterior temp stopped working a few days ago because of the Wunderground Weather API, but they’ve fixed this today. I’m yet to test the fix.
