I started a new thread because I see lots of posts about the Z-Wave version, but none about Zigbee.
I’ve been attempting to move my lock over for a while, but don’t seem to be able to find any drivers that use edge, and it always falls back to the standard DTH.
Do you have a custom DTH installed in the IDE? If so, that will take precedence over an Edge driver. You’ll need to remove the device from your network, delete the custom DTH, and then re-install the device. The stock ST Edge driver zigbee-lock supports that Schlage model. As with Z-Wave Schlage locks, you may need to factory reset the device to get it to associate. YMMV
you may want to check if the fingerprint of your lock is handled by @Mariano_Colmenarejo Zigbee Lock Mc Edge driver. if not, you can probably request that it be added.
