Just moved into a new home with a Schlage Camelot Touchscreen lock. I followed the instructions and have the lock showing up in Smart Things app on iphone. However, the battery level shows 0% (but lock works fine with local code), but I can’t activate it from the app. Nothing happens. Any ideas?
hopefully you are using the ST Classic app.
- run z-wave repair
if that does not resolve control through the app, then
- remove device
- factory reset device
- exclude device in ST
- move ST hub close to lock and re-add
i installed one of these at my dads house and got an error (secure inclusion failed)when pairing, even though it showed up in smartthings i could not control it, i had to move the hub within 15 feet of the lock, excluded it and then it paired successfully
12 feet, not 15
Try adding a z-wave repeater between the lock and the hub and also follow @jkp instructions to exclude and re pair there after. Schlage locks are very sensitive to mesh issues.
