Schlage Nexia BE369NX
Does anyone have this door lock installed and working with ST’s? If so, what’s working and not working? I’ve got it working with Vera, the last thing I have still working with Vera.
Thanks in advance.
I don’t have the lock, but according to the list of compatible devices, it should work with ST: http://build.smartthings.com/compatible-devices/
Assuming it’s like the Kwikset in terms of abilities, right now you can just lock/unlock it. You can’t program access codes or anything else at this point.
I’ve got 2 of these locks and I don’t think it works well with Smartthings.
Paired one up with smartthings and it would not recognize it as a Zwave lock. I had to go into the IDE and set the type as a Zwave lock.
It does trigger the lock mechanism when you tap the “Lock” or “Unlock” buttons on the app. However, smartthings does NOT recognize the state of the lock. Unlock it and it will still show locked.
This makes it pretty much useless when paired with smartthings, because you don’t know when your lock has been unlocked/locked.
