Hello.
I got a schlage Touchscreen I have tried several times to include o program with my smartthings hub with no luck.
Every single time I press the program code and then 0, I always get the “X” and never the green light
I reset the lock to factory settings and.still got the problem.
The hub is actually plug into the power and to the router about 7 feet from the door. Is it too much? If so, how can I bring the hub closer if it has to be plug into the.router?
I’m not sure which Schlage lock/keypad you have, but if you have the Connect version, here is a good thread with several good links and info on best practices:
