Try the FAQ, it works for most people, but you have to follow these steps exactly. (This is a clickable link.)
A zwave lock will exchange an encryption key with the hub when it is first paired. Most models will say that the pairing failed if the encryption key is not exchanged successfully.
The schlage are unusual in that if the encryption key is not exchanged successfully, they will still say that the lock paired. It will work from the touchpad but the network will not be able to control it because there is no encryption key. Very frustrating.
But if you follow the steps in Walter’s post exactly as written, you should be able to get it to reset and try the key exchange again.
