So ever since upgrading to the new SmartThings app that was just released, my Schlage Camelot Connect cannot be controlled and constantly says “Getting Status” and when clicking on it says its unreachable.
I removed and re-added the lock to SmartThings fine but it still isn’t reachable.
What do you mean “I have it set up correctly”? What do you have set up correctly? The new app? Your hub appears in the new app? You’re part of the New App beta? Then you should report your problems there. No one but beta users is on the new app yet because it’s not SmartThings, it’s Samsung Connect.
Did you even read the post on the link that I posted? You can’t use the new app yet.
Oh. So they updated the Samsung app and called it SmartThings. Isnt that the “new” app? That’s the one I am having troubles with. If its not the new app then I’ll just go back to the old app and see if the problem is fixed. But you can see where I was confused. They said there releasing a new app, and at the same time update the old Samsung app to “SmartThings” with a spiffy new design which makes you think that’s the app.
Welp. Back to old app. Removed all devices, Factory reset Hub and Schlage. Re-added Schlage. Connected fine. But now I cannot unlock/lock from smartthings app. Just says “Unlocking”. Gah
I am having the same issue. I can lock and unlock my locks but can not see access history or add or change pins with the new app (old Samsung connect app)
