I installed a few of the GE 14291 in my home. The blue led light on 2 of the switches will come on when I turn on the light. When the light is off, the led light will go off too. The switches work fine, it will turn on/off the light and response to the app. Did I wire them incorrectly or did I get 2 bad switches?
This is configurable via gear when viewing the switch in the app. There is a ST bug that changes this setting periodically. Click the gear, change LED indicator to Never and then click Done and then click Done to exit the settings. Then go back in and change it to When off and click Done and Done again and you should be good. I have to do this from time to time on some of my switches.
Thanks for the information. It works great.
