GE Smart Switch - LED Locator working backwards
I have a GE Smart Switch and add-on switch wired up for a 3 way install. Everything works correctly, except the LED locator light works backwards. When the light is off, the LED is off and when you turn the light on, the locator LED lights up.
I have other switches installed the same way and they work fine, but these seem to have this weird issue. They work fine - I can control them from my hub without issue, but the locator light is backwards from every other switch I have.
Has anyone else seen this?
Go into the settings for that device from the app, you can change if the LED is lit when on or off.
I never thought to check there!
Thanks! That took care of it. I kept checking my wiring over and over and couldn’t figure out what was wrong.
