This is a device handler for the Zooz Universal Relay (ZEN17).
Features
Supports all of the device’s configuration parameters
Main device is a switch that controls the relays together.
Creates a child switch for each relay
When the “Input Trigger” is disabled for a Relay the input and relay act as separate devices.
Creates a child device for the relay’s input when its “Input Type” setting is set to Water Sensor, Motion Sensor, Contact Sensor, Smoke Detector, or On/Off Report.
The device ignores the “Input Trigger” setting for Momentary, Toggle, and Garage Door so those input types will not create a child device. -
Warning: The input’s child device gets deleted when the Input Type setting is changed.
The manual says to exclude the device and join it again after changing the Input Type settings, but that’s not necessary with this handler. The only catch is that if you don’t do that then the child device it creates won’t get assigned to a room.
