Contact Heatit for integration with SmartThings
Introducing the Heatit Z-Smoke Smoke Detector Alarm Siren device handler (DTH)
RBoy Apps is the official SmartThings partner for Heatit products
The Heatit Z-Smoke Detector is a multifunctional Z-Wave Plus smoke sensor. It features a 230v mains powered smoke sensor, siren alarm, PIR motion sensor, temperature sensor, heat alarm and emergency lighting. It also features a built in battery backup and a tamper sensor.
WHERE TO BUY THE SMOKE DETECTOR
It can be purchased from Heatit or Thermo-floor.
Device Handler Screenshots
Key Features of the DTH
- Use as a Siren alarm
- Smoke sensor
- Heat sensor (temperature rising too quickly)
- Motion sensor
- Reports Temperature (0.1 °C accuracy)
- Temperature adjustment offset
- Power source (mains/battery)
- Battery level
- Tamper reporting
- Manual refresh (pull down on page)
- Optimized for new ST app
- Toggle Siren alarm from dashboard
- Multifunctional dashboard display
- Works with the Automation tool
- Supports S0 and S2 security
INSTALLATION INSTRUCTIONS
Device handler installation instructions can be found here. Once the device handler is installed, pair the device with the hub:
PAIRING INSTRUCTIONS
- Make sure the device is within 5ft of the hub and sometimes rebooting the hub helps before pairing and keep the ST mobile app open
- Press the
button the SmartThings app to initiate the pairing - Press the main button 3 times within 1 second and it should beep loudly when the pairing process is initiated
- It should complete pairing within 30 seconds the device should show up on the ST app. If it doesn’t show up, reset the device, reboot the hub, bring the device closer and try again
EXCLUSION INSTRUCTIONS
- Start the device removal or exclusion process on the SmartThings app
- Press the main button 3 times within 1 second and it should beep loudly when the exclusion process starts
- If it doesn’t exclude, try again otherwise reset the device
FACTORY RESET
- Press the main button for atleast 20 seconds and then release it
NOTES
- When a smoke or heat alarm is triggered, the only way to silence the alarm is to press the main button on the device itself (mute)
- The device only reports battery levels in increments of 20%
You can also check out the following button related security and convenience apps
[RELEASE] Door Chimes and Notifications for Doorbells and Sensors
[RELEASE] Motion Sensor Thermostat with Remote temperature sensors, Presence detection and Schedules
[RELEASE] Virtual Garage Door Opener/Controller with Relays and Contact/Tilt/Door Sensors
