After spending much time on the phone with FortrezZ telling them that their integration does not work, I just decided to do it myself. So here is my fully functional version for the following models:
WWA02AAUSW; WWA02AAUSB; WWA01AAUSW; WWA01AAUSB by FortrezZ
disforw with your code were you able to get the Fortrezz (wwa-02aa) to report the current Temp with each reporting period? I see you have a couple of code versions, I take it the pre “Frozen Food Quality” is the one that works.
thanks.
Tom,
Yes you are correct about the pre “Frozen Food Quality” being the better handler to use. My unit reports temperature without an issue. When adding the device to your hub, make sure to trip it at least once using a wet towel across the water leads.
