[RELEASE] Fibaro RGBW Controller (FGRGBWM-441) - Advanced DTH
Hi everyone, my first post in the community (I have just migrated from Vera to SmartThings).
Firstly, a big thank you to zcapr17 for this Fibaro RGBW Controller device handler.
I have 2 x RGBW LED strips controlled by 2 x Fibaro RGBW Controllers and as noted above, had previously been using these with Vera with no issues.
However using the SmartThings built in device handler I could not get the brightness level (on white setting at 100%) to the level I had been able to achieve using the Vera plugin, so I thought I would check out the device handler written by zcapr17.
I found out 2 things from this:
  1. When first installed, this showed the brightness level for both Fibaro RGBW controllers at 39% which I initially thought was odd and then realised why. The built in ST device handler assumes a scale of 0-100 whereas the actual scale on the Fibaro device is 0-255 hence a value of 100 in the built in ST device handler equals 100/255 * 100 i.e. 39%. So the ST built in device handler needs changing to allow the correct maximum brightness level to be selected.
  2. Like a number of posters I wasnt able to configure any of the parameters for this advanced device handler from the mobile app (using a Samsung S8 phone) - I assume it is an issue with enums or default values but no attempt at setting all values solved the issue.
So I just used the IDE to set these by cross referencing with the code to set the required values for my 4 channel (RGBW) LED strips:
|configAggregateLevelMode|OUT|
|configAggregateSwitchMode|OUT|
|configAssocGroup01||
|configAssocGroup02||
|configAssocGroup03||
|configAssocGroup04||
|configCh1Mapping|Red|
|configCh1Threshold|1|
|configCh2Mapping|Green|
|configCh2Threshold|1|
|configCh3Mapping|Blue|
|configCh3Threshold|1|
|configCh4Mapping|White|
|configCh4Threshold|1|
|configDebugMode||
|configLevelSetMode|SCALE|
|configParam01|255|
|configParam06|0|
|configParam08|0|
|configParam09|1|
|configParam10|10|
|configParam11|67|
|configParam12|255|
|configParam13|2|
|configParam14_1|1|
|configParam14_2|1|
|configParam14_3|1|
|configParam14_4|1|
|configParam16|1|
|configParam30|0|
|configParam38|10|
|configParam39|600|
|configParam42|0|
|configParam43|5|
|configParam44|30|
|configParam45|10|
|configParam71|1|
|configParam72|1|
|configParam73|0|
Anyway I hope this is useful.
