Heya All,
This questions have been going for around a while, but I don’t think they ever got a straight answer on them, so here they go:
1.- What exactly does ‘runlocally: true’ truly means and does?
- Does that mean that the DTH gets downloaded into the hub and the Java Groovy code stays locally?
- If so, do all capabilities, and/or methods or just some (like those native commands) run locally?
2.- what exactly does ‘executeCommandsLocally: true’ truly means and does?
3.- what exactly does 'genericHandler: “Zigbee” ’ actually do?
4.- If the hub loses internet connection, and the custom DTHs are on cloud (depending on the answer on question 1), what happens with the device?
- If custom DTHs are not copied into the hub, how does the hub ‘know’ what should be the ‘closest’ default handler for that device?
5.- Based on the previous questions, what it all means after 0.35.x firmware gets deployed with the local automation rules (rules API) happening?
6.- Will local automation rules on the 0.35.x firmware be geolocked as smartapps to only US, or will it be distributed globally?
7.- (Added in an edit), what happens with STHM on a network with no internet? If the app doesn’t work locally (requires the cloud) as per comments done in this community, and you do “ST Button → Scene (home) → home mode (disarmed)”, do you effectively disarm STHM?
If you can help answer @nayelyz or point to who can, I’ll owe you months worth of coffee
Edit: Will edit this post with all the historical references I can find.
