Okay, I went back to the preference screen and changed query lock code to off (false) and I also set my code length to 4. This time the preferences stuck.
Now a refresh of parameters is actually doing something!
2024-03-11T18:11:28.933872414+00:00 TRACE Z-Wave Lock PH Found ZwaveDispatcher handler in zwave_lock -> Schlage Lock -> Schlage BE469
2024-03-11T18:11:28.939436414+00:00 INFO Z-Wave Lock PH <ZwaveDevice: de44069a-c231-4cc9-b410-c942844fd837 [6E] (Front door lock)> emitting event: {"attribute_id":"interiorButton","capability_id":"platinummassive43262.schlageInteriorButton","component_id":"settings","state":{"value":"enable"}}
2024-03-11T18:11:28.945720080+00:00 DEBUG Z-Wave Lock PH Front door lock device thread event handled
2024-03-11T18:11:29.341819747+00:00 TRACE Z-Wave Lock PH Z-Wave command(5f0ea41f) transmit status: TRANSMIT_COMPLETE_FAIL
2024-03-11T18:11:29.439066081+00:00 TRACE Z-Wave Lock PH Received event with handler unnamed
2024-03-11T18:11:29.520195414+00:00 INFO Z-Wave Lock PH <ZwaveDevice: de44069a-c231-4cc9-b410-c942844fd837 [6E] (Front door lock)> received Z-Wave command: {args={configuration_value=0, parameter_number=15, size=1}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S2_ACCESS_CONTROL", payload="\x0F\x01\x00", src_channel=0, version=1}
2024-03-11T18:11:29.533151747+00:00 TRACE Z-Wave Lock PH Found ZwaveDispatcher handler in zwave_lock -> Schlage Lock -> Schlage BE469
2024-03-11T18:11:29.537833414+00:00 INFO Z-Wave Lock PH <ZwaveDevice: de44069a-c231-4cc9-b410-c942844fd837 [6E] (Front door lock)> emitting event: {"attribute_id":"autoLock","capability_id":"platinummassive43262.autoLock","component_id":"settings","state":{"value":"off"}}
2024-03-11T18:11:29.544397081+00:00 DEBUG Z-Wave Lock PH Front door lock device thread event handled
2024-03-11T18:11:33.132711416+00:00 TRACE Z-Wave Lock PH Received event with handler capability
2024-03-11T18:11:33.173990749+00:00 TRACE Z-Wave Lock PH Z-Wave command(0286965f) queued for radio transmission: CC:Configuration, CID:0x04
2024-03-11T18:11:33.176706416+00:00 INFO Z-Wave Lock PH <ZwaveDevice: de44069a-c231-4cc9-b410-c942844fd837 [6E] (Front door lock)> received command: {"args":{},"capability":"platinummassive43262.autoLock","command":"autolock","component":"settings","positional_args":{}}
2024-03-11T18:11:33.225557082+00:00 TRACE Z-Wave Lock PH Found CapabilityCommandDispatcher handler in zwave_lock -> Schlage Lock -> Schlage BE469
2024-03-11T18:11:33.235770416+00:00 INFO Z-Wave Lock PH <ZwaveDevice: de44069a-c231-4cc9-b410-c942844fd837 [6E] (Front door lock)> sending Z-Wave command: {args={configuration_value=-1, default=false, parameter_number=15, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0F\x01\xFF", src_channel=0, version=1}
2024-03-11T18:11:33.243335749+00:00 DEBUG Z-Wave Lock PH Front door lock device thread event handled
2024-03-11T18:11:34.558904750+00:00 TRACE Z-Wave Lock PH Z-Wave command(0286965f) transmit status: TRANSMIT_COMPLETE_OK
2024-03-11T18:12:06.129127431+00:00 TRACE Z-Wave Lock PH Received event with handler unnamed
2024-03-11T18:12:06.145409098+00:00 INFO Z-Wave Lock PH <ZwaveDevice: de44069a-c231-4cc9-b410-c942844fd837 [6E] (Front door lock)> received Z-Wave command: {args={alarm_level=1, alarm_type=27, event="AUTO_LOCK_LOCKED_OPERATION", event_parameter="", notification_status="ON", notification_type="ACCESS_CONTROL", v1_alarm_level=1, v1_alarm_type=27, z_wave_alarm_event=9, z_wave_alarm_status="ON", z_wave_alarm_type="ACCESS_CONTROL", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="S2_ACCESS_CONTROL", payload="\x1B\x01\x00\xFF\x06\x09\x00", src_channel=0, version=3}
2024-03-11T18:12:06.168082765+00:00 TRACE Z-Wave Lock PH Found ZwaveDispatcher handler in zwave_lock -> Schlage Lock -> Schlage BE469
2024-03-11T18:12:06.173310765+00:00 INFO Z-Wave Lock PH <ZwaveDevice: de44069a-c231-4cc9-b410-c942844fd837 [6E] (Front door lock)> emitting event: {"attribute_id":"lock","capability_id":"lock","component_id":"main","state":{"data":{"method":"auto"},"value":"locked"}}
2024-03-11T18:12:06.178890765+00:00 INFO Z-Wave Lock PH <ZwaveDevice: de44069a-c231-4cc9-b410-c942844fd837 [6E] (Front door lock)> emitting event: {"attribute_id":"unlockCodeName","capability_id":"platinummassive43262.unlockCodeName","component_id":"main","state":{"value":"Locked"}}
2024-03-11T18:12:06.184048765+00:00 DEBUG Z-Wave Lock PH Front door lock device thread event handled
2024-03-11T18:12:10.823736434+00:00 TRACE Z-Wave Lock PH Received event with handler unnamed
2024-03-11T18:12:10.836959767+00:00 INFO Z-Wave Lock PH <ZwaveDevice: de44069a-c231-4cc9-b410-c942844fd837 [6E] (Front door lock)> received Z-Wave command: {args={door_condition=0, door_lock_mode="DOOR_SECURED", inside_door_handles_mode=0, lock_timeout_minutes=254, lock_timeout_seconds=254, outside_door_handles_mode=0}, cmd_class="DOOR_LOCK", cmd_id="OPERATION_REPORT", dst_channels={}, encap="S2_ACCESS_CONTROL", payload="\xFF\x00\x00\xFE\xFE", src_channel=0, version=1}
2024-03-11T18:12:10.848347100+00:00 TRACE Z-Wave Lock PH Found ZwaveDispatcher handler in zwave_lock
2024-03-11T18:12:10.855094100+00:00 INFO Z-Wave Lock PH <ZwaveDevice: de44069a-c231-4cc9-b410-c942844fd837 [6E] (Front door lock)> emitting event: {"attribute_id":"lock","capability_id":"lock","component_id":"main","state":{"value":"locked"}}
2024-03-11T18:12:10.860281767+00:00 DEBUG Z-Wave Lock PH Front door lock device thread event handled
2024-03-11T18:12:16.065013769+00:00 TRACE Z-Wave Lock PH Received event with handler capability
2024-03-11T18:12:16.090037436+00:00 TRACE Z-Wave Lock PH Z-Wave command(88491573) queued for radio transmission: CC:Configuration, CID:0x04
2024-03-11T18:12:16.125113436+00:00 INFO Z-Wave Lock PH <ZwaveDevice: de44069a-c231-4cc9-b410-c942844fd837 [6E] (Front door lock)> received command: {"args":{},"capability":"platinummassive43262.autoLock","command":"off","component":"settings","positional_args":{}}
2024-03-11T18:12:16.130370436+00:00 TRACE Z-Wave Lock PH Found CapabilityCommandDispatcher handler in zwave_lock -> Schlage Lock -> Schlage BE469
2024-03-11T18:12:16.139686770+00:00 INFO Z-Wave Lock PH <ZwaveDevice: de44069a-c231-4cc9-b410-c942844fd837 [6E] (Front door lock)> sending Z-Wave command: {args={configuration_value=0, default=false, parameter_number=15, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0F\x01\x00", src_channel=0, version=1}
2024-03-11T18:12:16.147308436+00:00 DEBUG Z-Wave Lock PH Front door lock device thread event handled
2024-03-11T18:12:16.189812103+00:00 TRACE Z-Wave Lock PH Z-Wave command(88491573) transmit status: TRANSMIT_COMPLETE_OK
In the app I finally see the current state of the auto Lock attribute.
Now I need to re-run some of the tests above and I’ll let you know what I see.
